Question about Ovens
The double oven works on top oven only, bottom over does not operate. Occasionally an error message comes on but usually bottom oven digital readout shows nothing. Do I just need a "selector switch with buss"? Seems to me that the control board must be working is one oven operates. If correct, how do I get access to the control switch? It looks like the front stainless panel must come off to unscrew the switch.
    Genius:
  • 1,417 Answers
what this error message means no the screen is that there has been a loose of wire from the connection or loose of wire from the element that i the heat provider (heater)on the below oven unit
the failure of the below oven has nothing to do with control switch from your statement or explanation .
what you will have to do to fix up the problem of the oven is to unscrew (open) the oven from the stroll with a stroll driver (tools) from behind then trace the wire (power connector from the switch ) down to the element beside (left or right)Conner of the oven silver in color to see if there is any form of loose wire from this position , if yes then you will have to fix up back to the element with care with out disconnecting any other wire from it position ,but is non the it then mean that the element will need a replacement
thank you and thanks for using fixya
Posted on Jul 19, 2010
I had to replaced the thermal fuse in my double wall oven top oven now works fine but the bottom oven does not heat up what could be the problem?
Hello Mr Samuels,
Do you have the model number of your oven? I'd be happy to help.
Please email us at info@fixyourboard.com
Jun 04, 2017 | Ovens
WE HAVE AN ELECTROLUX DD060GA DOUBLE OVEN THE TOP OVEN IS WORKING BUT THE BOTTOM OVEN DOESN`T EVEN COME ON WHEN YOU TURN THE KNOB THERES NO GAS AND NO SPARK AND THE LIGHT WONT COME ON EITHER, CAN YOU...
Good Morning Friend,
I understand that your Electrolux double oven, model# DD060GA, is having trouble with the bottom oven coming on. I also see that your top oven works just fine. This appears to be a UK Electrolux double oven. I suggest contacting the manufacturer directly. They will be able to better assist you in getting your bottom oven functioning correctly.
-Best Regards-
WP
May 21, 2014 | Electrolux EOG7330WN Gas Double Oven
Why my whirlpool GBD307 double oven top oven will not cut on, but the bottom one will. but after heating up, the oven starts blinking the start? button but it will not cut off, it shows a error code F
that's a bad touch panel or key panel,the number you sent isn't the full model number off of the oven so when you call to order the part you will need that.if you try to fix this yourself make sure the power is off.good luck
Nov 07, 2017 | Whirlpool GBD307PDS Electric Double Oven
F5 error code
F5 = EOC electronic control failure replace electronic control is stated in the service manual. If you have any further questions message me them back. Thank you
Rick
Nov 28, 2011 | Thermador SC302T Electric Double Oven
Cannot use self cleaning feature on Meile double wall oven. Get the same error message on the top and bottom oven. A giant F and fault 09.
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Oct 28, 2010 | Miele H398BP2 / H398B2 Electric Double...
TEMPERATURE READOUT NEVER REACHES POTENIOMETER DAIL SETTING.ELEMENTS ON OUR DOUBLE STACK 1132 IMPINGER ALL READ CONSISTANTLY 28 AMPS @ 208V.SWAPED THERMOCOUPLES BOTTOM TO TOP TEMP DISPLAY DID IMPROVE BY 50...
You could also check that the fingers are properly fitted in place at the point where thy join oven and the glass window is closed. make sure that all the elements are working well
Jul 30, 2010 | Lincoln Conveyor Oven - 1132-000-A
We have Smeg DUCO8CSS double electric oven. Bottom oven does not work, clock is blank and fan doesn't work. Top oven OK ! - though usually the fan runs when this is operating.
If the clock is blank, then the main oven will not work, as the clock timer is linked with the main oven.
You need to to get the clock working, or you will not be able to use the main oven
Jan 19, 2010 | Smeg DO81CSS Electric Double Oven
Frigidaire double ovens F8 error and beeping
good day,
hope this link below will solve your problem.
ovens
Mar 23, 2009 | Frigidaire PLEB30T8A Electric Double Oven
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
TOp Oven Light ..
if its a brand new unit (still in waranty) make the service call
Aug 30, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Ovens Logo
41 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
