Question about Acer Aspire 4315-2490 Notebook
My acer aspire 4315-2490 just shut-off after more that 2hours of use even if a/c adapter is still connected. I turned on the power button and it begins startup after a minute it again totally shuts off. I again pressed the power button and it begins start up unfortunately after a minute it shuts off again. What seems to be the problem? Is it peripherals or hardware? Hope you can assist me on this. Thanks - angel
  • 86 Answers
It sounds like the machine is overheating. When you are using it, make sure that the intake vent is clear and that you're not leaving it on for extremely long periods of time. You could also check that there isn't a large amount of dust on the vents.
Posted on Jul 19, 2010
Acer aspire notebook will not switch on after battery discharge even with mains adaptor plugged in. Help Noel
1. Remove the battery and the ac adapter from the laptop computer. Press the power button for about 10 seconds. This will discharge thee flea power from the laptop.
2. Connect the battery and the ac adapter. Charge the computer for about 30 mins then try to turn the computer on.
If this does not work, try to turn the computer on with only the AC adapter connected. If this works then it time to replace the battery.
Jun 26, 2011 | Acer Aspire One PC Notebook
Acer Aspire One, the Laptop powers on,the yellow light comes on when you hit the power button, thats about it you dont hear the hard drive running and the lcd dosent come up either,sometimes if i remove...
sounds like a power issue, may be related to the motherboard and you may need to get in touch with Acer support for it, but try these and see if it helps. turn off the system, remove the battery and adapter and remove the hard drive and memory if you can. with the components removed, hold down the power button for about 10 secs to discharge whatever power remaining. After that, connect all components, boot in BIOS and reset the default settings, and then restart the computer and observe it. Make sure to set any BIOS options again that you may have set previously.
Aug 25, 2010 | Acer Aspire One PC Notebook
Cannot connect to the internet. Took the ethernet plug from desktop and it it did not lite up wireless button. Where is the button to turn on internet?
Your guides To help you use your Acer notebook, we have designed a set of ... Note: If you cannot power off the computer normally, press and hold the power button ... your AC adapter: • • • • Do not connect the adapter to any other device. ... 62 62 63 Taking your notebook PC with you Disconnecting from the desktop ...
www.scribd.com/.../Acer-Aspire-4720G4720Z47204320-Note-Book-Manual
Jul 11, 2010 | Acer Aspire 5315 Notebook
I have an Acer Aspire 4520 and the batter will not stay charged and it keeps shutting down even though I have it plugged in. Please help.
Hi there, please perform power drain first. Take out the battery and unplug the power adapter. Press and hold the power button for 30secs. Put the battery back in, plug in the power adapater then turn on the computer. If same issue will occur then you need to replace your battery.
May 16, 2010 | Computers & Internet
Turns on but no video. another monitor would not
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
Mar 15, 2010 | Acer Aspire 5630 Notebook
Acer aspire 5315 with no display
If you are connecting with external monitor, then you have to toggle the display Fn+F5 together, still not getting the display then,
Unplug battery and adapter,
Press and hold the power button for 20 sec
then try to turn on the computer
Nov 26, 2009 | Acer Aspire 5315 Notebook
Sir, i have bought a acer laptop model aspire 5920 but when i was working on it suddenly it shut down and till now i cannot made it power on can you tell me the problem
Remove the battery and the power adapter, wait 5 minutes, plug in the power adapter and try turning it on, if it doesn't turn on, remove the power adapter, plug in the battery and try starting up again, if it still doesn't work plug in the power adapter, try starting up.
Is the power adapter working? does it have a green led on it that shows that its powered?
Sep 10, 2009 | Acer Aspire 5920 Notebook PC
Acer Aspire 3680 laptop. Computer is not getting power
If the power adapter light is not on, even when not connected to the computer, you have a bad power adapter.
You can find additional troubleshooting tips here:
http://www.shopbysystem.com/blog/?p=21
Aug 07, 2009 | UltraLast ULAC3660L For Acer Aspire...
My acer aspire one won't turn on
"Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
The Bios can be found from the Acer site. Source(s): http://macles.blogspot.com/2008/08/acer-aspire-one-bios-recovery.html
Jul 18, 2009 | Acer Aspire One PC Notebook
My acer aspire one zg5 wont turn on
I assume there is something wrong with power supply...Get an electric meter and test the adapter for dc output..I think the bit that connect to the laptop may be worn out and hence losing connection..Try to play with the adapter end when connecting to the laptop and hold on firmly on it and watched if any light comes on.If it stays for more than 2 sec the you know it is faulty..That is an alternate option is you don't have a meter..
Jun 12, 2009 | Acer Aspire 5100 Notebook
Acer Aspire 4315-2490 Notebook Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
