Question about HP Photosmart C6180 All-In-One InkJet Printer
The printer light does not come on causing printer
    President:
  • 2,571 Answers
If it does not come on at all.
Either its not plugged in, the fuse has blown in the plug, the lead/power adapter is faulty.
If this is not what you meant, please give some more information
Posted on Jul 19, 2010
Printer blinking red and showing letter E
Error description:
The Attention (red) light is blinking. There are six possible causes that will display the Attention light pattern:
-Paper out
-Door open
-Print cartridge missing
-Paper jam
-Paper sensor jammed
-Duplexer error
Solution :
After the cause of the problem has been addressed, pressing GO will cause the printer to attempt to recover from the cause of the error. If the printer is unsuccessful, it will continue to display the Attention message until the cause is remedied.
Pressing JOB CANCEL will cancel the print job and the printer will return to the Ready state (Ready light on) unless there is a paper jam still in the printer or the print cartridge is not in the printer.
For more details visit the link below :
Resolve Printer issue
Jun 09, 2011 | HP DeskJet F380 All-In-One Printer
Flashing red lights on printer
From my personal experience, there are several things that can cause the, i.e. a damaged head, a bad motor (any bad motor) or a cracked ribbon cable all cause the red flashing lights error.
You can download the Document from the below link to troubleshoot the issue:
http://www.ziddu.com/download/4138471/R1800.rar.html
Feb 27, 2011 | Epson Stylus Photo R1800 InkJet Printer
Amber light just keeps flashing on HP2200 printer
This can be a number of problems but mostly caused by a worn paper pickup roller. If you turn the printer off and then back on, does the light come on before any job is sent to it?
If this is the case it could be caused by a dislodged paper sensor, possibly in the fuser area ( rear of printer ) or even the one under the printer at the front near the paper pickup roller.
Dec 09, 2009 | HP LaserJet 2200D Printer
My printer is not printing..page comes out blank. inside, all the lights are flashing on the ink cartridges...any ideas what's wrong? thanks
this message means that the cartdriges are empty...
if you have bought new cardridges and lights still flash then the printer just dont recognize them right.
possible cause 1:
dirty cartdrige (or printhead) chip contacts > clean them with alcohol and cotton (switch printer off first).
see the chips in this photo:
https://secure.datatekusa.com/images/canon%20PGI5.CLI8%20refillable%20cartridge.jpg
possible cause 2:
bad printer controller: the chip in the printer that communicates with the cartdriges is gone mad... take the printer to service...
all the above are valid assuming you bought original cartdriges if not then do so...
Sep 03, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
On/off light keeps flashing green and will not print.
Your problem can be caused by a couple of things.....paper jam, printer cover open,etc...
But have no fear below is a link to figure out what is causing this problem and the solution to fix it....
Blinking Lights
Apr 27, 2009 | HP DeskJet 3520 InkJet Printer
Flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Mar 03, 2009 | HP DeskJet 3520 InkJet Printer
Not printing
Yes, this would cause it to not work - try taking out your toner cartridge, shake it lightly a couple of times, and then put it back in. This should work for a short while, until you get a new cartridge
Feb 11, 2009 | Brother HL-2040 Laser Printer
Blinking red error button
Blinking light can be caused by a multitude of problems, but in most cases it is caused by the little white switch that you see when you open the printer lid to install paper. Has to be replaced by a printer technician who can get the part from star micronics. Another cause is bad cutter or paper out switch located under lid at the back of printer in which the paper pushes the switch into the side of the printer. None of these problems can be solved by an end user.
Jan 15, 2009 | Star Micronics TSP600 Thermal Printer
Ink cartridge light is blinking, I replaced the #45 ink cartridge
What's the printer's model. The print heads may need to be cleaned.
Dec 28, 2008 | HP DeskJet 6122 InkJet Printer
Not printing
Hi ,
There may be several causes for this problem.
I will tell you one by one, and you try it.
CAUSE: 1
The printer is not
receiving power.
SOLUTION:1
Check the power cord connections.
Check the power switch and the
power source.
CAUSE:2
The printer is not
selected as the
default printer.
SOLUTION:2
Select Xerox Phaser 6110
Series as your default printer.
CAUSE:3
Check the printer for
the following:
• The printer cover is
not closed.
• Paper is jammed.
• No paper is loaded.
• A toner cartridge is
not installed.
SOLUTION:3
After locating the problem, clear it.
If a printer system error occurs,
contact your service representative.
• Clear the paper jam.
• Load paper.
• Install the toner cartridge.
CAUSE:4
The printer may be in
manual feed mode
and out of paper.
SOLUTION:4
Check the message on the Status
Monitor program window, add paper
to the tray and press the
button on the control panel.
CAUSE:5
The connection cable
between the
computer and the
printer is not
connected properly.
SOLUTION:5
Disconnect the printer cable and
reconnect it.
CAUSE:6
between the
computer and the
printer is defective.
SOLUTION:6
If possible, attach the cable to
another computer that is working
properly and try to print a
document. You can also try using a
different printer cable.
CAUSE:7
The port setting is
incorrect.
SOLUTION:7
Check the Windows printer setting
to make sure that the print job is
sent to the correct port. If the
computer has more than one port,
make sure that the printer is
attached to the correct one.
CAUSE:8
The printer may be
configured
incorrectly.
SOLUTION:8
Check the printer properties to
ensure that all of the print settings
are correct.
If u still cant find the remedy, go for the support from XEROX,
www.office.xerox.com/printers/color-printers/phaser-6110/serv-enus.html
Hope my info solves your problem,
Thanx for using fixya.
Oct 01, 2008 | Xerox Phaser 7760/YDX Laser Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
55 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
