Question about Hitachi 53SDX89B 53" Rear Projection Television
I have a hitachi 53SDX89B model rear projection. I was recently trying to have it connected to ATT Uverse TV. Every time the tech hooked the DVR receiver to one of the inputs, it knocked out the service. We tried two different receivers, but it was the same on both. The problem occurred a few seconds after the TV is turned in, no matter which input is used. The Tech said there was power back feeding out of the inputs. Can this board be replaced and what is the PN? Does any of this make sense?
  • jsweney310 Jul 20, 2010
    I don't understand how putting the isolation transformer on the incoming line will affect the A/C leakage on the video inputs.
    President:
  • 1,961 Answers
All inputs of the tv's are zero voltage I think the problem must be on the DVR reciever because you already try two units and same thing happens.the tech must see the compatibility of the TV and the reciever there must be a problem in there...
Posted on Jul 20, 2010
  • 10,594 Answers
Hitachi 53SDX89B is September 1999 model as its mentioned on its service manual that I have.
Since tv is too old so I'm afraid, no spare boards or parts would be available any more to fix its AC leaky current issue that damaging ATT U-verse service. (power back feeding out, we call it AC leakage).
There is one solution for that problem, buy Isolation Transformer and plug your tv in it, that will cure AC leakage from your tv and wont hurt any thing attached/ connected with this tv. Your tv consume 245 Watt power while working so 500 Watt isolation transformer would be good enough to keep turn On tv for hours/ days.
Below is an image of basic isolation transformer and click HERE to get required 500W isolation transformer.
Hope these info will help you.
Thanks.
Posted on Jul 19, 2010
  • Shahid Electronics
    Shahid Electronics Jul 20, 2010
    OK, no problem, I tried to explain that.
I am hooked up to At&t uverse through a DVR. It works fine except when HD light on DVR indicater comes on then TV and sound go blank. Could it be that this TV doesn't support HD?
Some DLP tvs support HD some don't.Easy to find out.Ur tv have any HDMI ports for the HDMI cables to hook up in?Yes,it support HD,no HDMI ports,than it dosen't support HD.
Oct 26, 2010 | Sony KP-53HS30 53" Rear Projection...
My Hitachi 53SDX89B is showing double. It has a bow effect going on that shows red and green
It is a convergence problem (see attached photos) and total parts cost if you can do it yourself will be under 25 dollars--I know where to buy the parts at the best cost and how to do the repair.
Let me know if I can assist you with a comment here and if this information helped, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 26, 2010 | Hitachi 53SDX89B 53" Rear Projection...
I have a Hitachi rear projection 53sdx89b tv and the colors do not line up. what is it and how do I fix it?
hello it sound like convergance ic may be the problem usually they are fittted to right hand side of the tv behind he tuner board 2 large black chips connected to a metal frame called a heat sink .after time these over heat go open / short circuit.also you may have to check the resistor in front of the ic and any capacitor near by it would be best to get a quote from an engineer i hope this helps
regards
shaun
Mar 27, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Need att remote control mfg. no. for magnavox tv
i do not think it would work with your tv. there has been problems when tech installed uverse on dozens of tv. you can try to purchase an universal remote and see if that works. it is just like a jvc vcr/dvd player/recorder which will not work with any tv but jvc. you can also call att tech to help
Mar 05, 2010 | Televison & Video
My philips tv is hooked up with att uverse. i want to play my ps3 on the tv and when i plug it in nothing works i cant here or see the game. the same thing happens with regular tv eexcept i can hear sound...
hi! just a tip try to check on the video connection if it is plugged properly or if it is on the right port, try to check on the input as well. hope this helps! goodluck!
Dec 21, 2009 | Philips 60PP9202 60" Rear Projection...
I have 3 att uverse cable boxes...1 being the dvr unit. The room with the dvr unit only shows a black screen with live tv? When I go to watch a recorded show it works in the other rooms but is a black...
Is the cabling from the satellite receiver to the DVR hooked up right. It sounds like it's in single mode, but with the coax cable put on the wrong way.
Nov 23, 2009 | Computers & Internet
How to connect DVR 1600 to LCD HD TV or ATT uverse recorder
has to be scarts, your reciver (sky, cable ect ect) to your dvd recorder, from that to the tv, all scarts, might help, regards mark
Feb 01, 2008 | Cyberhome DVR 1600 DVD Recorder
CONVERGENCE
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Dec 14, 2007 | Hitachi 53SDX89B 53" Rear Projection...
Hitachi 53SDX89B 53" Rear Projection Television Logo
137 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
