Question about Refrigerators
Refridgerator power went ou fort a couple of hours yesterday and by the time it came back on the fridge was totally defrosted and now the fridge won't event get cold at all the fan under the fridge is blowing but the freezer fan is not on
    Genius:
  • 1,073 Answers
Check the compressor overload relay it has been taken out by the loss of power and the power being brough back on line
Posted on Apr 21, 2008
Freezer defrosts all the time
The defrost timer is faulty
Jan 16, 2014 | Refrigerators
Royal dometic. not sure year or model. started cooling several days after power connected..auto defrost kicked in second time there was frost buildup and now neither fridge or freezer will get cold..have...
When you feel cooling unit from outside behind cover and unit is on for a couple of hours min, does it feel warm, hot? describe any other things you notice please.
Apr 09, 2013 | Refrigerators
My refridgerator is not cold enough even though i adjusted the temperature
Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 4 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Jan 31, 2011 | GE Refrigerators
The refridgerator is not staying cold. The
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Mar 06, 2010 | Refrigerators
Fridge not cooling
In the freezer compartment on the back wall there is a panel , behind that panel is the evaporator coil and return air ducts that go up to the fridge.
these ducts freeze up, thus not allowing the cold air to circulate to the refridgerator. You can unplug the unit overnight and let it defrost on its own, or you can help it using a blowdryer for a couple of hours. just lay the blowdryer in the freezer area with the doors open and let it defrost.be sure to place an old towel on the bottom to catch the water.
Jan 16, 2010 | Zanussi ZI918 / 12K Bottom Freezer...
Freezer works great, as it should, but fridge is only keeping items room temp. I have the setting at the coldest setting: #7. What is wrong?
Here's what I did, I defrosted! I found out that the fridge temp is monitored and maintained by the freezer. Because we had a power outage one night, my freezer thawed while we all slept and then when power came back on, freezer re-froze but this cause an ice build up on the vent on the back wall of the freezer. Well, ice must have been in one (or more) vents, causing blocked air flow in my top half of the refrigerator. I turned the dial in the freezer to "off" which also shuts down power to the fridge half. I then unplugged the refrigerator, hauled all my food items into coolers, opened the freezer door and refrigerator doors and left them open for a little over six hours. I took advantage of this empty fridge and freezer and wiped everything down. After this time frame passed, I plugged the fridge back in, turned the freezer dial to my preferred freezer temp, and wah-lah! Within two hours I had a cold fridge and solid ice cubes in the freezer. I then put all my food items back into their appropriate compartments, and went to work. Bear in mind, a total 24-hour period is needed for the fridge to re-set itself, but still, after two hours the fridge was noticeably cold. Who knew, besides our parents' generation: DEFROST!
Sep 10, 2008 | Maytag MBB1954G Bottom Freezer...
Power went out for a couple of hours yesterday and when it came back on the fridge was totally defrosted and now the fridge won't get cold at all
If it doesn't fix itself in a couple of hours, the defrost timer may be stuck on (defrost) can you give it a partial turn? (located at bottom of fridge near floor, has about 5 wires - size of pack of cigarettes. Let me know?
Apr 21, 2008 | Refrigerators
Kenmore refridgerator c1065094881
It sounds like your defrost cycle has stopped working. unplug your fridge for 24 hours and let it defrost. plug it back after 24 hour and if it starts to cool in the fridge part at about 40 degrees F. you will have to replace one of three parts the Defrost Timer, Defrost Themo or Defrost Element. I hope this helps you.
Dec 22, 2007 | Refrigerators
Tempature on fridge won't stay @ 38
might be freezing on the evaporator faulty defrost timer or drain is blocked water should run down back bottom tray
May 10, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
99 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
