Question about KitchenAid KSRA25ILSS Side by Side Refrigerator
Ksra25ilss13 Kitchenaid ice maker not working
I have a Kitchenaid SxS (model KSRA25ILSS13) and the ice maker has ceased working. I have been on this site (and others) reading and trouble-shooting, and here is what I have done.
1) defrosted the whole fridge over night to eliminate the possibility of an ice blockage anywhere in the water line
2) pulled the sheet with the optic codes out of the bottom of the fridge and the flashing lights seem to indicate that there is no issue there (two flashes pause, two flashes)
3) Manually filled the ice tray with water, and it seems to have frozen but it has not harvested. The ice remains in the tray.
This fridge has been nothing but problems (5 years old), and I assume my only recourse is to spend another 110 bucks and buy a whole new ice maker, but before I do that I wanted to see if you had other suggestions.
Also, I have not been able to figure out how the ice tray knows when to fill. Is there just a sensor that detects when its empty?
Any guidance is much appreciated.
  • brent_floyd Jun 11, 2011
    Anyone haveva solution for this, by chance?
Joe_Rex
  • 114 Answers
SOURCE: Ice Maker troubles
THERE IS A HARVEST CONTROL (SENSES THAT THE ICE IS PRESENT AND SWITCHES MODE TO HARVEST)... THAT MAYBE THE PROBLEM BEFORE YOU CAN SAY ITS THE MOTOR MODULE. IF YOU HAVE A BAR THAT IS VISIBLE OVER THE BIN ... TRY LIFTING IT ALL THE WAY UP WHEN YOU HAVE ICE IN THE TRAY... IT SHOULD SWITCH THE MODE TO DUMP THE ICE. I NEED TO KNOW IF ANY OF THIS WORKS OR NOT BEFORE I CAN GO FURTHER. GOOD LUCK .... YOU CAN WRITE ReckingerJ@aol.com make sure to type (Fix-Ya) in the subject bar.
Posted on May 02, 2007
icansurf
  • 72 Answers
SOURCE: Ice maker won't fill
leaky solenoid? could cause ice build up
Posted on Jul 11, 2007
aborcass
  • 2651 Answers
SOURCE: Ice maker quit working
good sign its flashing , woth door open depress the left side flap oppiste the blinkin light. does the light then go solid red??? i fso its an indication that the electricl eye is operating ok .
theres a screw 1/4 in. along the right side underneath the icemaker itself, youll need to removeit and the cover its holding down. you can then slide the ice maker assy foward and out of machine,There will be another litle tab along loeft side uder ice maker youll need to depress to ppulll unit out. pry off the white cover from front of the ice maker assy itself and have a look at the main gear 2 in. round, is it broken off, or on its way top breaking( sometimes the tabs that hold it on to the ice maker module itself break preventing operation, if this is the case youll need to repalce the ice maker assy.
Posted on Oct 31, 2008
Controlfrk
  • 304 Answers
SOURCE: kitchenaid ice maker dripping and freezing down freezer shelfs
Tube sometimes freezes because of minerals in it hold one droplet at a time until buildup freezes solid. Replace tube first. Water valve allowing some droplets through can also cause this. Tube first-less expensive.
Posted on Aug 23, 2009
  • 401 Answers
SOURCE: Can I trigger the KitchenAid Superba KTRS25Q ice maker to fill?
THERE IS A WAY TO (JUMP) THE ICE MAKER BUT I DONT RECOMEND IT BECAUSE IF YOU JUMP THE WRONG WIRES YOU CAN DAMAGE IT. TAKE THE COVER OFF THE ICE MAKER AND LOOK IN THERE IT MAY SAY HOW. OR WAIT
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Posted on Jan 13, 2010
Remove ice maker whirlpool refrigerator
Ice maker repair - How to remove Whirlpool Kitchenaid ...
? 2:01
https://www.youtube.com/watch?v=UHi59JFB3N8
Feb 13, 2014 - Uploaded by AdamDIY
This ice maker is used in: Whirlpool, Kenmore, KitchenAid this one ... ... How to remove an ice maker from a ...
Jan 08, 2016 | Whirlpool Refrigerators
Our ice maker leaks water and forms mini iceburgs inside our frezer. It appear to a water leak leading to the ice maker. What part should we replace to fix this problem. It is a Kenmore SxS 26' SS...
Your water valve probably has a drip like a bad water faucet.The water valve is cheapest and your only 2 parts options are the ice maker AND the water valve.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 08, 2011 | Kenmore 57703 Stainless Steel
I have a KitchenAid SxS model # KSRG25FTST01 with an icemaker problem. It stopped making ice, but the water still dispenses. It makes no noise and no water in the ice tray. I never hear it try to fill with...
If the thermostat behind the left side of the fill tray goes bad, the cycle will stop completely. Cost of thermostat is $20.00. Cost of new icemaker with new motor and everything including thermostat is $45.00, brand new, on EBay plus shipping. Cost for new icemaker from repair shop, $153.00 plus tax. Control board circuit panels each side of freezer compartment will go bad also stopping the ice maker cycle. these control boards come in pairs, one for each side of freezer compartment. Cost for new circuit panel control board from repair shop, $215.00. Cost from EBay brand new circuit control board $45.00 plus $8.00 shipping. Easy to install both, icemaker and control board circuit panels. Phillips screw driver and small socket set is all you need for removing and installing these items.
Jan 22, 2011 | KitchenAid KSRS25IL Side by Side...
Ice maker not filling...already turned off ref let set for 3 hours to thaw still not working
Noticed you did not list your model number of
your Kitchenaid Refrigerator. I see a model number KSRD22FKST above your post
is that correct? If yes there are a couple things that may be causing this. If
the ice maker mold/tray is
full of ice and will not
cycle most times the ice maker thermostat Click Here=> KSRD22FKST while there look at item number
27 in photo. That is your ice maker's thermostat that tells the ice maker when
ready to cycle and fill with water again. The part Number is=> 627985
they also request that you order the sealant for ice maker thermostat=
Jan 09, 2011 | KitchenAid (KSRD22FKST) Side by Side...
The refrigerator is not cooling
If your freezer is frosting up, fresh food section is warm: bad fan motor,defrost drain stopped up and forming slab of ice between the freezerand the fresh food section. Check heaters andterminator(defrost thermostat) unplug the ice box and let it defrostcompletely. Clear objects from drain. Check timer. Note to find thelocation of your timer look up your model number online here: APPLIANCEPARTSPROS.COM.
Check under the bottom for the fan motor to be running and the cobwebs, dust, dirt, and pet hair, off the condenser coils. If the fanunderneath has quit then the ice box won't get cold. BASIC REFRIGERATION REPAIR MANUAL
AMANA SxS REPAIR MANUAL
BOSCH MANUAL
Monogram Manual
KitchenAid SxS with variable capacity compressor
GE LATE MODEL SxS MANUAL
F&P Reefer
Jan 11, 2010 | Maytag Refrigerators
Kenmore by Whirlpool sxs water in the door. Ice maker 106.565424
The water control valve for the ice maker side is your most likely reason. If filling ice maker with tap water and allowing to freeze. If it dumps then the water control should fill. if not the valve is not working. Sea Breeze
Oct 16, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker not getting water, but water to the door dispensor ok
The fill solenoid for the ice maker is not working. Replace it and you are good to go.
Sep 24, 2017 | Whirlpool GD5SHAX Side by Side...
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Aug 02, 2007 | KitchenAid KSCS25FKSS Side by Side...
KitchenAid KSRA25ILSS Side by Side Refrigerator Logo
418 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
