Question about Canon Cameras
Lens error,camera restart,it appears on my camera and it automatically shut off
  • 360 Answers
Hi, The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Take care
Posted on Jul 19, 2010
How to fix Powershot Elph 530S so that the lens retract all the way when powering off
From the way you describe the problem it appears that the retraction mechanism has become out of line. I think that as you can hear a clicking sound the mechanism is working but not engaging with the lens. Try gently applying slight pressure on the front of the lens this may help to re-engage. You may need to consider a trip to the repair shop.
Jul 11, 2014 | Canon PowerShot Cameras
Getting message "Lens error. Will shut down
Welcome to FixYa.
Getting message of "Lens error" occur if you hold the lens while it is in motion or when using it in a location with excessive dust or sand in the air.
If this error continues to appear, contact a Canon Customer Support Help Desk as there may be a problem with the lens.
I hope this information will help your issue on your camera,
Thank you for using FixYa.
Apr 05, 2011 | Canon PowerShot A490 Digital Camera
Lens malfunction, "Lens error, restart
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 27, 2010 | Canon PowerShot S5 IS Digital Camera
Lens error, restart camera.
I had the same problem with my powershot and with the batteries going bad super fast. The way to fix it is to empty your memory card of all pictures then put it back in the camera blank. That should take care of the problem and should pro;long your battery life as well.
Aug 25, 2009 | Canon PowerShot A710 IS Digital Camera
Lens Error. Restart Camera. Camera gives this error message and then shuts off. I can't access photos or function buttons. What can I do?
Press the "MENU" button and navigate to the reset command and reset the camera. That may get the camera to function properly.
May 10, 2009 | Canon PowerShot SD1000 Digital Camera
Lens error
Hey Wiggs12485,
This error message appears when the camera detects a problem with the lens when it's turned on. This is often caused by the user pressing on the lens when it is trying to extend, or the camera is being used in a dusty or sandy environment. When this message appears turn the camera off and back on, and this should resolve your issue. If this message continues to appear you should have the camera looked at by an authorized service technician because there is probably a problem with the lens.
Sincerely,
Allan
Go Ahead. Use Us.
May 04, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Cameras Logo
155 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
