Question about Sport & Outdoor - Others
I have an fn-10151 adjustable rowing machine but unsure how to adjust the tension
SOURCE: skipping stitches
Rule of thumb: Fast needle, slow hands. This should help. GiGi
Posted on Mar 15, 2009
kent581
  • 87 Answers
SOURCE: Bobbin tension on Viking 350 Sewing Machine
Viking bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Posted on Mar 19, 2009
Mimito7
  • 128 Answers
SOURCE: Top tension adjustment
Believe it or not, most computerized machines have an automatic tension. This works well providing, the thread is thru the tension wheel setup.
But for further reference,
loops on the bottom-- problem on the top.
loops on the top--problem on the bottom.
Mimi
Posted on Apr 24, 2009
  • 255 Answers
SOURCE: sewing machine tension
Hi. The upper tension is too loose (even tho it looks ok). If the upper thread is too loose, it can't pull the bobbin thread up to properly form the stitch and you get those messy 'birds nest' on the bottom side of the fabric. I posted a Tip on Adjusting Tension--read that and adjust your upper tension.
Thanks!
Robbie
Posted on Aug 02, 2010
Testimonial: "Thanks! That does help. Now I'll have to find your tip on Adjusting Tension =)"
hazelgrace
  • 340 Answers
SOURCE: how to adjust tension on Toyota RS 2000 sewing machine (CB series
Hi
I found a free manual and parts for my Toyota 9090 on this site. http://www.aisin.fr/index3.php?language=en
The only problem is that the manual is in French but some are also available in English. I found it useful for the diagrams etc.
Try the online guides as well as they give help on adjusting tension, replacing bobbins and needles etc.
Posted on Aug 23, 2010
Tension - I am getting a loopy bottom row and a straight top row of stitching when using a slightly thicker thread. If I adjust the tension on the wheel the thread just snaps.
If when tightening the upper tension the thread breaks it is likely the needle is two small.
Try sewing same setup with a very light fabric. The weight of the fabric can also require a larger needle to provide for a channel to allow the tension to pull the thread up. Check that the thread is properly routed through the tension mechanism.
26255548-krhgav1oaptdc4xjlkggf2tf-3-2.png Confirm that the needle is installed correctly.
26255548-krhgav1oaptdc4xjlkggf2tf-3-9.jpg Hope this helps?
Aug 09, 2016 | Sewing Machines
Precor rowing 612
any hardware store should have that wingnut..
Jan 15, 2014 | Exercise & Fitness
Tension on magnetic rowing machine
magnets get stronger the closer they are to the metal
undo the tension knob all the way out
it may be broken off the magnet in which case it will always be close to the metal
Apr 18, 2017 | Exercise & Fitness
I want to be able to hem knit fabric using a twin needle. I always wind up with a hill forming between to two rows of stitching. Is there a way to adjust the bobbin tension to reduce this hill...
Never mess with the bobin tension, just make an adjustment to your stitch length, I suspect the stitch length is set for small stitch, try it on #3
Aug 15, 2010 | Husqvarna Designer I
I am having problems with the tension adjuster on Kettler favorit on the left arm. Every time I adjust the tension to increase it, the tension grip slips back to the original lower position so I get an...
The tension adjusting mechanism in all intensive purposes has worn out and will need to be replaced. Since I don't know where it was purchased either in USA , Canada or the U.K.
aftersales@kettler.co.uk
Tel: 01527 591901
KETTLER® USA 1355 London Bridge Rd Virginia Beach, VA 23453 USA
Phone # 757.427.2400 Fax# 757.427.0183 e:mail:info@kettlerusa.com
KETTLER® CANADA PO BOX 171 HASTINGS, ON K0L 1Y0 CANADA
Phone # 613.475.3300 Fax# 613.475.3395 e:mail:murray@kettlercanada.com
Jun 12, 2010 | Kettler Favorit Rower
How do you adjust the screen brightness ?
It is at a press of some combination of buttons.
For brightness up:- fn (low row to the left beside ctrl) and For brightness down:- f7 (function key) top row.
Good luck and rate this.
Dec 26, 2009 | HP Pavilion ze4300 Notebook
Slack in line on rowing machine
extend the line to its max required length while you are sitting on the machine { as using } then get someone else to adjust the slack on the line and make it taught , the adjustment should be a bolt and nut type located on the main wheel . do not adjust the line from the seat as this may dislodge the seat . happy rowing
May 06, 2009 | Kettler Coach Rowing Machine
Thread breaks off
Where does it break? You change tension at the top via the tension discs the thread passed through, and at the bottom by adjusting the small screw on the bobbin case - the screw on the front part of the spring. Thread size matters as well as needle size. For everyday upholstery I use #69 nylon thread, and "G" bobbins.
If the thread's breaking at the hook you may need to adjust timing. But most commonly thread breaks because of improper tension, threading, needle or thread size.
Mar 22, 2009 | Consew 226R-1
Skipping stitches
Feb 19, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Sport & Outdoor - Others Logo
63 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
