Question about IBM ThinkPad X60s Notebook
My wireless has decided not to work. Have run
My wireless has decided not to work. Have run thru the diags and says to try to switch on - tried ftn F5 no difference, recently installed citrix so have removed it, no difference :o(
    President:
  • 2,571 Answers
Check in network adapters, see if it is enabled there.
Control panel / network devices (network and sharing centre, or similar depending on OS)
Posted on Jul 19, 2010
Hp pavilion 500-210qe hard drive blanked or formatted
Looks the hard drive is failing, did you run the hp diagnostic tool. See the link below on how to do that
http://www8.hp.com/us/en/campaigns/hpsupportassistant/pc-diags.html
Apr 06, 2014 | HP Pavilion Computers & Internet
Hi, i have a fujitsu siemens v6535 with windows 7 ultimate & my wirless switch doese'nt work, it may be broken, i tryed every way to turn it on from windows(fn+f1 & other ways) ???? how ca
Have you tried turning it on manually? Look on both sides and in front of the laptop for the switch.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
May 10, 2012 | Computers & Internet
Hi! All i have Amilo li2727 and using windows 7. my wireless net device doesnot want to turn on what must i do.
Normally there is a switch on the side or front that turns the wireless on. The FN function key located at the lower left portion of the keyboard toggles the wireless on and off if the switch is on. Normally you would Press and Hold the Fn function key then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it will have the icon of a tower with the wireless signal )))).
May 06, 2012 | Computers & Internet
My Wi-Fi on Lenova Think Pad T60 is not working. I tried to update the drivers. Still not working.
What is it doing? Still not working could mean a lot of things!!! Is the computer connected to the wireless network? You've got to connect to the network before you can do anything. And most times the problem with connecting to the network is people key the network key or password wrong so the wireless just keeps on polling trying to connect.
Do you have the wireless turned on on the notepad? Sometimes there might be a wireless switch somewhere that you have to turn on. Also most times you can toggle the wireless On and Off by hitting the FN Function key and the corresponding F1 thru F12 key that toggles the wireless. Most times the correct F1 thru F12 key will have a wireless icon signal on it sorta like ))))) or it may show a tower with the signals. Once you find the correct F1 thru F12 key to press then Press and Hold the FN Function key then hit the correct F1 thru F12 key. If you look at your screen most times it will let you know if you've toggled the wireless by displaying Wireless On or Wireless Off.
Mar 29, 2012 | Computers & Internet
How do I turn wireless capability on my acer aspire 5560. I can't find it anywhere
somehow my my acer aspire 5560 decided to turn off wireless capability by itself ... thank goodness i jumped onto the desktop computer and typed into Google " How do I turn on my wireless capability on my acer aspire 5560 ' your directions were spot on ... I dont know anything about fixing computers , so i just want to thank you for your simple instructions that helped me to get my laptop functioning again perfectly ... on my laptop the keys were FN (funtion Key) & F3 ....... much appreciated !!!!
Mar 21, 2012 | Acer Computers & Internet
My acer aspire 4720 has a Intel/PRO Wireless 2200BG (802.11b/g) Connection, which is now turned off. How do I switch it on ?
Most laptops have an external switch to turn on the wireless adapter. The ones that don't have to be turned on in the setup screen. If this adapter is on in the setup screen, then make sure that your driver is installed and that the adapter is enabled in the device manager. If this does not work then your adapter has gone bad. Of course never discount the possibility of a virus.
Aug 05, 2010 | Acer Aspire 4720 Notebook
After i format my lenovo computer i found that everything is ok except for my wireless and bluetooth problem though all the drivers needed are installed. Then i try to take out the wireless card underneath...
Hi. Make sure that all drivers are installed and the wireless card switch is turn on. Try Disabling/Enabling the wireless card by pressing the Fn + F5 key.
Jul 11, 2010 | Lenovo (40Y7026) Wireless Adapter
Power light is on and doesnt blink, Link light is solid green and there's a red light on the "diag". when I try to plug a Lan cable into the router I get no up link. My friend ask me to take a look at the...
You said there is a diag light lit up on the router.
In that case you can try to reset the rotuer for 30seconds . unplug the power and plug it back in. wait for a minute.
Check the lights on the rotuer. If you still see the diag light then try to reset the rotuer again. If there is a diag light on the router then the rotuer is not working.
Try to reset the rotuer for 2 - 3 times . power cycle the router till you get no diag light.
Once the diag light is gone then reconfigure the router.
Connect the modem to WAN port and computer to one of the 4 ports. Do not conenct anything to the uplink port.
Reconfigure the router.
Click Here to know more about how to set up router
Nov 19, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Dynes Wireless G Router
Try turning everything off, PC, Router, and Modem. Then turn on the modem, then the router, then the pc. Your modem needn to connect, then the router will be assigned an ip address, then your pc will acquire an ip from the router.
Jan 14, 2008 | Computers & Internet
IBM ThinkPad X60s Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
