Question about Samsung Computers & Internet
Why is my samsung 2232gw blinking blue
Why is my samsung 2232gw power light blinking blue?
3 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: my 2232gw started flashing, as if the starter is
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 15, 2010
SuperTech-11
  • 1591 Answers
SOURCE: I have the samsung 2232gw
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Jun 17, 2011
Testimonial: "This will help out. Thank you very much."
I have a Samsung lns4695dx lcd tv. The blue light on the front power switch blinks and I get no picture or sound. I read in some forums about bad caps on power supply board so I replaced the 12 cap in the...
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Mar 12, 2014 | Samsung Televison & Video
Samsung 906vw blank screen
if the power light indicator is just blinking with no display, you must checked the power supply the common cause bulging electrolytic capacitor. just replace with the same value and rating then the problem solved.
Jul 22, 2012 | Samsung Computers & Internet
Samsung HLN507W turns on for about one minute then shuts off, three blinking lights stay on in front. It is not the lamp, nor the blue lamp cover switch for sure. I unplug it and immediately turn it on. ...
Samsung HLN507W turns on for about one minute then shuts off, three blinking lights stay on in front. It is not the lamp, nor the blue lamp cover switch for sure. I unplug it and immediately turn it on. It always does the same thing: comes on for 1 minute, then powers down - there is no wait time in between unplugging and powering on. All fans seem to work and I cleaned the dust out of it. Help.
Nov 04, 2010 | Samsung HLN507 50" Rear Projection...
My 2232gw started flashing, as if the starter is
May 12, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
My 2232gw started flashing, as if the starter is going, now it is not turning on at all, power light flashes no backlight
You need to open it up and inspect the inside for bad capacitors (bulging top/seal, leaking liquid), inverter/power supply circuits, can be bad lamps, transformers, etc. Post back what you see inside, pictures will help a lot. See pictures I posted here on failed monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 19, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Syncmaster 2232gw led blinking.
Change the screen resolution. The video card or video display may not be compatible to the supported video setting of the monitor. Try changing the video resolution to a lower setting such as 1024x768 and bit depth to 32 bit.
Mar 15, 2009 | Computers & Internet
Samsung Syncmaster 205BW power button lights up image will appear
Hold down the power button and the auto button. if that doesn't work try the power button and the source button.
Jun 24, 2017 | Samsung SyncMaster 213T 21.3" LCD Monitor
Not working with Samsung U600
YOu will have to put the headset in pairing mode by keeping the power button pressed till the light becomes solid blue instead of blinking. Now switch on the blue tooth of your mobile and try pairing,. it should work. passcode will be 0000
Jan 29, 2008 | Samsung WEP200 Headset
Computers & Internet Logo
124 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
