Question about SuperMicro P4DC6 with FERRET RESISTORS (MBD-P4DC6+PL-P) Motherboard
Haw to learn more as an auto body manager i want to be tot on haw to start a vehicle
    President:
  • 2,571 Answers
Try google (car repair)
Posted on Jul 19, 2010
Cannot get my 2009 colorado into program mode to set tps sensor
What engine ? Are you talking about Throttle Learn ? Did you replace throttle body ?
The engine control module (ECM) learns the idle position of the throttle plate to ensure the correct idle. The learned airflow values are stored within the ECM. These values are learned to adjust for production variation and will continuously learn during the life of the vehicle to compensate for reduced airflow due to coking. Anytime the throttle body airflow rate changes, for example due to cleaning or replacing, the values must be relearned.
A vehicle that had a heavily coked throttle body that has been cleaned or replaced may take several drive cycles to learn out the coking. To accelerate the process, the scan tool has the ability to reset all learned values back to zero. A new ECM will also have values set to zero.
The idle may be unstable or a DTC may set if the learned values do not match the actual airflow.
Throttle Learn
With Scan Tool-Reset
Ignition ON, engine OFF. With a scan tool, perform the Idle Learn Reset in Module Setup.
Start the engine, monitor the TB Idle Airflow Compensation parameter. The TB Idle Airflow Compensation parameter value should equal 0 percent and the engine should be idling at a normal idle speed.
? If the engine is not idling normally, proceed with the Learn portion of the diagnostic.
Clear the DTCs and return to the diagnostic that referred you here.
May 16, 2017 | Cars & Trucks
What is relearn predcudre for idle on 08 chev. 1500 5.3 eng.
Throttle Learn
Description
The engine control module (ECM) learns the airflow through the throttle body to ensure the correct idle. The learned airflow values are stored within the ECM. These values are learned to adjust for production variation and will continuously learn during the life of the vehicle to compensate for reduced airflow due to coking. Anytime the throttle body airflow rate changes, for example due to cleaning or replacing, the values must be relearned.
The idle may be unstable or a DTC may set if the learned values do not match the actual airflow. Without Scan Tool - Learn Procedure
• DTCs P0068, P0101, P0102, P0103, P0106, P0107, P0108, P0116, P0117, P0118, P0120, P0122, P0123, P0128, P0171, P0172, P0174, P0175, P0201, P0202, P0203, P0204, P0205, P0206, P0220, P0222, P0223, P0300, P0351, P0352, P0353, P0496, P0601, P0604, P0606, P060D, P0641, P0651, P1516, P2101, P2119, P2120, P2122, P2123, P2125, P2127, P2128, P2135, P2138, or P2176 are not set.
• The engine speed is between 450-4,000 RPM.
• The manifold absolute pressure (MAP) is greater than 5 kPa.
• The mass air flow (MAF) is greater than 2 g/s.
• The ignition 1 voltage is greater than 10 volts. Without Scan Tool - Learn Procedure
Important: Do NOT perform this procedure if DTCs are set. Refer to Diagnostic Trouble Code (DTC) List - Vehicle.
Start and idle the engine in PARK for 3 minutes.
The ECM will start to learn the new idle cells and Desired RPM should start to decrease.
Ignition OFF for 60 seconds.
After the 3 minute run time the engine should be idling normal.
Important: During the drive cycle the check engine light may come on with idle speed DTCs. If idle speed codes are set, clear codes so the ECM can continue to learn.
? If the engine idle speed has not been learned the vehicle will need to be driven at speeds above 70 km/h (44 mph) with several decelerations and extended idles.
After the drive cycle, the engine should be idling normally.
? If the engine idle speed has not been learned, turn OFF the ignition for 60 seconds and repeat step 6.
Once the engine speed has returned to normal, clear DTCs and return to the diagnostic that referred you here.
Dec 18, 2016 | Cars & Trucks
How to reset security light after installing a new ignition switch
Due to component variability, the vehicle theft deterrent (VTD) system must have the learn procedure performed regardless, if the vehicle starts on the first ignition cycle after a VTD repair.
You must perform a theft relearn procedure if any of the following components have been replaced:
  • Passlock sensor
  • Body control module (BCM)
  • Powertrain control module (PCM)
The above modules, with the exception for the Passlock Sensor must also be programmed with each module's own vehicle configuration.
Auto Learn:
Time required, approximately 10 minutes.
  1. Insure that the battery is fully charged.
  2. Use the scan tool in order to clear the DTCs.
  3. Turn the ignition switch from the OFF position to the CRANK position attempting to start the vehicle. The vehicle will start and then stall.
  4. Leave the ignition switch in the ON position while observing the security indicator.
  5. When the security indicator turns off, which can take up to 10 minutes, turn the ignition switch off. Wait 10 seconds.
The BCM and the PCM will learn the new code on the next start attempt.
Jul 17, 2011 | Chevrolet Silverado 1500 Cars & Trucks
How hard is it to replace a emc in a 95 jimmy 4.3 vortec
I assume you are referring to the ECM. The ECM is fairly simple to replace on this vehicle. It is located on the passenger side of the vehicle under the kick panel just under the glove box. Disconnect the battery and remove any static from your body by touching a metal part of the vehicle. It would be in your best interest to get a grounding strap that goes on your wrist and clips to a metal ground. You can get them at your local Radio Shack. Once you have grounded yourself the ECM can be removed from its mounting bracket and the electrical connections removed. Ground yourself again prior to touching the new ECM, connect the electrical connectors to the the new ECM and re attach it to the mounting bracket. Re-connect the battery, start the vehicle. The vehicle may idle rough for a few minutes while the ECM "learns" the engine systems. Drive the vehicle conservatively for the first 15 minutes to allow the ECM to continue to "learn". If you have a " CHECK ENGINE" light the problem can be retrieved for FREE by visiting you local AUTO ZONE or other auto parts store. Good luck. If you can hook up a VCR or a DVD player you should be able to handle this without much difficulty.
Mar 12, 2011 | GMC Jimmy Cars & Trucks
Haw i can connect my kcassette player arx8270 in my car
The best way is to locate a wire harness for your particular vehicle at the local auto parts. Then connect the harness from your radio to this harness and then plug into your vehicle. If your vehicles harness is cut then I will need to know what particular Toyota you have.
Aug 17, 2010 | Toyota Car Audio & Video
Can i get a new ignition switch for my 1999 LS will the sensors be affected?
Yes you can install and new ignition switch in your Blazer, once you have installed the new switch, your going to have to do a PASSLOCK II relearn for the new ignition key's to start the Blazer.
PASSLOCK - Reprogramming Auto Learn
IMPORTANT:
* The Body Control Module (BCM) must be programmed with the proper RPO configurations before performing learn procedures. See BCM Programming/RPO Configuration.
* If replacing the BCM with a GM Service Parts Operations (SPO) replacement part, the module will learn PASSLOCK sensor data code immediately. The existing VCM/PCM however, must learn the new fuel continue password when the BCM is replaced.
* If replacing a VCM/PCM with a GM Service Parts Operations (SPO) replacement part, after programming, these modules will learn the incoming fuel continue password immediately upon receipt of a password message. Once a password message is received, and a password is learned, a learn procedure must be performed to change this password again. A VCM/PCM which has been previously installed in another vehicle will have learned the other vehicle's fuel continue password and will require a learn procedure after programming to learn the current vehicle's password.
CONDITIONS
Use this procedure after replacing:
* Passlock Sensor
* BCM
* VCM
* PCM
30 MINUTE RE-LEARN PROCEDURE
1. Turn ON the ignition, with the engine OFF.
2. Attempt to start the engine, then release the key to ON (vehicle will not start).
3. Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF.
4. Turn OFF the ignition, and wait 5 seconds .
5. Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes (the vehicle is now ready to relearn the PASSLOCK Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK). IMPORTANT: The vehicle learns the PASSLOCK Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
6. Start the engine (the vehicle has now learned the PASSLOCK Sensor Data Code and/or password).
7. With a scan tool, clear any DTCs if desired (history DTCs will self clear after 100 ignition cycles).
Thank you foe using Fixya
Mar 20, 2010 | 1999 Chevrolet Blazer
Spark plug diagram mazda milliean 2.5l v6 motor need tot know where number 1to six goes.
You can get a diagragm of the engine layout, distributor rotation and wire routing at Auto Zone or one of the other auto parts store. Should be free.
Mar 15, 2010 | Spark Plugs BR4HS Plug 10/BX #3322
Computers & Internet Logo
26 people viewed this question
Top SuperMicro Computers & Internet Experts
David
David
Victorman
Victorman
Joseph Hoffmann
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
