Question about Saniflo Home
My saniflow is pumping to a fall and when flushed it blows the plug out of the sink i fitted air admittancs valves as recomended , how do i solve the problem
    Scholar:
  • 122 Answers
You have a venting issue, air admittance valves are not for venting purposes, although they do work in some situations.
you may need the services of a plumber to solve your venting issue.
Posted on Aug 20, 2010
Dishwasher would not drain
Your drain line some where is plugged or kinked. Try taking it off from under the sink where it is attached and blow should blow water or air into the dishwasher if not plugged
Mar 10, 2014 | Kenmore Dishwashers
Toilet wont flush
Here is a nice link for your saniflow maintenance.
http://www.plumbteamltd.co.uk/sanifloguide.html
This will may help.
Oct 22, 2012 | Saniflo Sanicompact 48 - One Piece Toilet...
Saniflow pump keeps comming on without flushing toilet
Water pressure makes the unit kick on and off. If it's turning on by itself then most likely somehow water is draining back into the pump. It could be leaking water from the toilet tank, to the bowl and from the bowl to the pump. Or the check valve inside the discharge elbow may not be closing all the way down and is allowing waste water to drain back into the pump creating enough water pressure that makes the pump kick on and off. Inspect the flapper on the flush valve and the check valve on the discharge elbow on top of the macerating pump.
Aug 22, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
My saniflow dosnt allways come on when you flush
That can be a problem with the pressure chamber, the membrane might be warped or the micro switch may be defective. Open the lid and remove the motor and presure chamber. Inspect the unit for damages or any broken pieces. Check that the membrane is not warped. This can be tested manually by placing the motor on a work bench and putting pressure on the membrane to manually start the pump on and off. If parts are needed you can buy them through Saniflo directly. Their website is www.saniflo.com
Jul 13, 2010 | Saniflo 013/003/005 Sanibest Toilet with...
Saniflow pro xr keeps running and blowing trip fuse any idea's
Mine did this, have you tried using a drain cleaner to break up any blockage? I had to unblock the outlet pipe by connecting a garden hose and flushing it out.
Mar 15, 2010 | Saniflo & Saniplus& Macerator Pump
1997grand voyager is blowing cold air new thermostate water pump and the raditor and heater core has been back flushed it started blowing hot air again then went back to blowing cold air again
I would look for a vacum leak on the control valve for the heater. There are 2 lines from the radiator leading back to the firewall. One has a control valve on it that should be vacum controlled. When you back flushed to the heater core you may have forced this valve open temporarily. The control may have low vacum or insufficient vacum to open a stuck valve. The good news is you can actually manually open this valve and tie it in the open position which will at least temporarily solve the problem. Check your vacum lines for leaks and check the valve to make sure it isn't sticking.
Jan 21, 2010 | 1999 Plymouth Grand Voyager
Water leaking out of breather
I have a question, I have a saniplus no problems hooking it up filled the tank and then flushed it..On the discharge end I had a small about of water puddling up at the pressed in rubber fitting. Every clamp was tight not sure what the reason is any ideas. I thought about silcone around the rubbber seal between the lid.
Sep 08, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
My saniflow toilet is blocked and a plumber has told me i need a new motor. where can i get this and how much are they?
If you hear it making noise the motor isnt blown, but it could be clogged.
A quick an easy fix is by filling a 5 gallon bucket with hot water (or warm water) and slowly pouring it into the bowl. The warm water breaks the particles up further, and will help flush the unit out. Make sure you run the water alot after its cleared out (to flush the debris). You can do that by turning on the shower or sink (if connected). If you dont have a shower or sink just keep flushing the toilet.
Sep 03, 2009 | Saniflo Sanicompact 48 Toilet With Pump,...
Home Logo
120 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
