I have a Toshiba P200/P205 Series and there isn't any backlight but hooked it up to another monitor and it was fine
  • 86 Answers
The backlight in your screen is out. You can have the screen replaced and your problem should be resolved. If you are confident enough, you can buy the screen and install it yourself.
Posted on Jul 19, 2010
Toshiba Satellite P205-S6267 screen is blank but backlight is on and external monitor out works
Your LCD panel needs to be replaced more than likely. There are plenty of youtube videos if you are a DIYer, otherwise take it to your local computer shop and they should be able to fix it up within a day or two for 50-100 dollars plus the cost of the part. Good luck... you can find all your parts on ebay if you decide to go DIY
Mar 23, 2013 | Toshiba Satellite P205-S7402 Notebook
I have a Toshiba Satellite P205-S6337 that will only show a black screen. I can outboard the video and this works but only in safe mode. The laptop screen has perfect backlighting and no dead pixels so I'm...
QUICK SOLUTION IS
the os with the correct disks 2. Ensure the correct drivers are used 3.request the correct installation disks from the PC manufacturer 4. The blue screen will no longer be an issue as you should not see it anymore
LONG SOLUTION
TRY AN EXTERNAL MONITOR TO SEE IF YOUR MONITOR IS THE PROBLEM. IF IT IS, BE PREPARED TO PAY OUT $125 PLUS FOR A NEW ONE
Jan 25, 2011 | Toshiba Satellite P205-S6337 Notebook
Laptop toshiba satellite p200 bw5 screen goes dark as if darkness/brightness was adjusted - but not Thanks
An LCD screen cannot produce enough light by itself. It needs a Backlight to help illuminate the screen.
Power for the Backlight is produced by an Inverter. An Inverter also provides power for the LCD screen.
It reduces voltage for the Backlight, and increases Voltage for the LCD screen, from the laptop's power.
Most of the time a dark LCD screen can be attributed directly to a bad Inverter. (Around 90 percent)
A Backlight is a CCFL.
Cold Cathode Fluorescent Light.
VERY similar to the fluorescent lights you see used in residential, and commercial applications.
(Homes, and businesses)
Only on a MUCH smaller scale in physical size, and needed power to operate.
When a Backlight goes bad, it just goes all at once. Not goes dark as you have stated.
(Your statement meant to me that you power on the laptop, the LCD screen shows well, then goes dark)
How to install an Inverter in a Toshiba Satellite P200 series laptop,
http://www.irisvista.com/tech/laptops/toshiba-satellite-p205/take-apart-display-panel-1.htm
(You can click on each individual photo to enlarge. You are on Page 1. Page 2 is accessed at the bottom, by clicking on it. Page 1::Page 2::Find another model)
Just one of many places that offers an Inverter for your Satellite P200.
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=5367&zenid=43bc1e775a9ed2d4309140111231cab5
NOTE*
1) ALL power removed from the laptop before beginning.
AC adapter (Charger), and Battery.
2) The screws you will remove, may have screws that look alike, but are NOT.
Do Not mix them up.
For this reason it is suggested to use a multi-compartment container, and label the compartments for where the screws came out of.
You can use a clean egg container, and label the individual egg holders, in a pinch.
IMHO it isn't hard to perform this repair, and you can do it. Save yourself money.
For additional questions regarding this, or comments, please post in a Comment.
Regards,
joecoolvette
Oct 22, 2010 | Computers & Internet
Toshiba satellite p205-s6267 backlight
Your system is consuming much power.
Go to Control Panel, Power Options.
Click "Advanced Power Settings" for your current power plan.
Under the section "What happens when I close the lid", choose "Do nothing" for both "Battery" and "Plugged-in".
Click "Apply" and "Ok".
Now, close the lid of your laptop and open it, it would restore but next time don't overload your system power.
This is common with Dell and Toshiba.
Apr 03, 2010 | Toshiba Satellite P205-S7402 Notebook
I have a Toshiba Satellite p205 s7402. The Lcd backlight quit working suddenly while in use. when you first power it on it briefly (2to 3 seconds) and partially turns on(only one corner) I am not sure how...
sounds like backlight bulbs, not easily replaced pretty much gotta send to manufacturer to replace them. The inverter may be failing but because you still get one is why i believe its the bulbs themselves
Jan 04, 2010 | Toshiba Satellite P205-S7402 Notebook
Toshiba Satellite P200 RT2 won't startup but is holding a charge just fine. Power light, charge indicator, battery indicator appear normal, just nothing on the screen. Please help.
Hook up an external monitor and see if windows loads up, if so it might be a backlight or inverter. if you dont see anything then it might be a hardware failure
Mar 20, 2009 | Toshiba Satellite A135-S2276 Notebook
Need to unlock phoenix bios password for toshiba satellite a135-s4527
remove the keyboard the mobo battery is there you need to unsolder one end of it, lift the leg, and turn it on that way for it to clear.. you will have to resolder once done.. have the skills or find someone that does... and you're set..
Jan 16, 2009 | Computers & Internet
Troubleshooting Toshiba Satellite P205-S6267
is the laptop getting extremely hot on the bottom.
Could be thermal shut down (keeps the cpu from meltdown temperatures)
Robert
Aug 18, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Changing hot keys on laptop
Dullahban,
The key functions along the top of the keyboard can not be changed. They are preset and all of that model function the same.
PAeasop
Apr 24, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Computers & Internet Logo
David Payne
David Payne
