Question about Acer V223W Monitor
Desktop is larger then the screen....!!!
I have an Acer v223w monitor, and the desktop is considerably zoomed in and can't figure out how to make it to fit the screen, this has only recently happened and i can't work out the cause either, please assist me.....
    President:
  • 2,571 Answers
Change the resolution, if you dont know how, just google it
Posted on Jul 19, 2010
Acer v223w
Right-click on the Desktop and select Screen Resolution. You most likely need to adjust something (resolution) on the screen presented. This assumes Windows Vista/7. If you are running WinXP, getting to the settings is different. However, it also could be the aspect ratio setting of your monitor itself if the setting is available in monitor's settings.
Apr 30, 2014 | Computers & Internet
Can i hook up my xbox to a Acer V223W EJbd monitor
Yes, you can get a DVI or AVG connector and use those.
Mar 09, 2013 | Acer 22" V223W EJbd Widescreen LCD...
Acer v223w on and off
You could have a faulty power supply. If the capacitors have a blown (deformed top) then they are faulty. Replacing these capacitors with new ones may fix the problem provided nothing else is faulty. Make sure you replace them with the same voltage and capacitor rating.
Nov 30, 2012 | Acer V223W LCD Monitor
V223W
When you go to project just hit the windows key and the p key at the same time and it should instruct you from there.
Jul 15, 2017 | Acer V223W LCD Monitor
Acer V223W monitor At 1680X1050 resolution cannot get full screen. Windows Xp
Just press the AUTO button for two seconds to activate the auto adjustment function.
Mar 21, 2011 | Acer V223W
I have a V223W monitor it goes to a black screen
Possibly cold solder joint or a cable needs resitting will need to take to trained technician as covers will have to come off to reflow pcb boards
Jan 04, 2010 | Acer Computers & Internet
I have a new Acer 22in v223w flickers
Check your power supply. IF it is through a UPS then try connecting directly to a main supply. If problem persists then look for a ACer service center immediately. There might be a problem with the panel.
Nov 30, 2009 | Acer 22" X223w LCD Monitor
Acer V223W monitor goes to sleep and doesn't awake
Go To Start > Programs > Accessories > System Tools > System Restore. Select "restore my computer to an earlier date". Look at the LIST of Restore points. Find the DATE when this "Security Update" was installed and Select the last date before it was installed and Follow the "Wizard" to Restore it to BEFORE the Update you think CHanged Things. Too many variables to figure out without seeing it to determine what was changed but that will correct the situation and you will not loose anything.
Aug 21, 2009 | Acer V223WBD Monitor
Driver
Here is a link to the driver you need.
http://support.acer-euro.com/drivers/monitor/v223w.html
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post.
If I have helped you, please help me, and rate this suggestion a FixYa rating. If not then please comment to this post and I will try to help you further.
Thank you for your support
May 12, 2009 | Acer V223WBD Monitor
Resolution issue Acer V223w
Hi, I'm sorry to hear you are having trouble....
THis is a tricky one. My first step would be to connect another screen to your G5 and connect your V223w to another Mac... Are you able to do this, do you have access to another system, could even be a PC ( in the worst case )
Ideally, having 2 screens connected to your G5 would be the best situation.
THis way, with one working screen, you can attempt to modify the resolution and refresh rates on the V223w from the good screen, be sure to activate screen mirroring, otherwise you will not have access to the other window of monitors system preferences.
If you can get two monitors connected and mirroring is not an option, then either your monitor is KAPUT or the video card secondary port is KAPUT, try switching the port of the card your displays are connected to. I think they are both DVI ports. If the opposite screen is now working, then you know it's the port on the video card.
Hope this will get you through it.
Mar 28, 2009 | Apple Power Mac G5 Desktop
Acer V223W Monitor Logo
360 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
