Question about Toshiba Televison & Video
Toshiba flat screen 27wl46b.No picture only sound.Quick flash of blue when first switched on.
tvtek
  • 1284 Answers
SOURCE: Toshiba Rear Projection Screen Problem
Doesn't sound like a lamp issue to me. Do you see this on all inputs and if not what input do you see it on and what is it connected to?
Posted on Nov 20, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: only getting sound but no picture!
Well, i had a look at the back of that Toshiba TV - make sure that the red, white, and yellow cables are hooked into the Video-1 slot of the Toshiba and that the Toshiba channel is changed to Video 1.
Then check your nameless DVD player and make sure the red, white, and yello cables are all hooked to OUTPUT slots that are in the same column or row - if I had you DVD manufacturer and model #, I could suggest some additional steps to check. Also, make sure your dvd player is in dvd playback mode.
-Tha Mp3 Doctor
Posted on Dec 31, 2008
SOURCE: blue power light flashes No picture on a 37 HDTV/LCD Polaroid -
this might help
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Posted on Jan 17, 2009
  • 187 Answers
SOURCE: LG 42" flat screen 3years.. NO PICTURE NO SOUND.
It could be the mainboard or the powerboard.
You need to check those boards in order to figure it out wich one need to be replaced
Posted on Jul 08, 2009
petraman7
  • 1175 Answers
SOURCE: I have sound but no picture on my toshiba flat screen
Hi...
What are you using for cables to connect to the TV?
Can you try a different one?
Let me know
Posted on Jul 09, 2009
I have a 42" flat screen Toshiba Model 42HL196. The picture won't come on, but the red light flashes 3 times, pauses and flashes 3 times, etc.
Hi Karen, The link below is a YouTube video showing how to fix a Toshiba television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
https://www.youtube.com/watch?v=WtRuUBS9doE
Toshiba 55HT1U repair No Picture
May 03, 2016 | Toshiba Televison & Video
Can't see picture in TOSHIBA LED TV, but still have sound and can see picture with flash light
try changing the back light inverter that's what light the screen some sets have separate back light inverter while some comes in he power supply...good luck
Apr 03, 2015 | Toshiba Televison & Video
42C128135UA-52 Phillips Flat Screen TV. I switched it on and all i got was a clicking sound and flashing green LED light which continues 1 long flash 2 short flashes. No picture whatsoever.
On the lower right side of the psu, (clamped to a heatsink), i changed the 8.5v (L4940P85) voltage regulator and it worked. As a test to single out the fault i warmed this component with a fine blue flame, this would make also make the tv work perfectly.
Aug 29, 2011 | Televison & Video
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Bush lcd tv has sound but no picture when switch on tv screen is blue then goes black and you can hear the proggramme that is on
acoustic solutions lcd tv when i switch it on the screen flashes blue, green then red no picture??? it was working ok last night any ideas?
Jan 23, 2010 | Polaroid FLM-2632 Television
Thomson 40wkw611s - when switched on button flashes green orange and red but no sound or picture- sometimes sound without picture and blue screen
Ur video board have burn parts,the board that connected to the CRT long neck tube.Must trouble shoot replaced parts.or change the whole board.
Dec 11, 2009 | Televison & Video
Toshiba 50HP16 Plasma tv has sound, no picture. Screen is flashing like a camera flash....on-off at random. Volume works with remote. No menu. Screen flickers/flashes. Power light in front is green. TV is...
Display IC seems to have gone. It will be a replaceable module. Only you have to figure out which one it is. Such thing happen in electronics. Look for any burnt or bulged IC.
Oct 07, 2009 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Picture loss after picture begins to flash. blue and yellow light
Most likely the lamp is dying. Try replacing the lamp before calling a repair tech. What does the Owners manual say about the blink lights?
Oct 01, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Screen turning blue now and then on various channels
Picture tube issue. How long have you had it? Call the manufactor.
Jan 03, 2008 | Toshiba MW30G71 30 in. TV/VCR/DVD Combo
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
