Question about Linksys Computers & Internet
Wireless Connection Conflict
I am running a Linksys WRT320N wireless router, when our XBOX 360 is online and we connect our IBM ThinkPad T40 their 2 wireless connections interfere with each other. The T40 is connecting using Windows XP Wireless Connection, the IBM ThinkVantage Technologies connection doesn't pick up ssid broadcast from the Linksys router. Linksys, IBM and XBOX techs have not been able to give me any assitance. Anyone have any thoughts on resoving/fixing the conflict/interference? Thanks .
I would enable/disable your mac address clone. Do the opposite of what ever the setting is. You should be able to the setting on the main setup page. If it does not fix it, change it back. I know that can cause a connection to quit working if the setting is not correct.
Posted on Aug 12, 2010
Cant connect Xbox 360 to this wireless router
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings." Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.) Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP. Save your settings and verify the network is functional. On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live. On the Xbox 360, use the "Test Xbox Live Connection" option instead.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 15, 2011 | Linksys WRT160N Wireless Router
Cant find a strong enough connection
You need to buy a Linksys Wireless-G Range Expander to boost the signal
  • Move your wireless router to a central location in your network, keeping in mind that the router should be at waist level at the very least, not on the ground.
  • Plug in the Linksys Wireless-G Range Expander in the room where your wireless router is. You'll move the range expander later, but for setup purposes, it should be in the same location as your wireless router.
  • Press the Linksys Wireless-G Range Expander's "Auto Configuration" button for five seconds, which will allow the range expander to detect your wireless network and configure itself with the appropriate settings.
  • Unplug the Linksys Wireless-G Range Expander and relocate it to a location closer to the Xbox 360.
  • Ensure that the antenna for the Linksys Wireless-G Range Expander is pointing upward, and keep in mind that the higher the range expander is placed, the better performance you will get out of it.
  • Plug the Linksys Wireless-G Range Expander back in, and your wireless network should have a much greater range, ensuring that your Xbox 360 is able to maintain a good connection to the network.
  • Dec 29, 2010 | Microsoft Wireless Network Adapter Xbox...
    I cant get a wireless connection on my IBM R40 using a Linksys G
    I had the same problem with my R40 (2681) and a Linksys G router. The specs on IBM's/Lenovo's site indicate that the wireless card in the R40 only handles certain types of wireless encryption. The newer types (e.g. WPA) won't work on it and they are usually the standard on routers nowadays. My Linksys G router works fine with the R40 with WEP or with no encryption. Not ideal, but that's life with an old laptop.
    Dec 14, 2009 | IBM ThinkPad T40 2373 Notebook
    How to connect to xbox live with linksys router
    Just to confirm you are using a wireless connection to hook up to the router? do you have the router model number? Have you configured the correct wireless settings on the 360? Make sure that if you have a key that you have entered it correctly. http://support.xbox.com/support/en/us/xbox/xboxlive/getconnected/setupahomenetwork/stepbystep.aspx
    also you can use the xbox support site for reference, use the left side panel to look at wireless settings and other help.
    Thank you,
    Lee
    Oct 21, 2009 | Microsoft Wireless Network Adapter Xbox...
    Need wireless connection driver
    it should be on your recovery disk that came with computer when it was bought new if you dont have that disk try windows update to fine it
    Mar 26, 2009 | IBM Thinkpad T30 Notebook
    I am having problems with my dsl router
    id say yes it can be done by folowing these steps on both xboxes
    1. Make sure your wireless router is correctly connected to your Internet access and is broadcasting the wireless signal.
  • Step 2 Connect the Xbox 360 console to a Microsoft-manufactured WiFi adapter with a USB connection. This is different from an older Xbox console, which required an ethernet connection.
  • Step 3 Turn on the console and navigate to the Wireless Settings menu. Go to "System - Network Settings" and then finally to "Edit Settings."
  • Step 4 Configure the console's SSID to match that of the router. The SSID will be pre-selected and appear on the Xbox's display if the router is set to broadcast the SSID. Go to "Specify Unlisted Network" and enter the SSID.
  • Step 5 Set the Network Mode to "Infrastructure."
  • Step 6 Set the security of the Xbox 360 to match the router's security. Set the console to WEP or WPA encryption, whichever one the router uses, and enter the router's encryption key.
  • Step 7 Save all your settings after configuring them. Confirm that the console is connected to the network by going to the "Test Xbox Live Connection" option. This will tell you if your wireless connection is working.
  • Feb 20, 2009 | Linksys EtherFast Cable/DSL Router
    Can't pick up wireless internet through router
    You need to have the specific wireless adapter made for the Xbox 360. It runs about $100. Other wireless adapters (for some reason) will not work. I tried 6 different ones before I gave up and hard wired the Xbox 360.
    Jan 03, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
    Problem using XBOX 360 Live and Linksys WRT160N
    You need to reconfigure the wireless settings of your xbox. First, verify if you xbox can connect online by using ethernet cable. If it works that way, the only thing that you need to reconfigure is the wireless settings of the xbox. Make sure you have the same SSID and encryption key with the new router.
    Nov 21, 2008 | Linksys WRT160N Wireless Router
    Xbox 360 live on wireless router
    In theory you should be able to "share" your internet connection. I use a Linksys WRT54GS wireless router and I have a Linksys Game adapter on my son's 360. He has not complained about lag or slow server times unless other intensive bandwidth is being used.
    Nov 09, 2008 | Microsoft Xbox 360 Console
    Xbox 360 wireless adapter connection
    Try resetting your router and reconfiguring. Secondly try using a different wireless security mode that the 360 adapter supports. If the router is a linksys, that could be the problem. Linksys has a very common drop problem. I have found that D-Link has better integrity for wireless devices. Also try putting another device on the network via Wireless, if the same result, replace the router. Also, you can do a search on google for wireless router tweaks, to optimize the router for and xbox wireless connection. One more thing. be sure you force an ip address for the adapter in the settings area on the 360. That promises the same IP everytime it connects. Then go into your router configuration and forward the ports for xbox live, the wireless connection may not even be dropping, but a port problem with live while trying to authenticate your game system
    The following ports must be available for Xbox Live to operate correctly:
    • UDP 88
    • UDP 3074
    • TCP 3074
    Jan 06, 2008 | Microsoft Wireless Network Adapter Xbox...
    Computers & Internet Logo
    94 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
