Question about PfaFF Tiptronic 2040
My reverse button only works intermittently. - PfaFF Tiptronic 2040
I have a Husqvarna Viking Quilt Designer II that the reverse button does not reverse. It continues to sew forward when I hold and press the reverse button. Thank you for your help.
If, the machine has been sitting, take a hair dryer and heat where the reverse lever is. Try this, it worked on mine. If, that does not work, try cleaning and oiling your machine according to your manual.
Nov 19, 2017 | Husqvarna Sewing Machines
Will not sew in reverse when reverse button pushed
my kenmore 385.17526 will not go in reverse when I push ...
www.shopyourway.com > Manage My Life > Questions
my kenmore 385.17526 will not go in reverse when I push the button ... Having asewing machine that doesn't reverse can be a bit disappointing, especially ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home_and_Garden/.../Sewing.../index.html
Sewing Machine Won't Sew in Reverse. My Elna 3007 became temperamental atsewing in reverse some years ago. On occasion, I will need to push the button ...
Bernina 1230 Reverse Button Fix ' Temecula Valley Sewing ...
https://tv-sewingcenter.com/bernina/bernina-1230-reverse-button-fix
Aug 30, 2010 - The reverse button of the 1230 had been pulled or popped out of ... All I had to do to fix the button was to hold the button in, and then push the cap forward. ... My 1120 Bernina reverse button will not work and the person who ...
Dec 28, 2015 | Sewing Machines
Reverse not working. Pressing the reverse button isn't engaging the machine in reverse - the light has gradually stopped coming on, it appears to be disconnected.
take your machine to a Viking dealer and have them check it out. it probably has a worn 8 button keypad. the reverse button is usually the first to wear out. this not a DIY project.
Mar 10, 2015 | Husqvarna Designer I
My singer 4210 will only work in reverse
The reverse button may have loosened check for looseness and tighten if possible
Oct 30, 2014 | Singer Inspiration 4210 Mechanical Sewing...
Husqvarna viking sewing machine reverse button not working
yes, it's possible that the button needs to be replaced and it's also possible that a part could be broken or loose inside the machine, it would be a good idea to have the machine checked..
Feb 03, 2014 | Sewing Machines
My sewing machine now only sews in reverse
Maybe there's a problem with the reverse and forward button.
For sewing machine reviews
Sep 26, 2012 | Sewing Machines
Reverse button dose not work
if the gear or button that works the reverse is worn or broken or come loose then it would have to be fixed at a sewing machine shop
Mar 05, 2012 | Singer Sewing Machines
Janome New Home mx3123 reverse button not working
1/28/13 - I have Janome Harmony 2049 that was initially sewing forward with no reverse and then after about 12 inches of sewing would ONLY sew in reverse. After spending an hour getting the plastic housing off...I was able to locate the shaft that made the reverse. It needed lubrication and after working it in and unjamming the part from the down position, the forward and reverse now work!
Huh, right? Hope it continues to work well. It is a smooth running machine, otherwise. Good luck!
Apr 05, 2010 | New Home MX-3123 Computerized Sewing...
Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Jul 28, 2008 | Kenmore 15218 Mechanical Sewing Machine
Reverse stitching problem
There are 4 buttons just above and to the right of the needle on the face of the machine. The second button from the bottom is the reverse.
sewman7
May 13, 2008 | Singer Quantum XL-6000 Computerized Sewing...
Sewing Machines Logo
23 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
