Question about Sharper Image Wireless Caller ID with Atomic Alarm Clock (CH002)
My sharp atomic clock has stopped working- changed
No readout on the screen
How can I stop the Samsung gusto 3 from reading numbers of incoming calls.
I believe one of the Accessibility Readout options is enabled. From the home screen, press the Left soft key. Select Menu, then Settings. Go to Accessibility and then Easy-Setup. Check that the following are off: Full Readout, Digit Dial Readout, Alert Readout. (Alternatively, you can look at each of these individually from the Accessibility menu.) There may be other options to check in the Readout options but these seem the most likely.
I hope this helps.
Dec 21, 2017 | Samsung Cell Phones
How to reset allreadouts such as trip miles and all that can be reset
There should be two buttons associated with your readouts, NORMALLY one will change the readout, trip miles, fuel usage, etc, the other is normally for changing from imperal to metric (miles to kilometers) on MOST vehicles if you put it on the trip miles screen and hold down both buttons for a few seconds it will reset, some vehicles will even beep to let you know that you have reset your readouts.
Apr 07, 2015 | 2005 Chevrolet Blazer
WHAT DOES THE READOUT =BASE= MEAN
Remote handsets must be synchronized with the base unit. The remote charging stand will not perform this function. If the handset goes dead or the battery disconnected and reconnected, you must return the handset to the base unit and cradle it so it can be identified and synchronized to the base unit.
Mar 06, 2015 | Lands Phones
I have Canon MP520, the screen has backlighting but no info, what is the fix please
Turn off printer.
Close readout cover.
Unplug printer. Wait at least 5 minutes.
Plug back in printer
Open readout cover
Turn printer on
This will reset the printer
If this does not work, try turn off printer
Open and close the readout cover slowly couple of times
Turn printer back on
If still does not work, try a different outlet
the voltage could be low.
Dec 26, 2010 | Canon PIXMA MP520 InkJet Printer
Radio LCD readout
the LCD is back-lighted by a tiny bulb inside the radio chassis, pull the radio out, remove the sheet metal top cover, you will see a small twist in/out bulb socket at the rear of the radio display screen, remove it, take the bulb to a good full service parts store like NAPA or the dealer, the bulb is about $2.
Jan 07, 2009 | 1997 Jeep Grand Cherokee
Screen Readout
yes screen readout is bad... u need a new screen
May 01, 2008 | SanDisk Sansa E280 MP3 Player
RNGOFF KX-T7630
press the button below the readout "rngoff", let go, then rotate the volume control dial. It should raise the volume. The readout will now say "ring"
Jan 11, 2008 | Panasonic KX-T7630 Corded Phone
Display stopped working
My Alpine CDA-7842 works fine from a functional point of view but the display (readout) had stopped working. All the lights on the display work but the actual readout is blank. At first the readout would intermittently work now it's completely dead. Any assistance would be greatly appreciated.
thanks
Oct 26, 2006 | Alpine CDA-7842
Sharper Image Wireless Caller ID with Atomic Alarm Clock (CH002) Logo
147 people viewed this question
Top Sharper Image Audio Players & Recorders Experts
woodzowl307
Tom Chichester
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
