Question about Cobra 29 LTD CB Radio
The ANT light is not lighting up I don't know if I am broadcasting but I know I am not getting any response any ideas?
  • 1,514 Answers
The ideal way would be to check against another radio if possible. Failing that either use an swr power meter to show the forward power or a power meter. They can be bought cheaply on ebay.
Posted on Jul 19, 2010
My Denon Stereo Receiver (DRA-345R) (quite an old model but has worked perfectly up until now) has a very static reception on AM. FM is fine. It started when I had my DirecTV upgraded with a Genie (whole...
it's obviously getting interferance fronm that whole house broadcast unit (not abnormal!) best and only thing you can do is to move the stereo to a place where you can get the MOST am stations the loop ant. is exactly what it says it is a loop of wire with two ends..both ends connect to the ant. input on the back of the unit..however if that whole house broadcast unit is the devil then an ant. no matter what or how it's made will only recieve more static not built to reject static! so you've got to move it unfortunately ..fm is a totally different band obviously fm isn't being affected by that whole home broadcast unit..you're lucky! on that count
Dec 12, 2013 | Denon AVR-2307 Receiver
I have a flat tv olevia 332 b-11 my problem is that that I have no idea where the antena goes and the screen is blue and I don't know how to program the local chanels because is no hole in the tv
Ifyou look at the rear of the TV, you will see a round thing with threads on it. That's the antenna connector. You will probably see ANT or ANT INN marked nearby.
Dec 21, 2012 | Televison & Video
Hitachi 50v500 lcd rear projection just trying to get the setup so cable works on ant a can't make the channel move when im on ant a set up.
be aware this model has almost a 100% failure rate on the light engine which while not related to this issue should be kept in mind.
If you have cable get a box with a/v jacks on the back and hook to a rear input on the set--bypass the whole issue and get a better picture.
PS: I don't think it is the set itself causing this ........
Apr 03, 2012 | Hitachi Televison & Video
I'm not having a problem with my tv or the receiver, but there's a blue like that comes on every now and then on the receiver and I don't know what it means? Any ideas?
life_on_stan,
Our Duo receivers do have a blue light which represents the TV2. When that light is on the TV2 is no longer on a screen saver.
I would need more information on your equipment to provide further assistance.
Tommy Faust
DISH Internet Response Team
Jan 18, 2012 | DISH Network Televison & Video
Casio lk-33 does not work with external power adapter. The unit will work on battery power. The connector for the adapter provides power to the power board, but the unit does not work. I don't have a...
I once had this problem with another Casio synth.
I hadn't the power adapter ant I tried with an other one, with the same specifications : the synth was apparently powered but it didn't work.
I finally understood that it was a problem of polarity (+/-). You may just have to cut the cable and resold it inverted.
Hope it could help!
Nov 05, 2011 | Casio LK30 Note Lighted Keyboard
My 85 Cavalier just quit running on e way No response to ign switch, wdows, seats door locks, inst lights, radio, htr fan, don't work. Hd lights do work Any ideas
CHECK SEE IF YOU HAVE BATTERY VOLTS SHOULD HAVE 12.6 VOLTS AT BATTERY IF NOT SOUND LIKE ALTERNATOR FAILURE.CHECK ALTERNATOR FUSE AND WIRES FOR DAMAGE.
Nov 01, 2011 | 1985 Chevrolet Cavalier
I have a red ANT light i can move my ANT coax on the back of my radio and it cuts the light on and off. any idea what this means
This is telling me that there is possibly a problem within the PL 259 connector ................cut off the connector and redo making sure there is no shorts. THis ....THE SHORT IS SHOWN BY THE ANT WARNIG LIGHT COMMING ON...........NO LIGHT......NOT SHORTED OR OPEN CABLE / CONNECTOR.
Sep 20, 2010 | Cobra 29 LTD CB Radio
Will my v 8600 work with an antenna after switch to digital broadcasting
Yes.  You'll just run the connections through the dig converter box...instead of however it's connected now.  ANT In/ANT out.
Sep 22, 2008 | Samsung DVD-V8600 DVD Player/VCR
Aerial replacement eu falcon
NOT AT ALL .....IF YOU ARE TALKING ABOUT A BASE STATION ANT.....FIRST GET A GOOD ANT ......GET THE MAST TO PUT IT ON ..1 OR 2 MAST.. YOU MAY WANT TO USE SOME GUIDE WIRES..IT'S A GOOD IDEA......MAKE SURE TO GROUND THE ANT..WITH A LIGHTING ROD THAT GOES INTO THE GROUND.....GET SOME BASE STATION COAX.........GET A SWR METER A CHEAP ONE FROM RADIO SHACK HOOK EVERY THING UP CHECK YOUR MATCH WITH THE METER AND YOUR GOOD TO GO........WHERE YOU PLACE THE ANT ON YOUR HOUSE WILL MAKE A
BIG
DIFFERENCE IN HOW THE ANT WILL PERFORM PICK UP A CB RADIO BOOK @THE LIBRARY OR LOOK INTO ONLINE
Apr 20, 2008 | Radio Communications
Cobra 29 LTD CB Radio Logo
52 people viewed this question
Top Cobra Radio Communications Experts
Steve
Steve Allison
Steve Allison
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
