I would like to run my tascam CD-GT guitar trainer through the speakers. Does the aux. speaker inputs above the antena connections have volume control through the stereo?
  • gargoyle055 Apr 21, 2008
    I'm going to go to radio shack and find the right kind of splitter. thank you for the info!
  • 100 Answers
Hi Gargoyle005,
Most Aux jacks have a base level, other then adjusting the level on the trainer your would have to control the volume with the standard volume controls.
Go Ahead. Use Us.
Posted on Apr 21, 2008
How do you get audio to play through a receiver? We have the TV running to input on receiver and no sound?!?!
You have to go thru the menus on the TV and tell it you want TV speakers off, and output to surround at fixed volume. Then plug audio out wires (RCA jacks or optical digital wire) from audio outs on TV to AUX or Video or something like that into the receiver.
Jan 21, 2015 | Insignia IS-LCDTV32 32 in. Television
Tascam GA-30CD will output sound through the headphones, but I cannot get it to output through the speakers, after the headphones are removed. How do I get sound through the speakers? Thank...
A common problem is that the switch contacts on the headphone jack that send the audio to the speaker when headphones are unplugged go bad. Some of these are so low quality that after a few times of inserting a plug the contacts no longer make. If you can access the jack, you might find a jack similar to:
What happens is the spring tension on the tabs over the top of this that contact the leads to the speaker lose tension and no longer press hard enough on the contacts to make contact. Try to open your unit and see if it has this kind of jack... Frankly, these jacks are JUNK and a chronic problem.
Sep 17, 2011 | Tascam Ga30cd Guitar Amplifier with CD...
Do not know how to connect my kappa 60.5cs to my pioneer cd player do they have to go through an external amp?what do i do with the power plugs on the oppisite side why are there 2 per speaker
You need to run RCA cables from the CD player to the CD or AUX input on your amp / receiver unit. If you have a standalone amp, you need some way to control the volume. Basically, if you have a volume control on the front of your amp, you're OK. If not, you should also have a preamplifier that the CD player feeds first.
From the amplifier, then, a single pair of speaker outputs feeds a single pair of inputs on your speakers. The reason for two jack sets on the speakers is for "bi-wiring" or "bi-amping", not necessary for basic stereo reproduction.
So -
CD red/white RCA out -> preamp/receiver red/white CD/AUX input. Amp speaker output (red + / black -) to one red/black input pair on the speakers. An input on the speaker is side by side...
Keep the red to red, black to black when connecting the speakers, or you will wind up with poor sound and weak bass.
Jan 18, 2011 | Infinity US-1 Main / Stereo Speaker
Tascam CD Gt1mkii CD Guitar Trainer - skipping around quite a lot, on any cd .unusable. can it be fixed easily and cheaply?
VERY carefully clean the lens with a QTip and 99% isoprophyl alcohol. Use ONLY 99% and it can be a bit hard to find.
Be careful to NOT snag the QTip cotton on the carriage or parts holding the lens... clean ONLY the lens, very gently. Let dry thouroughly before trying it again.
Sep 28, 2010 | Tascam CD Gt1mkii CD Guitar Trainer
Hi,you can try out if only the BT CD TRAINER has input and output jack space. So if it doesn't, you will not be able to use it.
Take care.
Jun 11, 2010 | Tascam Cd-bt2 Bass Trainer & Portable Cd...
My Tascam CD GT1 mkii guitar trainer is doing everything except when I plug my guitar into the unit, I can not hear my guitar?
Here is the manual if you don't have one:;9,21,23,19.html Make sure your guitar cord is working. Make sure your are plugged into the Guitar/Mike input jack.Do not connect a guitar amp to this jack via line out on the amp or otherwise. Set the Guitar/Mike switch to Guitar. Use the Input control to adjust the level of the input.Adjust your Headphone level using the Output control.Carefully read pages 12, 13, 14 and 15 of the manual.There are various combinations of controls that would make your guitar too quiet to be heard. Example: Mix Balance page 24. Let me know if this helps.
Nov 29, 2009 | Tascam CD Gt1mkii CD Guitar Trainer
No manual for the above as i lost it can anyone help
Look under the resources tab and you will be able to download the manual at:;9,21,23,19.html
Aug 18, 2009 | Tascam CD Gt1mkii CD Guitar Trainer
Aux in runs only back speakers and no volume control
check sub setting some radios can select between non fading sub output or aux input
May 08, 2009 | Pioneer DEH-P3000 CD Player
I've just got a tascam dp01cf recorder and i'm having trouble with it, its abit hard to understand what to plugs in were, i'm using a electric guitar,a yamaha magicstomp effect pedal and a amp. also i'm...
You have a couple of options with your guitar input. You can either plug your guitar directly into the right (Hi-Z) input and use the Tascam's onboard effects with it instead of your effect pedal.
You can put your pedal in the chain between your guitar and the (Hi-Z) input. So guitar into pedal is, pedal out into Tascam Hi-z in. (Still doesn't use the amp).
Or my preferred method for recording guitar would be to mic the amp. In that case you'd just input a microphone (placed about 8-12 inches from your amp) and record your guitar that way. The mic would be plugged into either one of the Tascams two mic inputs to record the amps speaker output while your guitar, pedal and amp would just be hooked up in the normal way.
Please note: Never plug the output from an amp into any of the Tascams inputs. Those inputs are line-level and the speaker output level which comes out of an amp out would damage your Tascam.
To get a backing song into a track in your Tascam, you'll have to first, using a PC, get the song into a 16 bit mono Wav file format. Then you'll have to use the USB import function to copy that wav file onto your Tascam onto the CF media cards fat partition. From the you'll be able to import it into the Tascam choosing which track it will import into.
Apr 17, 2008 | Tascam 2488 Portastudio Multitrack...
