Question about GE Microwave Ovens
Dishwasher won't drain - GE Microwave Ovens
  • 6,826 Answers
When this happens, you might have a logical problem in the control module of the dishwasher, the part that programs what the motor does at any given time, circulate or drain.
If it is an older 1970s or 1980s dishwasher, it has a mechanical program.
Newer 1990s to 2000 and beyond dishwashers are more electronic in nature, eliminating mechanical breakdown of the program.
However, the motor, if it is still running and does not leak, is probably ok.
You did not mention the model number for more specific information.
Posted on Jul 19, 2010
  • 4 more comments
  • Susan Jul 19, 2010
    The model PDW7980P00ss
    Duane is there an air gap in this model? The manual said there might be one
  • Duane Wong
    Duane Wong Jul 19, 2010
    OK, apparently this is a newer microprocessor controlled dishwasher, but under the Troubleshooting section of geappliances.com they did not have it listed.
    However, here is the site I was looking at where you can input the model # of your GE appliance:
    http://www.geappliances.com/service_and_...
  • Duane Wong
    air gap- do you mean the clearance must be 2" or greater between the sides and cabinet?
  • Duane Wong
    This GE model dishwasher does have a manual that I downloaded and read for installation and operation.
  • Duane Wong
    https://www.geapplianceparts.com/GEAppli...
    The module control assembly costs $116.50 and is located in the door.
    This is the problem or the motor pump assembly is the problem if it leaks or doesn't wash at all and doesn't drain.
    Or, it could be the wiring in between the module control assembly and the motor pump assembly.
All the water will not drain out of the dishwasher
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Jul 16, 2011 | Microwave Ovens
My dishwasher didn't drain the water out on the end of the clicle? What could be the problem?
Hello, Thank You for using FixYa. I will be helping you today.I would start where your drain line connects to the house drain,This is where most blocked drains happen. Disconnect the drain line and put it in a bucket and try to drain the dishwasher. Chances are its blocked somewhere you just have to find it.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 02, 2011 | Microwave Ovens
Dishwasher (Kenmore MDL# 363.14772100) not draining, what needs to be cleaned out?
heatman101
May 16, 2011 | Microwave Ovens
Purchased Model # EWDW6505GS from Lowes in Tigard, Oregon today. It was the floor model and did not come with a manual for use and care (I got online) or with a drain hose. Where do I find a drain...
the drain hose for your dishwasher needs to fit the plumbing in your home. Measure the size of the connection at the drain (under the sink) and possible use the old hose as a model for what you will need. Lowes sells a hook up kit but be careful to measure the size of the outlet on bottom of the dishwasher and size and distance to the drain connection. Sometimes addaptors are used to size down the outlet side of the hose. Also if you have the manual it may show the size of the outlet on the dishwasher.
May 01, 2011 | Electrolux Microwave Ovens
The dishwasher won,t start. The lights are blinking but no water comes in.
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Apr 19, 2011 | Microwave Ovens
Machine not draining
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Water will not drain out
heatman101
Feb 12, 2011 | Microwave Ovens
My dishwasher is leaving water in the bottom after finished. The dishes are not cleaning. Are the two related?
Yes more than likely you have a restriction in your pump/drain. you will need to remove the drain cover in the bottom of the dishwasher and clean it out
  • Empty the dishwasher and remove the dish racks so that you can easily locate the drain inside your dishwasher. The drain is under a drain grate, usually at the back of the dishwasher.
  • Remove the drain grate by either popping the grate out, or by unscrewing the screws holding it in place. Different types of dishwashers will have different options.
  • Use the soapy water and the toothbrush or scrub brush to clean inside the drain area and the grate.
  • Rinse the drain area with clean water. Then replace the drain grate.
  • Pour ½ cup of salt, 1 cup of baking soda and 2 cups of vinegar into the drain (in that order). The mixture will bubble. This will clean the drain and the drain hose.
  • Wait until the vinegar/baking soda mixture has stopped bubbling. Then pour 1 cup of bleach into your detergent dispenser. Replace the dish racks and run the empty dishwasher on a regular cycle. This will clean the entire machine
  • If this does not solve the issue your drain hose may be plugged or crimped and lastly your pump may be failing.
    Feb 11, 2011 | Microwave Ovens
    When my dishwasher drains both sides of sink fill with water...then they both eventually drain back into the dishwasher.
    Sounds like your sink drain trap or line is clogged. When the dishwasher drains, the sink drain can't keep up, the water backs up, then backs down the dishwasher drain line into the dishwasher. You may not notice the slow line when you run a little water into the sink, but with the amount of water coming from the dishwasher the problem is worse. You can try taking off the trap under the sink and making sure it's clear. If the problem is farther down the drain line, you can try snaking it yourself, or call a plumber. I don't recommend using Liquid Plumr or Drano because if those don't work, they leave the line full of caustic chemicals for the next person who works on it. That can be dangeerous.
    Dec 07, 2010 | Microwave Ovens
    I have a bosh dishwasher that has not drained of water and the tap light is red on the indicator board
    Hello there:
    Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
    If the motor isn't turning or working, the unit won't drain. Some dishwashers are susceptible to getting stuck if you don't run them regularly. I you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
    Jul 08, 2010 | Microwave Ovens
    Dishwasher does not drain. Drain valve is very hard to work and has burned out the solenoid. Can you tell me exactly how to get these parts out of the dishwasher. Do I have to replace the pump to replace...
    Hi
    Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
    First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
    Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
    Feb 09, 2010 | Microwave Ovens
    Microwave Ovens Logo
    21 people viewed this question
    Top GE Microwave Ovens Experts
    vince
    D. E. Hev
     Larry
    Larry
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
