Question about Samsung LNT3242H Television
The color on my Samsung LNT3242H TV suddenly is
HELP!!!!!!!!!! The color on my Samsung LNT3242H TV suddenly is horrible. I adjusted the settings using my remote, but colors are still way off. The other day when I turned on the TV, all the color in people's skintone was drained, hair is sunflower yellow and lips are greyish/blue. What is the problem? And how do I correct it? Thank you!
    New Friend:
  • 60 Answers
Go to settings in menu and Reset to Factory settings...Hope this works
Posted on Oct 27, 2017
circuitcity
  • 137 Answers
SOURCE: One year old Samsung digital has green color tint; reset doesn't work
One of two scenario. One, you have a bad LDS cable. This cable is found inside the set. This is the cable that is plug into the panel, The other end is plug into the main board. This cable may also just need cleaning. The end that plug into the Panel may have some glue put on it to keep it from getting loose. You may want to unplug it and try cleaning it . Two, You may have a bad panel. In that case you may want to consider getting a new set.
Best regards
CircuitCity
Posted on Dec 06, 2007
zjut
  • 106 Answers
SOURCE: Samsung LNT3242H
Try to change the aspect ratio of your tv to see which is better fit for you.
Posted on Jan 01, 2008
  • 103 Answers
SOURCE: Color bad
You might want to check the component cables to make shure they are firmly seated.
Posted on Mar 05, 2008
TBlessed 1
  • 61 Answers
SOURCE: Sony T240HD monitor TV
make sure that the plug on ps2 is connected and check the settings on tv and the settings on ps2 browser are correct if possible check ps2 on another tv to be sure of it's settings if the ps2 works the check channel setting on tv make sure it's not in pal setting it should be ntsc and also check the antenna setting make sure it might be set to cable and also check cables of any sharp kinks your problem is with the yellow cable red and white is the sound
Posted on Dec 01, 2008
  • 98 Answers
SOURCE: Only color is yellow and blue
go to menu & select the picture mode with standard
then go to detail setting , change the off-set value of r(red)
Posted on Feb 06, 2009
Problems with colors and display on my Samsung LN37A550P3FXZA flat LCD.
Replace all busted capacitors in power supply board inside.
Jan 10, 2014 | Televison & Video
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
Screen dim, black has green in it, contrast and brightness = shin
Since you have replaced the Color Wheel, it sounds like you have not adjusted the Index Delay in the service menu. First reset all of the picture settings you have adjusted back to original factory settings. Then on your Samsung TV Remote and with the TV OFF, Press Mute,Power,123. This will turn on the set and put you in the Service menu. Look for the top setting and select or scroll to the OPTION setting and select and look for INDEX DELAY and select that. Once you have the Index Delay selected use the right and left buttons on the remote to adjust for a picture the has no abnormal coloring and while looking at a program adjust for when the blacks look black with no abnormal coloring. Once that is done, turn off the set then turn the set back on. Now the picture should look normal.
Apr 03, 2010 | Samsung Televison & Video
Replaced the color wheel on a Samsung DLP
Did you replace the color wheel yourself ? Sometimes you have to remove a small black jumper on the DM module on the light engine and that will remove the greenish but sometimes adjustments also need to be made in the service menu.
Oct 30, 2009 | Samsung HL-R4667W Rear Projection...
Bad color scheme - cannot adjust enough
If you haven't already done so, it may be that all you need to do is adjust the convergence after moving the set. You should find convergence and its adjustments in the setup menu
Feb 25, 2009 | Samsung HC-P4741W 47" Rear Projection...
Samsung HL-R6167W DLP color problem/buzzing noise
My 3 yr old Samsung DLP has the same buzzing noise, had a tech out today and he said "color wheel". Thank goodness I purchased that expensive warranty, This is my 4th repair in 3 years.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Dec 17, 2007 | Samsung LNT3242H Television
Colors are horribly misaligned... Do not have manual convergence...
Have you entered "Mute-> 1 -> 8 -> 3" to get to the remote convergence menu? There you can manipulate each color, null convergence, load last saved and make corrections. From this menu you should be able to determine if one or more convergence failures have occured.
Dec 01, 2007 | Samsung HC-P4363W 43 in. TV/DVD Combo
Televison & Video Logo
230 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
