Shredder doesn't turn off on the "auto" setting once the paper is through .. it is not full or jammed
  • 86 Answers
You should have a photo sensor directly in the center of the mouth of the machine. There is two parts to the photo cell. sender and receiver. Canned air is your friend for this problem. The photocell parts are little round parts upper and lower. You should be able to see them in the center where you insert your paper to shred.Paper dust can get on them causing to run continuously.It thinks your shredding and paper is blocking the photocell. To fix problem blow out with canned air using the straw included with the can of air. Hope this Helps. give me a good vote if so. thanks have a nice day.
Posted on Aug 04, 2010
Runs reverse auto
From your manual!
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the waste basket; insert waste basket and repeat jam clearing procedure.
Feb 01, 2014 | Fellowes DM12C Shredder
Can not get paper to shred
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Oct 26, 2013 | Omnitech Office Equipment & Supplies
No power. Seems to be overloaded
Oct 25, 2013 | Office Depot Ativa DSD160D Shredder
Wont turn on
Oct 01, 2013 | Cross Infoguard Shredder SX102M
I jammed it with too much paper
Sep 17, 2013 | Fellowes W10C Cross-Cut Paper Shredder
The shredder is totally inoperable
Sep 17, 2013 | HSM Office Equipment & Supplies
Red light and green light on but motor will not come on
Sep 13, 2013 | Fellowes PS60-2 Shredder
The shredder doesn't automatically shred anymore. How do I set it so the "eye" works and it shreds automatically without me holding down the button?
Sep 04, 2013 | Quartet gbc 5550X Shredder
Shredder stoppped working, no display or power when restarted. Power cable is good.
Aug 07, 2013 | Universal Office Equipment & Supplies
My fellows jbo1 jamed and then stopped running is there a reset buton?
Chances are it's over heated.
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
Dec 15, 2010 | Fellowes Office Equipment & Supplies
111 people viewed this question
k24674
Marvin
Marvin
