Question about Pentair Minimax NT Heater
Heater will fire up, but only run for about five minuetes. i changed the pressure switch and fuseable link. no change. turned off power to reboot. came back on for about a minuete then went back off.not the digital. the one with pool and spa nobs.
    Scholar:
  • 78 Answers
Possibly poor water flow. Clean all the baskets, pump too and backwash/clean the filter. If water flow is ok it might be the temperature control. If you are running it on "pool" try using the "spa" control...
Posted on Jul 22, 2010
  • 22 Answers
If it is propane there is likely soot around the exchangers. the pentair heaters all have poor circulation and bad design. cavity is overheating the sensor
Posted on Dec 23, 2010
My kindle fire won;t let me turn pages or change any thing
Soft Reset:
  1. Hold the power switch for twenty seconds. You will need to slide the power switch along and hold it for twenty seconds before releasing it. ...
  2. Your reboot screen should appear when you release the power switch.
  3. Give your device time to reboot for a minute or two.
  4. Turn the Kindle Fire HD back on.
kindle fire Google Search
Nov 30, 2016 | Tablets & eReaders
Why does my 1994 Nissan Pathfinders fuseable link keep blowing?
A fuseable link is a an "inline fuse" that works the same as a traditional fuse. When an excessive amount of current (amps) is detected, it opens to prevent fire or overheating of the wire.
It may be due to chafed insulation on the wire that when contacting body, frame or other grounded metal - causes a brief short circuit - and blows the link. Replacing it is the easy part - finding the cause can be labor intensive.
Feb 24, 2015 | 1994 Nissan Pathfinder
Troubleshooting. AGS
make sure filters are clean check to see if voltage on both sides of pressure switch and both sides of fuseable link also make sure proper gas pressure at unit when turning on does fan come on? does ignitor glow also check all fuses
Oct 04, 2014 | Jandy Pool & Spa
How do i fix my home heater, fired it up, ran for about 3-5 min. But never fired up. Replaced bad pressure switch, n heater venting tubing!
If you have a code indicating pressure switch thid is 50% of the time the barbed port on the induced draft assembly where the pressure switches tubing connects. Carbon builds up in this port requiring reaming, I use a small drill bit and insure I can feel, sense the blower wheel to insure it is clear, it is easy to be fooled as the carbon is tough at times.
If this is not it you have a bad board assuming the pressure switch is closing and opening as it should which can be determined by using an ohmmeter. or voltmeter.
Will it run without the new tubing you installed?
Nov 02, 2013 | Heating & Cooling
Raypak p-r405a PRS message. tried adjusting pressure switch, no change
clean out pump basket, backwash filter for starters. jump the pressure switch if nothing changes. if burners fire then replace the pressure switch
Dec 06, 2012 | Raypak Pool & Spa
I have a 1995 chevy g30 that i have rep[laced disttributor , eck and full tune up still no fire or fuel any suggestions
Are you getting fuel pressure to the throttle body ?
Does the check engine light come on when you turn the key on ?
If you are not getting voltage to the fuel pump and no voltage to the coil I would check the computer to see if it is getting power then proceed in checking the fuses and relays for power. Could be something simple like the key switch or a fuseable link.
Sep 27, 2012 | 1995 Chevrolet G20
I changed the transmission in my 99 oldsmobile intrigue and put the ground wire in the wrong place and when i hooked the battery up n it almost started on fire. now it turns over but doesnt fire
Not to worry your proteced by fuseable links youll have replace it in three area you did the transmission no problem go to the starter there youll see brown connections those have fuseable link you know how to check it it either blows externally ro internally and you visually see it or youll have to pull on it and check if it is open there. youll also need to look in the battery junction box for open fuses. remeber it is protected in three area 1.alternator 2.ignition.3 engine power junction box(the fuses in the engine area)
Apr 29, 2011 | 1999 Oldsmobile Intrigue
Pump starts runs for five seconds and then kicks off will not fire
If you have never checked/changed your filter or checked the pump pressure that is where your problem is. I have a tip which will guide you through the process at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters Let me know if you need any more help. I would advise getting the pressure gauge they have for setting the pump pressure.
hardrocko
Thanks for using FixYa
Feb 20, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heat works fine during the day at night it stops if you run hot water power vent turns on then boiler fires is it the presure swith in the power vent its model ck-92fal thanks ron
Turn on the boiler and jump out the pressure by putting a wire between the 2 electric connections only after the unit fires up than put the jumper on, if it runs ok it is the pressure switch.
Jan 08, 2010 | Calvin Klein The Field Controls Company...
Pentair Minimax NT Heater Logo
404 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
