Question about Amana DLE330RAW Electric Dryer
Wiring The top of the dryer came off during moving i need to know the wiring diagram for the top of the dryer
  • Anonymous Nov 26, 2008
    i had to change the cord of the dryer because  the new place i moved into has a different socket. i wasnt able to memorize the colors before i took them out. now, i have to get into the front cover. hope i can find the wiring diagram.
    Problem Solver:
  • 14 Answers
It should be inside on the front cover of the dryer. I know, it's a pain to remove and get to. Not hard, just time consuming.
Posted on May 29, 2008
The wiring came off during a move
Posted on Dec 01, 2008
Need a wireing diagram for GE dryer mod. DWSR483EA ser. dd760646 a
I'll let you know if the diagram is available
Jun 16, 2008 | Dryers
Im in need of wiring diagram to model ex-81204. serial 9DJ50229.
unplug dryer, move it forward for you can access the back, take the top panel off there are like six screws and in the top left hand corner there is a diagram. provided no one has taken it out. Good Luck Tim
Feb 27, 2011 | Dryers
I need a wiring diagram for a Whirlpool GCEM2990LQ0 electric drier. Someone tried to work on it and messed up the wiring.
There should be a diagram in the tech sheet envelope on the rh side of the dryer cabinet as you open the top. If not here is the generic whirlpool wiring diagram:
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=653456&pkw_=basket&model_id=46651&NewWindow=1
I note this is a commercial dryer. I wanted to get something I think you can use to you ASAP. Let me know if the diagram does not work for you and I will dig deeper in the commercial service manual. .
Thanks for choosing FixYa,
Kelly
Nov 28, 2010 | Whirlpool Dryers
Need a wiring diagram for Kenmore 110.63102101 dryer
Here you go, this is for both gas and electric units, since your unit is electric use the top diagram
Kenmore 6210 Dryer wiring diagram
May 01, 2010 | Kenmore 400 6942 Dryer
Looking for dryer diagram
There should be a schematic on the inside of the back cover, sometimes it is located in the top control panel somewhere(timer panel)
Feb 22, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool gas model LGC8858EQ1 dryer works fine except the timer does not move.
ckd for wire from thermostat on rear of blower or high limit might be easier to look at wiring diagram wire is usually orange they have been known to come off voltage is feed to timer motor during auto setting from a thermostat
Jul 30, 2008 | Dryers
Maytag model MDE9206AYW will not heat. Checked coil, fuses and limits and am now trying to check cycling thermister. Can you tell me how? also do you have any suggestions. suspect dryer went out during...
My generic wiring diagram doesn't show this dryer uses a thermistor, only thermostats. The difference is a thermistor has to have an electronic control to interpret the values the thermistor is sending. A thermostat is mechanical and only open or closes at a preengineered temperature. You would need to check the ohm readings of a thermistor at different temperatures to test it, but you only need to know continuity or no continuity to test a thermostat. First make sure you have 240 volts to the dryer, the heater is the only part that needs 240 to run. It's possible for only half of the breaker to trip and give the dryer only 120 volts, in this case everything but the heater would run. If you've got 240 volts, to the dryer, unplug it, then check for continuity between the 2 terminals of the 2 thermal fuses, cycling thermostat, and hi limit thermostat and heater. Remember you must disconnect one wire before testing to prevent incorrect readings. If it still runs, just no heat, the 2 thermal fuses should be ok, but check them anyways. If they all test ok you'll need to check the temp selector switch. You'll need the wiring diagram to show which terminals to check at each heat setting. If that checks out you'll need to move to the timer, again you'll need the diagram. If the timer checks, the only thing left is the centifugal switch in the motor, and the only way to check that is to test it with the motor running.
Jul 18, 2008 | Maytag Dryers
Wiring harness diagram
which wires popped of exactly ??? the wires from light/door switch?? grey, white, black, wires???if so thats the order top to bottom
Mar 17, 2008 | Dryers
Amana DLE330RAW Electric Dryer Logo
136 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
