Inserted dvd but machine still says close maybe 1 in 50 will play all others same message. Close
    Genius:
  • Televison & ... Master
  • 1,689 Answers
Try cleaning the laser lens. If the laser gets some dust or dirt on it, its reliability to read disks is decreased.
eHow To Clean DVD Laser:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
With age and use, the emission of the laser can decrease. With this event, the ability to read disks decreases.
Check to see that nothing is binding and that the mechancal part of it is functioning smoothly.
Jerry G.
Posted on Apr 21, 2008
Hyundai 320-A dvd player codes
Hyundai DVD-320A / DVD-360A / DVR-510C
  1. Method 1:
  2. Turn on the player (without a disc inserted)
  3. Press 7, 7, 0
  1. Method 2:
  3. Press 7, 7, PLAY
  4. Select region (0 = multi-region)
  5. Press SETUP
  1. Method 3:
  2. Open the disc tray
  3. Press 3, 8, 0, 0
  4. Select RC (0=codefree)
  5. Press SETUP
  6. Close the disc tray
Apr 20, 2016 | Hyundai Televison & Video
Tip
If disk door wont open - stays locked
I called Samsung who suggested pushinhg the play button on the panel and the power button on the remote together. "No disc" eventually showed on the screen and pushing the open/close door button worked.
However, my remote wouldn't work, even after changing batteries.
The machine did play. Unfortunately, later that night I tried another DVD and it locked up again. The next day I tried the above 2-step and it worked again, so maybe the other DVD caused trouble. But I cant get my remote to do anything except the 2-step listed above.
I don't use the player very often.
on Aug 02, 2010 | Samsung DVD-P241 DVD Player
Recorded DVD. It will play back on the camera but not on dvd play
need close sesion on disc with the same camcorder, when close sesion the mini dvd can't record more video
Feb 02, 2010 | Panasonic Video Cameras
Discs won't play.
please change laser unite then solve your problem
Jul 16, 2009 | Sony DVP-NS575P DVD Player
After loading, disc error is displayed when dvd is inserted
hello i have had the same problem this maybe because of the region that your dvd is made to play.different dvd players play different.region dvd the regions should be on the dvd and the dvd cover.
Apr 25, 2009 | Televison & Video
H02 Error after inserting a dvd disk
The trouble started with an error to close and open the DVD drawer. It indicated "close" when the drawer was open, or "no disc" when the DVD was inside, and I had to try many times before I get the right response and go on with the procedures.
But then it also started playing just a few MP3 tracks and stopping to work, showing again the inserted DVD data. Later H02, and then H07 and STOP. It doesn't even start playing stuffs, movies or MP3 tracks!
Aug 11, 2008 | Panasonic Televison & Video
Dvd player
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Jan 14, 2008 | Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
NeXxtech ESDVD100 DVD Player
it would help to know what machine your playing these in . your media seems to be have recorded inna different format maybe your discs are not burned properly maybe theres a fault in your machine i would take it back to the shop or the media back the shop oh and if burning you must not use ne other program its probably your using media that is not finalized or your machine isnt designed to play them discs your using
Jul 31, 2007 | NexxTech ESDVD100 System
My SD1009U not sensing the DVD.
Some of the panasonic models had motor problems that cuased them to start not reading disks and give a error code on the display. Maybe yours just has a dirty laser pickup and you MIGHT be able to gently clean it off and see if it will play again, other then that it might well be worn out. most newer machines have a dual laser pickup, one is tuned for pressed cd's and DVD 's and the other is tuned for cdrw and dvdrw style disks.
Nov 18, 2005 | Toshiba SD-1009
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
