Question about Mastercool 67471 Evaporative Cooler Air Conditioner
My evaportative cooler keeps blowing fuses - Mastercool 67471 Evaporative Cooler Air Conditioner
Master cool mcp44 making noise when turned past low setting this is a evaportive cooler
Worn motor bearings, bent fan blade or out of balance, many other issues like sheet metal vibration.
Jun 12, 2018 | Cars & Trucks
The 1 6/10 fuse keeps blowing on my evap cooler what could cause this?
dead short in the unit
have it checked at an appliance repair shop
Sep 17, 2016 | Cars & Trucks
I have recently bought a 40 qrt coleman eletric cooler. Has it one da y and dc plug stopped working. Replaced fuse, and checkes all volt outlets in truck as well as fuses in fuse panel they all work.
Did you accedently or spark power wires? These have a tendency to blow the diode if that happens. Also check fuse in plug of cooler. Take it apart an look sometimes the wires break.
Jan 11, 2015 | Coleman 40 Quart Powerchill...
Keeps blowing 25 amp fuse
you have a short. Use a test light to find it.
Dec 17, 2013 | 1998 Oldsmobile Intrigue
I have an evaportating cooler omega it only works on fan.
I would have the unit looked at. The auto section on the motor is turned on by the cooler automatically so there seems to be a problem there at that switch.
Good Luck on your repairs hope this helped some
Dave
Nov 09, 2009 | Heating & Cooling
How do I change the bearings in a Mastercool 2 evaportive cooler.
take it apart if it's all rusted your going to use a lot of bad words my self to get the old ones off i use a grinder cut them off careful not so cut the shaft and clean real good good luck. Tom
Jun 30, 2009 | Heating & Cooling
No air movement at evaportive
mother board problem . check with ge your might be one of the recalled for this . 1-800-GE-CARES
Jan 24, 2009 | GE Profile PSW26P Stainless Steel Side by...
Uline 2075WCS not cooling
Hi!! I'm a uline authorize servicer and yes the repair man is right. you have a leak in the evaporator..remember make sure to call uline ans see if you have warranty on your seal system of the wine cooler..good luck..
Jan 03, 2009 | U-Line 15WC Wine Cooler
Oster wine cooler fuse
I just replaced mine with a "Slo Blow" and it is working just fine. Got it at Radio Shack , 4 for approximately $3.
Sep 25, 2008 | Oster 12-Bottle Wine Cellar - Black
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
387 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Paul
Paul
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
