I recently install a cable line for my lxi tv and installed a vcr/dvd player. Now, I have no picture or a few channels are snowy. I do not have a remote and must use the hard buttons. I did notice that I do not have SAP.
    Novelist:
    Scholar:
  • 100 Answers
Hi Chara77,
There maybe a couple issues that could be causing your problems.
a) Check your cable lines to make sure there are no cable breaks, or loose connectors. Tightening down connectors will sometimes assist with that as well.
b) Depending on how you change the channels there maybe an issue with the television not receiving the full signal from the vcr/dvd player and you may need to change channels only from it.
P.S. SAP stands or "Second Audio Programing" it usually allows secondary audio tracks such as bilingual programing. It should not affect your picture.
Cordially
Jon
Go Ahead. Use Us.
Posted on Apr 21, 2008
Tv has only snowy screen. Used the remote to
What to do if you have an all snowy picture (blue screen or the TV displays unusable signal-no signal or no sync)
1 – If you are using a digital cable box or satellite receiver (make sure it’s on) and be sure your TV is set for either CH3 or CH4 (which ever you usually view it on). If you usually view it through video inputs (video1 or 2 etc.) make sure the appropriate input is selected.
If you still don’t get a signal see if you get picture using the DVD or VCR (if available) if you do than plug the satellite or Dig. Box temporarily into the place of the DVD (unplug DVD) you may have to use some A/V cables (RCA yel./red/wht like the ones on the DVD) to hook to the tv from the sat./dig. box. If you get a signal then the sat./dig box is ok. If not the Sat./dig box is not sending a signal and is either defective or needs to be rebooted (unplug wait 5 min try again).
2 – If you are using standard cable or antenna (source) if possible check that the source is good by connecting to another TV. Otherwise try running the source into a VCR and then out to the TV using video inputs (RCA yel./red/wht like the ones on the DVD) and then selecting the appropriate input. Try seeing if the VCR plays using standard CH3 (or CH4)
If the VCR plays on video input but not when connected to CH3 (CH4) then the tuner of the TV may be defective – see if you can use the VCR to change channel using the VCR remote.
Be sure to vote/rate me if this helped Thanks!
Nov 24, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
Snowy screen when I play a DVD
hi!!!!
try to change the cable!!!
may that helpS :)
Sep 27, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
When tv is turned on with cable channels picture is snowy. when dvd or vhs tape played through tv the picture is snowy
Try using the video inputs
Nov 13, 2009 | Televison & Video
I am unable to get my vcr to record. To use my vcr i have to turn my tv to channel 3. Our cable company uses channel 4. Please help
If the tv is working with the cable box with the coax to channel 4 ( then with this configuration to send any signal to the VCR actually it is posible to use a splitter with coax and send the signal to the tv and vcr after the cable box. vcr has tobe in channel 4 also, all channel selection is done in the cable box then anything you see in the tv is recorded in vcr. BUT guess what: You maybe can try something else:
If you send the cable from the wall straight to the splitter and then from splitter to the TV and to VCR, now you can record differnt channel than you are watching in the tv but in this case scenario you need to send the vcr to the video input 1 of the tv to play what is record. Any way to install this TV and VCR you not always need to depend in the cable box.
May 01, 2009 | Sanyo DVW-7000 DVD Player/VCR
Bought a proscanlcd hdtv 32lb30Q unable to get cable signal
Hi and welcome to FixYa,
Initially, pls confirm if below is how it is wired using a coaxial cable and not 3cable RCA to RCA:
  • Charter Digital Cable > DVD/VCR > TV
If yes and your concern is snowy or no signal on the TV screen, might it be that you have to power OFF the DVD/VCR when selecting channels on the TV itself (including when channel setup is being done).
Alternately, you can tune the TV to channel 3 and let the DVD/VCR do the channel selections.
Pls post back results. Good luck and thank you for using FixYa.
Jan 26, 2009 | Televison & Video
Snowy picture on VCR with only certain channels
In all likelyhood, you have a bad ground somewhere in the cable. Try other channels through the VCR. If the ground is the problem, there will be a cluster of channels that are snowy with the rest being clear. Check the cable itself and all of the connectors along it.
If the cable and connectors are good, the tuner or power supply of the VCR could be faulty and cause this as well.
Dan
Dec 24, 2008 | Sony SLV-N50 VHS VCR
I have a 30 year old tv w/cable. I want to install a dvd/vcr combo player. What kind do I need? I've tried one and it didn't have the right connection.
If the original TV doesn't have audio/video inputs, you'll need a DVD/VCR player that has a built-in RF modulator. A RF modulator takes the audio & video and modulates a RF carrier to one of the channels that your TV can receive. In the U.S., this is usually channel 3 or 4. If the DVD/VCR player has a built-in tuner, connect your cable to the RF input of the DVD/VCR player and the RF Output of the DVD/VCR player to the cable input of the TV. This way, you can receive your cable channels through the DVD/VCR player and watch movies as well. If your DVD/VCR player does not have a built-in tuner, you can put a RF switch inline that will allow your TV to either receive the cable signal or signal from the DVD/VCR player.
- Jim
Jul 03, 2008 | Televison & Video
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
TV intermittently goes snowy.
time for a new tuner probably about 150-200 bucks to fix
Jun 13, 2006 | Mitsubishi PD-4001 40" TV
No picture
Tvs usualy have a few ways to hook them up. One is a coax cable this is the silver one in the back that you screw in a cable. The second are RCA cables these are the ones that are yellow, red and white. Yellow is always the video and white and red are for audio. If your using the coax cable your tv needs to be on channel 3 or 4 you may have to force the tv to go to that channel by pushing 03 on the remote. If you are using the Rca cables then you need to change the tv to "video 1" or "video 2" this changes the tv from tunner mode to aux input mode. Most DVD players dont have a coax out so you have to use the rca plugs. Some tvs have the rca plugs on the front (video 2) and the back (video 1) or line in. Some tvs have line out also so you need to figure out wich way you have it hooked up. Do a search for the model of your tv and it should show a diagram on how to hook it up.
Apr 07, 2006 | Emerson EWD2003 DVD Player/VCR
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
