Question about Whirlpool Duet GHW9150P Front Load Washer
F-H Mine flashes F-H...what does that mean? Can you help. I don't know how you open this panel?? :o))
  • 770 Answers
FH=
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then
valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has
detected 10.5 gallons of water passing through it, but has not detected the pressure
switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
• Make sure that both valves at the water source(s) are turned on all the way.
• Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
• Verify inlet valve operation
• If there is water in the unit:
• Verify Drain pump operation
• Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Posted on Apr 24, 2008
What does Er and uF mean. My dishwasher was linking water.
On mine it was Er meant "error" just generic for somethings wrong, (dumb I know!) and the uF means unit failure. I know it sounds so dang dumb. It is merely the computer\'s way of telling us something is not right. Hope it helps, but please don\'t ignore those codes they really are put there for OUR safety, Be Well.
Sep 29, 2014 | Frigidaire Dishwashers
My Coby LEDTV 1926 blinks red, green, blue, white, and black. Is there anyway to fix this?
Sorry I can't help, but mine does the same thing sometimes. It'll work fine for awhile, then no picture, but goes crazy and flashes one color at a time across the whole display, very brightly. I have it connected to RCA inputs, so I don't know if it would happen using the antenna input, but based on your experience, I suspect it would. I never got around to calling tech support, and my return period ends in two days, so it's going back to the store tomorrow.
Oct 30, 2011 | Coby Televison & Video
Control panel number 4
Hello, There has been a couple times, Frigidaire was sending out the wrong control board in the correct box ( believe it or not it happened to me 2x ).. finally i had to call ELECTROLUX directly and had them send me the board direct to customer.. i believe that the 4 is because there is a wiring issue with one of the microswitches where the damper motor is and it will not allow the damper / control board to recognize "open" position ..I don't know how old your fridge, but in this case you should get a tech out with some testing equipment. Thanks Mike
Oct 23, 2011 | Frigidaire Refrigerators
Can you help me to install this media flash player ?because this is my first time and i Don't know how to make this.please help me....and i cannot watch te channel television and vedio.
Do you mean flash media player? You can download it from here. Once it downloads just launch the installer and follow the on-screen instructions, or even better keep clicking next, next till it shows installation complete. Remember that the flash player requires you to close all your web browsers before you launch the installation
http://www.adobe.com/support/flashplayer/downloads.html
If you need more help, just let me know
Jul 10, 2011 | Televison & Video
Don't know how to open laptop gateway MX 7120 please help
check out the pdf free download supplementary file: http://www.retrevo.com/support/Gateway-MX7120-Laptops-manual/id/607ci057/t/2/ Good luck! I wish I had found this BEFORE I went nuts trying to open mine!!!
Jun 11, 2011 | Gateway MX7120 Notebook
I cant sign in in my skype account..whenever i enter my password..there is a word flashing in my computer SKYPE stop working..what will i do?
Don't waste your time. Control panel Remove Prog Programme.
Download latest skype update and re-install. Happens 1or2 times with mine, I'm already grey, don't need the agro these days.
May 26, 2011 | Computers & Internet
I need to replace the door switch on my GE Profile Gas Dryer DPSB620GC4ww and don't know how to get behind the panel on the front of the dryer. Can you give me detailed instructions on how to do this?
unplug it,open the door and look up,you'll see two phillips screws,take them out and remove the top panel,if you want to remove the front panel just remove the two phillips screws one on each side of the panel around 4 inches down from the top.
May 20, 2011 | GE Profile DPSB620GCWW Gas Dryer
Power light blinks 4 times pauses then blinks 6
Not sure what the code means (mine occurred after a slight power surge...maybe an overheat or some kind of overload), but after leaving the tv off for 10-15 minutes the flashing stopped and the picture was fine on restart. I know you've probably figured this out already, but hope it helps somebody because Philips apparently does not want to make it easy to figure out what these codes mean.
May 27, 2010 | Philips 50PFP5332D 50 in. Plasma...
Whirlpool Duet GHW9150P Front Load Washer Logo
56 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
