Question about Sony KP-61HS10 61" Rear Projection Television
Clarification Just wanted to make sure. My picture quality degrades and corrects. Sometimes the picture is very blurry and sometimes it's ok but the words on the screen are still sort of ghost. So my problem is definitely the convergence isn't it? I have already ordered the ICs. (STK392-560) Thank you.
  • 4 Answers
Just replace the sucket at the back of picture tube. remove from pcb the old one and then replace a new one. that's it and it solve your provelem.no need to buy an IC. if you can clean that socket, much better 'couse you don't need to purchase a new one. try it know. 99.9% sure...thanks
regards,
janex
Posted on Apr 22, 2008
  • janex2 Apr 22, 2008
    that ic(STK392-560) is for power regulator an "oscelator".. no need to change that ic because it is not deffective since your tv is still working the power.
    janex
  • Sony Master
  • 8,617 Answers
I jus posted a response to this question. It should take care of your problem. However if you ordered the ICs from the link I posted they will go the distance to help you find out whats wrong if the ICs dont fix the problem.
Posted on Apr 21, 2008
When I turn on the TV, the picture is fuzzy. After five minutes, the picture is clear but any words are out of focus even the menu for adjustments is out of focus. The convergence for red is clear but...
Below are some troubleshooting tips for a TV that has a fuzzy or blurry picture;
If your Plasma or LCD TV picture is blurry or fuzzy there are several things that may be causing the problem. It's worth running through the following list before seeking service. You may find yourself saving the full cost of a TV repair.
Make sure you are using the appropriate cable box for your TV. If you have a high-definition TV you should also be using a high-def channel box from your cable provider. Watching standard definition channels on a high-def TV can make the picture look distorted and fuzzy.
Not all cable channels are broadcast in high-definition. When you stretch a standard definition picture to fill the full frame of your wide-screen TV it may look distorted. You can try changing your TV display settings to show standard-def channels at their native resolution. This will create black or gray bands on either side of your picture.
Ideally all of your video components will be connected to your TV with HDMI cables. Your next best option will be component video cables. If your cable box does not have HDMI capabilities, contact your cable company about upgrading your box to one that does include HDMI.
Make sure there is no glare on your TV from a window or other strong light source. This can significantly degrade the quality of the image you are watching.
If your TV has digital noise reduction, try turning that feature on.
You can adjust your TV's sharpness and picture modes to see if that improves picture quality.
Try plugging the power cord into a different electrical outlet and/or surge protector. You may be receiving electrical interference through your power cord.
Trying moving any nearby electrical devices away from the TV. They may be creating interference that can degrade the picture quality.
Let me know if the above helps or not, so that I can direct you further on what do next.....
Best regards.
Apr 14, 2011 | Zenith IQB50M90W 50" Rear Projection...
I'm connected to a dish network receiver and the picture was good until my son tried to plug in his playstation 2. Now everything is back to the way it was originally installed except there is a scrambled...
Hey there. You want to make sure that the cables are tight on the back of the receiver and also that the tv is on the correct channel or input. Sometimes, if the tv is on the wrong input, you can get the picture, but it will look scrambled. So if you are in the room with the receiver box, you want to make sure that the tv is on channel 3 or 4, and sometimes on an input like Video 1 or 2. If on the secondary tv, you will want to make sure that the tv is on channel 60 or 73. I hope that this helps. You can follow this link below if you need more clarification.
http://www.dishnetwork.com/SupportSection/bbs-screen
Becki Barned
DISH Network Customer Service
Nov 16, 2010 | Insignia IS-LCDTV32 32 in. Television
Olympus x775 doesn't focus
Sometimes it will show a low quality picture on your camera screen for reviewing
Aug 04, 2009 | Cameras
View finder
Ok. On your viewfinder, there might be a round dial. Turn it to adjust focus. Otherwise, sometimes viewfinders are like that... blurry, especially electronic.
Apr 19, 2009 | Sony Cyber-shot DSC-H5 Digital Camera
Web pictures not clear
What version of IE are you running? How old is your laptop?
I had this problem before. Sometimes the settings are set so that images will download faster, the price is a lower quality image.
Pull up an image on IE and if it is blurry, then right click and see if there is an option to reload page at full quality.
Unless you have a fast processor and enough RAM to handle the download images. I would leave settings alone and just right click on images that you really want to see.
Feb 13, 2009 | HP Compaq Presario V2000 Notebook
Blurry pictures
try turning of the stabilizer if you have one it will be in the settings menu
Jan 08, 2009 | Canon PowerShot SD1000 Digital Camera
My pictures are coming out blurry, after a year of good quality.
Check that the lens and other elements on the front of the camera are free from dust and grime.  The focus mechanism is not functioning properly and may need to be serviced.
Dec 12, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
QuickCam Express, blurry, snowy picture...sometimes the picture is totally shaded red
Many factors can affect the image quality of your pictures. If you are experiencing blurry images, please try adjusting the focus ring located around the lens.
This will allow you to focus the camera image on objects at different distances.
Also, make sure there is good lighting. Improving the lighting conditions can improve the image quality considerably.
Connection Issues:
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video.
Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed.
Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds.
If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
Changing Display Adapter Settings:
If you are still experiencing a distorted, fuzzy or grainy image, you may need to change the settings for your display adapter.
For optimal image quality, please make sure the video display adapter is set to display at least 16-bit high color or higher.
To change the color palette please perform the following steps:
Click on "Start," "Settings," and "Control Panel."
Double-click on the Display icon.
Click on the tab labeled Settings.
In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
Also, check with the manufacturer of the video card for updated video drivers.
Low Light Boost:
If you cannot do anything to improve the lighting situation, some Logitech video cameras have an option for "Low Light Boost."
If there is an option for "Low Light Boost," try enabling the "Low Light Boost" in the QuickCam software.
To do this:
Open the QuickCam software.
At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
Choose "Advanced Camera Settings".
Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
If that does not improve the image quality, try adjusting the other image settings, such as contrast, saturation brightness, gain and white balance.
Click OK when your are done.
Last, make sure that you ae using the latest drivers.
You can upodate them from here.
http://www.logitech.com/index.cfm/492/&cl=us,en?prodcrid=492
Hope this helps.
Good Luck.
Live, Love, Laugh.
May 12, 2008 | Logitech Webcam
Blurry screen
coolant fluid on picture tube may be contaminated replace it an setbe ok (this is a technician job)
Mar 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Sony KP-61HS10 61" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
