Question about Maytag Bravos MTW6600T Top Load Washer
Describe your maytag washer MTW5870TW how toProblem how to remove timer from control panel
4 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: Maytag top loader MAV 8000MWW
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Checkto see whether power is getting to the washing machine. Is it pluggedin? Has a fuse blown or is a circuit breaker tripped?
Lid switch Ifthe lid switch is defective, your washer can't spin and may notfunction at all. The switch is inside the washing machine main housingnear the door frame. Often you have to raise or open the top or frontof the washer to get to the switch. If it's defective, you need toreplace it.
Some machines have a special lid-switch fuse nearthe lid switch, inside the control panel. If this fuse blows, the unitwon't fill with water until you replace the fuse.
Posted on Sep 27, 2008
Maytag317
  • 1136 Answers
SOURCE: Top loading maytag washer leaking water during wash cycle
Hi, There are two spring clips located in the gap between the top and front panel. They are the edges.
If the pump and hoses aare ok, fill the washer with water and look up toward the center of the tub abd transmission area. It migth have a seal going bad.
I hope this helps.
Vic
Posted on May 30, 2009
appliancexch
  • 448 Answers
SOURCE: MTW5870TW matag washer
Putty knife front of control panelbetween top of washer and control console (plastic) metal clips need pushed in twards back of unit top will hinge back they may spring off so watch wear they fly
Posted on Apr 28, 2010
Testimonial: "great help---thanks"
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Apr 28, 2010 | Maytag Bravos MTW6600T Top Load Washer
Maytag washer mtw5870tw , washer works but i have to manually click it out of the wash cycle-- timer , timer motor??
Yes, generally they both come as an assembly together. I reccommend change the timer assembly.
Mar 15, 2010 | Washing Machines
Switch on washer stops at rinse. I have to twist to spin for it to spin. What might be the problem
It would appear that your timer is faulty and needs to be replaced.
Typically when a timer starts to wear out, over time, the plastic steps that are part of the timing sequence can wear down and cause the washer to malfunction.
If you can hear the time motor running but it doesn't ever go into the rinse cycle, then it is most likely the timer motor that is the issue.
If you want to get an idea of the cost for obtaining a replacement timer, you can go to www.searspartsdirect.com and enter in your complete washer model number into their parts search and then select the "control" link to see a line drawing and parts list for your washer.
Since you didn't provide a model number for your washer, I'll give you the generic instructions for doing the replacement. Again, with the sears link above, you'll be able to see the location and mounting method of the timer on your washer.
This is an easy repair for anyone to undertake, just be sure to unplug the washer from the power outlet before you attempt it. First, remove the timer knob from the front of the washer simply by pulling it straight off. then with either a socket wrench or nut driver, remove the nut and lock washer that holds the timer onto the panel.
Now remove the screws on the backside of the control panel so you can get at the timer. remove any mounting screws/hardware that holds the timer on the panel. Once you've done that, you can just unplug the wiring harness from the faulty timer and plug it into the new one. Now just remount the timer, put the back panel cover back on and fasten the timer shaft with the lock washer and nut, put the timer knob back on and give it a try.
That should get your washer back working properly. I hope you find this Very Helpful and best regards!
Sep 23, 2009 | Maytag Washing Machines
My washer wont drain
The washer's pump unit has stopped working. It may not me getting the signal to pump after the wash cycle (controller problem) or the pump has let go and needs to be replaced.
Aug 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag top loading washer won't agate. Instead it fills with water and spins, then drains, fills for the rinse and spins. Thanks Bill
Open your control panel.
Disconnect then reconnect your timer wiring harness.
If this does not correct the problem,replace the timer.
Feb 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Need directions to replace timer on Maytag Washer PAV1000AWW.
First unplug washer from power , remove back panel of control panel, there should be a large molex connector maybe 2 of these connectors that plug into timer they usually have a clip that holds them into the timer there may be a release for the timer knob that would be on the back of the timer. Remove any screws holding the timer to the panel. plug connector blocks back into timer, most of the time they will only fit one way and if there is two of these connectors they only fit in the right one , the right way . I suppose if you tried hard enough you could possibly get them to fit in the wrong way or the wrong spot but that would be a lot of work. Reassemble in the same way you disassembled replace back panel of control panel happy washing. By the way how do you know the timer is bad?
Nov 05, 2008 | Maytag Washing Machines
Timer on maytag washer
this is a good one! dependable care unit made in my home town.
http://www.servicematters.com/maytag_library/docs/16010373%20(16001145).pdf
insert flat blade under center plastic clip in the center if timer knob , you will find a little clip and sping here , then remove two 5/16 screws , then remove two phillips screws on control panel , you should see 4 ,2 on each side remove the inside 2 then tilt panel forward unplug timer. so easy
May 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer won't spin out
Before you try to take the panel apart to remove the timer you need to check that the electrical connections to the pump are o.k. and whether the pump is getting power when it's time to drain. If you have to replace the timer you need to take the back panel off first.
Mar 12, 2008 | Maytag HAV2558 Top Load Washer
Maytag Bravos MTW6600T Top Load Washer Logo
55 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
