Question about Dremel 395 Variable Speed Multipro Rotary Tool Kit
Dremel moto tool model 395 coupling from motor to
Dremel moto tool model 395 coupling from motor to chuck ruined where do I find the parts?
  • 3 Answers
The part that goes between the motor and the chuck is called the CLUTCH UNIT,
REF 2615294309 it is a splined rubberised sleeve, it also fits the 276 and 396.
The price is £3.69 (including vat at17.5%) and can be obtained from Jaymac (Derby) Ltd.
http://www.dremel-direct.com/acatalog/service.html
Posted on Sep 26, 2010
I have the same problem. The parts are not carried locally, and most of the home made fixes you might find online seem to fail rather quickly. I'm calling Dremel tomorrow to order the part. I'm told it is still available, and should run around $5 including shipping.
Posted on Jul 23, 2010
    Guru:
  • 1,051 Answers
You can probably find the part you need at a local bigbox hardware store. If they don't have it you can definately get it directly from Dremel. The Dremel web site has all the info you'll need. If it's still under a warrenty you shouls have them replace or repair it at no cost.
Posted on Jul 19, 2010
  • Bob Korsu
    Bob Korsu Jul 24, 2010
    I'd like to add that my first Dremel tool was my fathers. It was passed on to me when he passed away. Being one of Dremels' very early models, I had some problems getting repair parts. Dremel actually sent me a new tool because they no longer had the part I needed.
The blade assembly on my dremel will not come off. Is there a trick to this?The coupling seems to stuck.
Try some W-D40 and gentle hits on the coupling to liberate the chuck 3 pin holders.If you got this type of chuck:
r00130v1.jpg > Enlarge Image
4486 Dremel Chuck
The Dremel Chuck holds Dremel accessories without using a collet eliminating having to use the wrench and creating quick and e
Nov 08, 2010 | Dremel 395 Variable Speed Multipro Rotary...
My Dremel tool motor still works but shaft won't turn?
Here's the email from I got from Dremel (in my case the flex coupling broke):
Inside the tool is a flex coupling and spline driver.
The flex coupling is # 2615294309 and the price is $ 1.25.
This is the hollow plastic sleeve about 1" long with grooves on the
inside, that goes between the motor shaft and the output shaft.
The spline driver is # 2615294308 at $ 1.00.
Spline driver sits on the direct end of the motor shaft. The flex
coupling sits over the spline driver. Spline driver is about 1/4",
hard plastic with grooves on the outside.
Total shipping for orders under $ 5.00 is $ 2.50. Orders over $
5.00 is $ 4.00.
I have provided ordering instructions below.
To order by phone: 1-800-437-3635, Monday-Friday from 7 am to 6 pm
central time. VISA, MasterCard or Discover is accepted.
To order by mail:
Dremel
4915 21st Street
Racine WI 53406
Dec 06, 2009 | Dremel Variable - Speed Multipro Rotary...
Motor works but no drive to shaft.
My 15 year old Dremel 395 had the same problem so I took it apart. There is a plastic spline between the motor and the output shaft to the chuck . My plastic spline was split and had many of its teeth sheared off. The shaft lock acts on the output shaft side of this spline, so it was ok. Otherwise everything looked great; bearings ran free & had little play free, brushes ok. To be fair, my Dremel had seen hard use & doesn't owe me anything. No luck so far finding replacement spline parts, which if available should be easy to install. To take apart your tool, just google "Dremel Disassembly". GOOD LUCK!
Nov 28, 2009 | Dremel Variable - Speed Multipro Rotary...
The motor on my dremel 395 works but the bit doesn't turn
there is a coupling between the motor and the spindle that has probably cracked or stripped out. I suggest going to Dremel.com and getting an original replacement part for this. They are not hard to install.
Sep 02, 2009 | Dremel Variable - Speed Multipro Rotary...
Dremel Moto-tool model 395 type 1 lock
You can either go to Dremel.com and type in your model number for replacement parts or call their toll free number at 1-800-437-3635 and get that information. Let me know if you need anything further
Feb 20, 2009 | Dremel Variable - Speed Multipro Rotary...
Dremel 395 Variable Speed Multipro Rotary Tool Kit Logo
1,911 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
