Question about GE Security Simon 3 Wireless Home Security System
One of my sensor stopped communicating w/ the panel (sensor failure), how do I reprogrammed my sensor so the panel will communicate w/ it?
    New Friend:
  • 74 Answers
You either have a bad battery in the transmitter or a bad transmitter. If you replace the battery and it fixes the problem you are fine. If the battery doesn't fix the problem you will need to replace the transmitter.
Posted on Aug 23, 2010
Adt wants 500+ dollars to repair phone communication failure and defective sensor(warranty) and add seccond key pad and 2 more window sensors in same service call. any way to get parts and leave adt
Communication failure will clear itself once your phone lines are restored. Try arming your system and opening a door to set the alarm off, a forced signal will usually clear a communication failure. As far as parts, you can get them pretty cheaply from a local Alarm Company or dealer. Give them a call, most local, small dealers are fair and helpful. Easy to install yourself as well.
Nov 19, 2010 | GE Home Security
Tip
CANON iR2016/2020 ERROR CODES
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540
0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542
0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744
0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
E808 0000 Fixing drive circuit failure
on Aug 03, 2010 | Office Equipment & Supplies
P0601 diagnostic code what is the mean , or whats is the problem
P0601 - Internal Control Module Memory Check Sum Error
Basically that means that there is an interal fault in the Powertrain Control Module (PCM). There have been many reported PCM failures on Chrysler/Dodge products although it is possible for this to happen on any vehicle. In Dodge/Chrysler products, a P0601 trouble code means that a serial communication failed inside the computer at least 6 times.
Symptoms: Likely, no symptoms will be discernible to the driver, other than the illuminated Check Engine Light. Typically the engine runs fine, gauges work, etc.
Causes: A code P0601 in most cases means the PCM has gone bad. This is possibly due to a short-circuit inside the PCM. Or, if you disconnect the wires/connector from the PCM while the battery is still connected, that may also cause this code.
Possible Solutions: With a P0601 OBD-II trouble code, the most common fix is to replace and reprogram the PCM. In a few cases the dealer may be able to reflash the PCM and get it working. But more than likely the PCM will need to be replaced and reprogrammed (we recommend you take it to a dealership for this). The good news is it *may* be covered under your emmissions warranty. So even if you're out of bumper-to-bumper warranty or powertrain warranty, check your warranty guide or dealer to see if this is covered.
Other people have reported that they cleared the code only for it to return again and again. Keep in mind that most shops can replace the PCM but not all can program it.
Other PCM / ECM Codes: P0602, P0603, P0604, P0605, P0606, P0607, P0608, P0609, P0610.
Hope this help to solve it (remember rated this).
Aug 03, 2010 | 2001 Dodge Stratus
Where can i get the codes canon ir 2016 series.
Hi, here you go:
E540
E542
E744
0002
0003
0004
Jul 16, 2010 | Canon Office Equipment & Supplies
I want to find out what a report suspended error 0008 is and how i can get rid of it. Canon photocopier 2018i
ARE YOU SURE THAT IS E008?
hERE ARE THE ERROR CODES FOR 2018
E196 0001 Error on writing and readout ROM of image processor PCB (main ROM).
0002 Error on writing and readout ROM of image processor PCB (option ROM).
E261 0000 Zero-cross signal error
E540
E542
E730 0000 Inside error of the image processor PCB (PDL system error)
E744
0002
0003
0004
Sep 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Hello, I just purchased a GE SImon XT system with two motion detectors and a smoke/temperature increase detector. I live in a very small house and don't need more. Everything is hooked up and works...
Clarence,
If the problem is the Communication Failure, try to reprogram the Home Security System. The codes that you need are indicated in the user's manual. If reprogramming the Simon would not resolve the problem, try to get the master code from the manufacturer.
Reprogramming the device should resolves the issue.
Aug 25, 2009 | GE Security Simon 3 Wireless Home Security...
Download standby error
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i Код ошибки Субкод Описание E000 0000 Fixing temperature abnormal rise E001 0000 Fixing unit temperature rise detection (by main thermistor) 0001 Fixing unit temperature rise detection (by sub thermistor) E002 0000 Fixing unit temperature insufficient rise E003 0000 Low fixing temperature detection after standby (by main thermistor) 0001 Low fixing temperature detection after standby (by sub thermistor) E007 0000 Fixing film rotation error E010 0000 Main motor rotation error E019 0001 Waste toner full detection 0002 Waster toner full detection sensor failure E052 0000 Duplex unit connection error E100 0000 BD cycle out of range E197 0000 Erroneous communication with printer engine E500 0001 Finisher communication error E520 0000 Offset error E531 0000 Stapling error E540 0001 Paper surface not detected (standard tray) 0002 Not moved within the specified time (standard tray) 0003 Sensor not reached within 3 seconds (standard tray) 0005 Encoder clock failure (standard tray) E542 0001 Paper surface not detected (optional tray) 0002 Not moved within the specified time (optional tray) 0003 Sensor not reached within 3 seconds (optional tray) 0005 Encoder clock failure (optional tray) E575 0000 Stack delivery error E584 0000 Shutter failure E716 0000 Erroneous communication with optional cassette E719 0000 Erroneous communication with card reader (serial communication) 0002 Erroneous communication with coin vender (serial communication) E733 0000 Erroneous communication between controller and printer E736 0000 CCU communication error E739 0000 Erroneous communication between controller and network board E744 0001 Language file/boot ROM/USB memory error 0002 0003 0004 E805 0000 Fan failure E808 0000 Fixing drive circuit failure
Apr 10, 2009 | Office Equipment & Supplies
Canon IR2018 E007
E007 Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film
sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
you need to call a canon technician to sort it out
Mar 22, 2009 | Toshiba e-Studio162D Copier
System error E808
0002
0003
0004
Mar 22, 2009 | Canon CLC 1140 Copier
Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Feb 08, 2007 | Kodak i640 Path-Through Scanner
GE Security Simon 3 Wireless Home Security System Logo
733 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Michael Galve
Michael Galve
Are you a GE Home Security Expert? Answer questions, earn points and help others
