Question about E-Machines eMachines Desktop PC
Usb connection problem
Why does my usb connection not work
  • 2,229 Answers
There could be a number of reasons. Your motherboard might be bad. The USB function in the BIOS could be disabled. The device you are trying to connect could be not working. If you are installing something that plugs into the USB connector, you might have to install drivers for the computer to see it.
Sorry to be vague, but you didn't ask a very specific question.
Posted on Jul 19, 2010
  • 3,153 Answers
See here for most of the common and quick fixes for this type of issue
http://www.fixya.com/support/r4247716-usb_device
Hope you get it fixed
Bob
  • Project NOMAD
    Project NOMAD Jul 21, 2010
    Did you fix your problem ?
I bout retractable travel mouse and doesn't seem to work on my labtop
It may have a manufacturing defect. Have you tried it on another computer? If it works on another computer, see whether it works when connected to a different USB port on the laptop. If it does, then you may have a bad or damaged USB port on the laptop. If it works on another computer but still does not work on the laptop when connected through an alternate port, then see whether some other device will work when attached to the laptop's USB port. If neither the mouse nor the other device work when connected to a USB port, then you have a problem with the USB controller. If an alternate device does work when connected to the USB ports of the laptop, and if the mouse works when connected to another computer but does not work when connected to the laptop, then you have a software problem, and probably need to change the mouse driver in a control panel or setting in the operating system of your laptop.
Oct 27, 2013 | Maxell Optical Travel Mouse With...
HI Sir, My Samsung Corby F339 Mobule is not connect in my pc showing error 692 there was a hardware failure in the modem(or other connecting device) plz help me.....
This error usually comes when you use usb cable to connect the phone to pc . Please try to unplug the cable and plugin the USB cable to another port and try via pc suite to connect to internet. If still it is not working try to connect on another pc via same USB cable to phone. If you are getting the same error still then this means the USB cable is damaged then change the USB cable and you can connect to PC. If USB cable works with other pc then reinstall pc suite or try connecting by creating dial up connection.
May 24, 2010 | Lands Phones
How do I set up a d-link dub-h4 to my laptop I have a power connection, a connection on the rear of the hub-4 going to an adapter connecting to the ps/2 connector on the laptop. Do I need one of the...
The connection on the rear of the hub should go to a USB connection on the laptop, not a PS/2 connection. A PS/2 to USB adapter is used to connect a PS/2 keyboard or mouse to a USB connection.
Feb 23, 2010 | D-Link (DUB-H4) 4-Port USB Hub
Window7 crache connecting usb fax modem
I expect it is a problem with your USB Driver, Get an updated driver for your USB slots. (either from motherboard manufacturer or USB manufacturer if it is a USB "card")
Even default or old drivers might work Try a few different USB drivers - a new one, the reccomended one, the original one...
(good idea is to use a ps/2 mouse and keyboard since your usb will be going on and off while you're working, it can be hard to click YES when you're keyboard AND mouse aren't working ;-)
if it still dont work...
Can you set any of your USB slots to work in USB 1.0 instead of 2.0, there could be an option in bios, maybe it will run the "OLD" modem in an OLD mode?
Jan 21, 2010 | Computers & Internet
I have tried in vain to get the USB connection on my Westell 6100 to work. Are there some tricks to making this happen? The ethernet connection will work fine, but I cannot get the USB setup to work at...
I suggest that you use ethernet connection instead of the USB connection.
Ethernet is more stable that USB, you less likely to experience dropped connections.
Also take note that you can only use one connection at a time. You CANNOT use Ethernet on one computer, then USB on the other computer.
But if you insist to use the USB connection, you need to install the drivers. Once the usb cable is connected to the modem and computer, you will get a found new hardware wizard screen. Then you will need to insert the CD that came with the adapter to your computer.
If the found new hardware wizard did not appear, check your device manager and look if there is a USB adapter with a question mark or exclamation point. Right click on the USB adapter then click reinstall.
It should detect the drivers from the cd.
Good luck and have a great day!
Jan 11, 2010 | Westell Wirespeed LiteLine 6100...
Does not work when cpnnected to the external USB hub. Says "Camers Off". Works OK when connected directly to MacBook USB port? Why?
Make sure your USB hub is working. Confirm by using the with other applications such as connecting your thumb drive or other connections. If other connections will work, then your external hub is okay. Other thing, if your usb hub runs at lower speed than 2.0, new gadgets connection may fail.
May 14, 2009 | Logitech Webcam
Usb not working
Check that all the USB ports are turned on in the BIOS setup.
Apr 02, 2009 | PC Chips (M925G) Motherboard
HP laserjet 2200D connected via USB gives problem
try plugging into another usb & reinstall the driver that may help.
Jan 16, 2009 | HP LaserJet 2200D Printer
Hp all in one
Try the follwoing steps, i m sure that it will start working bcoz i tried the same steps and my printer started working:
  1. Turn the power to the computer off.
  2. Press the power button to turn off the product.
  3. Wait 10 seconds.
  4. Restart the computer.
  5. Press the power button to turn the product back on.
  6. When the computer restarts, try the scan again.
  • If the issue is not resolved , try some other troubleshooting:
  • Connect USB cable directly to the computer and then restart the product and try to scan again
  • If the product still does not work , try some other steps:
  • Connect the USB cable to a USB hub or a docking station for a laptop. 1. Restart the computer and the product and try to scan again.
  • If the product doesnot works after connecting the USB cable directly to the computer , follow these steps:
      1. Reconnect the USB cable.
      2. Try the scan again.
        • If the product worked when the USB cable was connected directly to the computer, but does not work after reconnecting the USB cable in the original configuration, there might be a problem with the hub or docking station. Either leave the USB cable connected directly to the computer, or contact the manufacturer of the hub or docking station for troubleshooting.
      If the product does not work after connecting the USB cable directly to the computer , follow these steps.
      1. Replace the USB cable.
        • If the product does not work with the new cable, continue to the next solution.
    Now, if this doesnot work, there is a conflicting USB device connected to the computer
    1. Disconnect all other USB devices from the computer except for the keyboard, the mouse, and the product.
      • The issue would be resolved now and teh answer is that the computer might not have sufficient power supplied to the USB ports to detect multiple USB devices. HP recommends installing a USB powered hub to connect multiple USB devices.
May 28, 2008 | HP DeskJet F380 All-In-One Printer
Only works when connected to laptop, not when connected to a usb hub
This is a common problem with many USB devices. Most will work on hub but some are designed specifically not to. The biggest offenders in this category are Palm Pilots/Pocket PCs and wireless peripherals. They do this because they consume a great deal of the USB bandwidth and splitting it would make everything connected to the hub have connectivity problems. If you really need an extra USB port or two on a laptop, they do make a PCMCIA->USB card as shown here: http://www.buyextras.com/syusb202pcca.html?gclid=CN_JsfLGno4CFR3NgAodIRRvTg
Aug 31, 2007 | Logitech Cordless Mouse
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Steve Allison
Steve Allison
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
