Question about JBL S120PII Subwoofer
No sound JBL 10'' POWERED, MODEL SUB 10, SKU7706477, BTP 2677695969,SERIAL 0406, PURCHASE 8/2006 Power is on, rumbles when system is tested, but makes no sound when the system is in use. 'Volume'' is turned all the way up. Thanks, Chas
SOURCE: jbl PB12 powered sub woofer problem
These subs have had many problems, all associated with the amplifier section. PB 12's with an "M" as part of the ser. no. were assembled in Mexico and these are the ones with the amp problems. JBL fixed mine and sent it back no charge, BUT it cost me nearly $100 to send it to them in the first place. I have another one that has had no problems at all. Try sending it back for repair. At best you'll get a rebuilt unit back, at worst a substantial discount from the company for a new sub.
Posted on Aug 09, 2007
if your serial number starts with ha then it's probably a bad capacitor C72 . 6.8uf 100v np electrolytic. replace it with a higher voltage capacitor of the same value.
Posted on Jan 05, 2008
SOURCE: JBL Sub 12 continues to make clicking noise
check the audio amplifiers of the sub
Posted on Jul 13, 2009
MECP Guy
  • 344 Answers
SOURCE: My jbl venue series subwoofer 10 keeps making a popping noise
sounds like the capacitors need to be replaced make sure you replace them with the same value mF
Posted on Feb 15, 2010
SOURCE: My JBL Venue Sub 10 light stays red, will not
i have the same problem. don't as yet have a solution
Posted on Apr 17, 2010
Jbl rumble no power power connector. Is ok
Possible blown fuse on the plate or possibly inside the sub cabinet
Jul 11, 2016 | JBL Audio Players & Recorders
JBL subwoofer not giving sounds even it is correctly connected
If this is a powered sub, than it will have it's own power supply and small mono amp, both of which can fail. Could be a fuse, but if the fuse blows again you will have a short on the main amp board.
Nov 20, 2015 | JBL Audio Players & Recorders
JBL JRX118SP POWERED SUB. Getting power and signal light flashes when theres a signal. Just no sound??? Speaker/coil looks fine..
There's a 8-pin ic located right at the side of output devices & power supply filter caps, that is a common issue with JRX active subwoofers, hope it helps.
Jan 29, 2012 | JBL JRX 115 JRX115 15 JRX118s 118s Speaker...
I bought a sony receiver,but i can't connect the sub from JBL on to it?
If the model ??? JBL sub is self-powered like most just run an RCA cable from Sub Woofer Audio Out to it and select YES for Subwoofer in the setup menu.
Jun 08, 2010 | Sony STR-DE445 Receiver
Can this all be hooked up?
There was never anything mentioned about the 18 yamaha sub in the hook up process
Aug 17, 2009 | Crown CE1000 2-Channel Amplifier
JBL Subwoofer - Intermittent operation
Sometimes bad caps show a lifting or rounding of the top of the cap, sometimes this top will split from heat and pressure and sometimes it will not show any sign of damage but will be dry inside and its capacitance value will drop to a very low value. Replace the big power supply caps and test again. Get the same size, value and voltage rating. You can go higher on voltage rating and a bit on value. Getting a similar size or something that will fit in the same space is important also.
Jul 20, 2009 | JBL PB10 Subwoofer
Subwoofer not powering enough (Sounds like under powered 8inch)
get a nice monster subwoofer cable and a Subwoofer PowerCenterâ„¢ SW 200 with Clean Powerâ„¢ Stage 1 get it from like amazon and you'll definately see a difference and also put the sub in like a corner
Jun 08, 2008 | JBL S120PII Subwoofer
Jbl PB12 powered sub woofer
Mar 10, 2007 | JBL PB12 Subwoofer
JBL S120PII Subwoofer Logo
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
