Question about Magellan RoadMate™ 1212 Car GPS Receiver
The receiver turns on and allows me to input an address, but when it's searching for directions the screen becomes distorted with multi colored lines and then shuts off. What is the problem and can this be repaired?
  • rozziroz Jul 19, 2010
    Where do I rate you?
    how do I rate you?
    Top Expert:
  • Magellan Master
  • 77,499 Answers
It can be repaired, but the problem is that the cost to repair is more than the cost of a replacement GPS, a good Garmin or Tomtom goes for about $140.
Posted on Jul 19, 2010
    Wow you are quick! Somehow I knew that would be the answer. Thanks so much for your response!
  • yadayada
    yadayada Jul 19, 2010
    could u please rate my help for fixya, thanks
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
My sony wega kf-50we610 unlike every one else i have no problems with set turning on my problem is i cant watch anything do to the picture being distorted scrambled like i can see the menu options and...
It looks like the vidoe board but the fault can be also a distortion in the horizontal / vertical section. So check the PIN amp and related sections. What must be looked is of the HSTAT can be off set.
Deguass the set well to confirm if there is any possibility of a distortion of picture by a severe magnetic field.
Since there can many problems associated with a distorted picture but you can try and see these possibilites other than the Y amp processing. Hope my suggestions helps.
Aug 20, 2010 | Televison & Video
Picture has become distorted, especially towards the side of the television. The colour filters line up towards the middle of the television, but become distorted towards the sides.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Apr 20, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Sound not picture
A few questions:
Are you using this TV directly on a cable line of do you have a cable box or satellite receiver connected?
Do you have sound and no picture on the AV inputs as well, or only on TV channels?
Is there anything on the screen or is it completely black? Has the picture collapsed to a single line across the screen? Is there a picture but it's distorted?
Does the on-screen menu and channel number display properly?
With a little more information I might be able to help you with this.
Feb 11, 2010 | Toshiba 32A33 32" TV
RCA 27R410T Television colors are distorted
If you`re talking about colored spots in the screen, then you may have a degauss problem. It was frequent for those sets to have bad solder joint on the degaussing coil connector or thermistor next to it.If you`re handy with a soldering iron these connections would be near the a.c line input. good luck and don`t forget to unplug
Nov 01, 2009 | RCA 27R410T 27" TV
Blue vertical lines across the top of the screen
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 18, 2009 | Gateway GTW-P42M303 42 in. Plasma...
RCA 52" Model D52W23 Color Distorted
its not due to the fuse.its the problem of the ic on the maIN BOARD of the tv just check out for the faulty on the main board with multi meter and replace it.
Dec 19, 2008 | Sony KP-51WS520 51" Rear Projection...
Magellan RoadMate™ 1212 Car GPS Receiver Logo
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
