Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Water draining into frig
The water coming from the freezer as it defrosts is draining into the bottom of the frig and into the meat keeper and vegetable bins. It appears that it is not evaporating.
  • Whirlpool Master
  • 43,501 Answers
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Water Running in Refrigerator from Freezerwater  draining into frig - 2_bing.gif
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Jul 19, 2010
Leaking water into the meat compartment of the frig
Frederick,
Sounds like your defrost drain line might be clogged and not allowing the water to drain out properly. I have seen something as small as a tab from a plastic bag get down into the defrost drain line and cause it to stop draining properly. You may have to take apart the back of you freezer section to find where the drain is located and see if you can clear it out. Hope this helps!
Jun 24, 2015 | Refrigerators
Amana fridge model number Arb1914cw is not cooling. Freezer is working fine
Bottom freezer fridges are especially susceptible to
  1. Dust build up on the condenser coil that impedes heat transfer to the outside from inside the box
    • Remove the (bottom) footplate by grasping outside edges and pulling/levering out and popping it free.
    • Use vac crevice attachment and coil brush to clean away all dust from the coil and foot plate.
    • Replace plate and allow 24 hours for inside temp to stabilize.
    • Adjust top temp setting if needed to maintain safe temp level.
    • Repeat semianually or annually as scheduled maintenance--depending on the dustiness is fridge's location.
  2. Airflow blockage through the crispers and meat keepers.
    • Remove crispers and meat keeper as well as glass cover shelf.
    • Find cooling passages between crispers and at midline of meat keeper.
    • Remove any buildup of air blocking debris.
    • Wipe up fridge box floor beneath meat keeper.
    • Reinstall glass shelf, meat keeper, and crispers.
    • Check perodically for poor temperature/moisture keeping in crispers and for water pooling on fridge box floor as signs of blocked air flow through criispers and meat keepers.
Mar 16, 2015 | Amana Refrigerators
The inside of freezer is leaking from back wall - there is no ice maker. water that leaks is freezing and taking up space. what can be causing this
the drain line is clogged causing the ice build up .the frig has to defrost every 6 to 8 hours so every time it defrosts is when it will leak ..you will have to defrost the frig manually ..turn it off. open the doors. let it defrost. remove the thick ice on the bottom ..after its defrosted take the bottom an back panel off.. un plug frig first !! drainline is in the back in the middle of the freezer. unclogg it hot water or shop vac be carefull good luck!! drain line should go to a pan under the frig, in the back make sure it drains before putting back together
Aug 21, 2010 | Estate TT18TKXKQ Top Freezer Refrigerator
Side by side frig/freezer. Freezer auto defrost
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
heatman101
Jul 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Kenmore 25.8 side by side with water freezing in the bottom of th
It sounds like the freezer drain is plugged up. When the frig goes into the defrost stage it melts the frost biuldup on the evaporator and the melted frost goes down a drain that is behind the evaopator cover. When this dran is plugged the water has no place to go and over several defrost cyles will actually run into the bottom of the freezer section. When the defrost cycle is over and the frig starts cooling again, the water freezes in the bottom of the freezer.
Nov 11, 2008 | Kenmore 53642 / 53644 Side by Side...
Freezer cold refrig warm
4 yr old sears side by side...not cold in freeze or frig side
May 21, 2008 | Frigidaire FRS26ZSG
Refrigerator - water liking under the meat drawer
defrost drain stopped up cleanout the drain from the freezer to the drain pan
May 07, 2008 | Jenn-Air JCD2295HES Side by Side...
Amana bottom freezer model #BX21TW purchased in 1996
this particualr refrig is notorious for this. check your controls ( your freezer control as well set to 4 max) any higher and the refrig is running longer, generating more cold then needed, behind the left hand crisper is a few slots( the fresh air return) by default the coldest spot in refrig, i usuallly would reccomend to my cust not to keep high water or thin walled vegies in there such as carrots cukes tom and lettuce, perfect beer and fresh /frozen defrosting meat to be though, if you ever looked at the newest bottom freezers they've pushed up the drawers and added a deli pantry, running the width of frig
Feb 27, 2008 | Refrigerators
Duct from freezer to frig is blocked with ice, frig warm
give the unit a full defrost then unblock the drain hole. it sounds like the tiny defrost heater element may not be working and is therefore causing excess frost to build up on the freezer evaporator. also check door seals are not holled anywhere.
May 31, 2007 | Hotpoint HTR15BBMRWW / HTR15BBMRAA /...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
632 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
