I have a LG 60PC1D-UE.AUSLLJR After it has been off for awhile, like overnight, when it is first turned on I get a horizontal band across the screen for about two thirds of my picture from bottom to top. It stays on for about 5 min. I have replaced the y sus and upper and lower y drive and the large power supply. Still the same. I have a good picture of it that I can send. Suggestions?
  • 1 more comment
  • Patrick McAlexander Jul 20, 2010
    Is this also called the control board?
  • Patrick McAlexander Jul 21, 2010
    There is one other thing that bugs me about this tv. There looks like either trash or maybe even a burnt spot on screen. I see that there is a plastic cover over the screen and a mirrored spot in same location on cover and on screen. There are other random spots over screen. I highly doubt its dirt. Could there be burnt spots on the screen? Whats your idea?
  • Patrick McAlexander Jul 28, 2010
    Thank you. You have been very helpful.
    Genius:
  • 1,112 Answers
Hi:
It is common that when you replace the Y-sus you replace the x sus, especially when dealing with LG, LG also recommends when replacing these board to replace the Digital singnal processing board also. also make sure that before you connect power connectors to the sys boards you measure and adjust the VA and VE and VS voltages to the factory spec's voltage chart that are on the label attached to the panel. Not adjusting these voltages to the correct values could blow the boards or if to low could result in unexpected results.Not to say this is your case but, with my experience with working on LG units we always order all four major boards in the unit. I would be looking at replacing digital board or logic in this case seems you have a thermal problem on one of the boards, but since you already replace several of them and have the same results try replacing the board that is actually responsible of producing the picture on the screen , Logic board assembly. Logic and digital may be one and the same board. GOOD LUCK...
Posted on Jul 20, 2010
  • Lavell Turner
    Lavell Turner Jul 21, 2010
    Yes, but sometimes these boards are seperate, depending on the model and year manufactured.
  • Lavell Turner
    Hi: As to your latest question the spot on the sreen. Plasmas only use glass fronts, there could be a fungus growing between the glass and panel, one way to check is remove the panel from the unit, the front glass will be left in the unit when the panel is remove and clean the two piecies at this point, if the spot does not go away then try contacting LG about a new one either glass or panel which ever one is defective usually the glass, eventho the unit is no longer under warranty as this is a manufacture defect and no fault of the consumer, LG have a tendancy to be willing to listen if pushed hard enough,lol. As for the random spots appearing on the screen, I am thinking you are talking about speckels spots appearing randomly, if so this is due to the VE and VS ,VA voltages set to low, Make sure you measure these voltages and use the trim pots to adjust them out. On the power supply the large white plugs that attached to the Sys boards the plug termainals are labeled on the board, using a ohm meter on dc voltage setting attach ground of meter to panel and positive lead to VE,VS and VA terminals. Look for the corresponding trim pot on the power supply and using a none metalic screwdriver adjust these voltages to the same as labeled on tag attached to the panel. There may be fore voltages to set on LG's as your PS is new, so this needs to be done.
    There also may be ve and vs voltages trim pots on the sys boards also, but on these boards mark the trim pot with a black marker before you attempt to adjust so you do not turn them to far out of tolerance. There is no voltage reading on the sys boards so you will have to watch the screen at the same time while adjusting the pots on the sys board. turn CCW /CW until you just see the random spots disappear.
60PC1D-UE power supply board
What's the question? Have you searched the Internet for one. Try E-bay or, just enter the "60PC1D-UE Power Supply Board" on Google.
Aug 31, 2014 | LG Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Where is the Capacitors?
Good day!!!!
Capacitor is usually found on the power supply board..It is usually connected directly to the power cord..
Thank you for using fixya..
Jan 05, 2012 | LG 60PC1D 60 in. Plasma Television
Rebuilding plasma moduel # 6871QYH053B, three diodes missing!!! need markings on D1 D7 & D12 , Thanks rioconcho
I’m not seeing a direct break down of that 42” Y-Sustain board to see the D1, D7, and D12.\
Look below for the complete diode parts locations, part numbers, and ratings for the 42PC3d-UE.AUSLLJR. That TV has the 6871QYH053B board you asked about.
I hope my information has helped you.
Good Luck.
May 24, 2010 | Televison & Video
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
61" plasam TV will not turn on
This is one of two problems, Bad capacitors in the power supply or your Y Sustain board has failed, I would go for the first, take the back off your tv and look for swollen or domed shaped capacitors on the power supply, They may also leak a brown liquid like substance.
Replace all that you can see and this should cure the fault.
Oct 12, 2009 | LG 60PC1D 60 in. Plasma Television
I have a Dell 17" LCD monitor with a horizontal band.
You would better served replacing monitor you can buy one for about $100-$120 dell if you lie has one for $99
Mar 01, 2018 | Dell Computers & Internet
Unable to receive local channels
According to the manual for the 42LC2D it should be able to receive local channels through a normal analogue antenna connected to the anntenna/cable coax input connector. You can get the manual here http://us.lge.com/download/product/file/1000001586/60PC1D-UE.pdf
Apr 18, 2009 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
154 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
