I have a mastercool p225102a controller - everything works at the test buttons. The fuse is good but motor will not run even though the thermostat is supplying power to the fan terminal.
2 Suggested Answers
SOURCE: Need a wiring diagram for mastercool evap 2 stage unit
I have the wiring diagram in the cooler. I can photograph and send it to you. Do you still need it?
Posted on Jun 06, 2009
Blower motor on Trane 4TEE3C04A1000AA not coming on.
could be a number of things. heat may have blown a fuse now nothing works, heater may not have worked because the blower wasn't. you need a meter to test voltage.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jan 15, 2018 | Heating & Cooling
Motor only runs when i hold down the test button
test button bypasses t-stat or selector switch check those to be sure there is a call for the fan.
Aug 31, 2012 | Mastercool 67680 Evaporative Cooler Air...
Mastercool plus 6500 thermostat problem
Posted also on the Cooler quick cycling problem:
My Master Stat Controller (CC2000A Rev 2003) was in 2 parts. The Thermostat unit in the house and the Power Control unit in the Cooler. The power Control unit was mounted on the squirrel cage fan housing so it vibrated some when running. That means the components vibrated slightly with respect to the PC board. Especially the larger components. My first symptom - Intermittent failure to turn the water pump on. I could see a faint crack in the solder around the pin of a relay on the PC board. Re soldering the PC pins solved that problem. Later, the second symptom was quicker than usual on-off cycling of the fan. I re-soldered all the pins on the PC board and all problems subsided. A better mounting place for the Power Control Unit would be good, but outside of the cooler might be a thermal problem here in the hot desert south west.
Apr 24, 2012 | Mastercool 67471 Evaporative Cooler Air...
My gas dryer burner does not heat. The igniter does not glow even to permit the gas valve to turn on. Everything else works and checks out being good, such as the thermostats, igniter, flame sensor. ...
You could check the igniter by testing to see if 120 volts is at the wiring the igniter plugs into, if 120 vac at that plug the igniter is bad Also need to check THERMAL FUSE,in addation to thermostat,on electric dryers if thermal fuse is out it cuts circuit to motor, on many brand dryers if thermal fuse bad on GAS dryer it cuts circuit to igniter
Aug 12, 2011 | Dryers
Our mastercool thermostat does not have any power going to it whatsoever. It is only a 3 year old unit and we have checked all the fuses and wiring which all seem to be fine. We even changed the main...
If it's a 24 volt thermostat, the inline transformer has failed and needs to be replaced. Some are 18 volts, and they require a transformer too. I suspect that's the problem, since the T-Stat is not getting power.
Hope this helps you solve the problem. Please let me know. Thanks.
May 06, 2011 | Mastercool 67680 Evaporative Cooler Air...
HEATER FAN BLOWER DOES NOT WORK
check fuse and relay.if all is good.check blower motor to see if its getting power if so motor dont run. replace motor.if not.and fuse and relay is good.problem could be the control switch or loose broken wire at control switch.
Dec 04, 2009 | 2001 Daewoo Leganza
Frequent short cycles of the Mastercool swamp cooler
Short cycling can also occur in a thermally protected motor if it is overheating. If the other solution did not work, make sure the belt on the motor is not too tight or too loose. A handy person can check the amperage with an amp probe to make sure it is in limits. The adjust the pulley to put it into specs.
May 27, 2009 | Mastercool 67680 Evaporative Cooler Air...
1988 GMC P/U windows and door locks don't work,
if fuses chk.out ok i would have to say its the drivers side controls went bad. windows, door locks, everything runs thru drivers controls. even though you said buttons chk. out ok i can't think of anything else other than a fuse, unless the wires came loose from the maine controls or maybe there coroded. hope i've ben some help. OLD SCHOOL.
Jan 14, 2009 | 1988 GMC C1500
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
