Question about Sony Playstation 3 (PS3) Console
PS3 no longer delivers audio or video. Purchased new cable but still doesn't work what could be the culprit?
    President:
  • 1,139 Answers
Try resetting the vide back to standard definition by holding the power buttong down for 5 seconds.
Posted on Jul 29, 2010
Ps3 comes on but no video or audio showa
try getting new audio video cables if that doesnt work it could be a TV issue try putting another device that has AV cables to see if its not your tv if after buying new AV cables i suggest it's an audio video port issue and you may have to buy a new ps3 or claim warranty on the one you have. hope this helps.
Dec 03, 2012 | Sony Playstation 3 (PS3) Console
My ps3 will not put out any audio or video
Have you changed your settings from hdmi back to normal you should try both hdmi and scart or av on your tv, if this doesn't work then you need someone with a ps3 that works (you need your ps3 and a spare tv) and you can copy what theres does but you need to be very precise or look on you tube to see how to restore your ps3 back to the factory settings. I hope this helps mines done the same and it worked for me.
Apr 04, 2012 | Sony PlayStation Video Game Consoles &...
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
PS3 Digital Audio (optical) out no longer working
Check you audio settings are correct on the ps3 dashboard. Failing this try swapping the optical cable or connecting to another devise to see if it working.
Post more info if you need further help
Mar 10, 2010 | Sony Playstation 3 (PS3) Console
PS3 no longer communicating with TV
The problem is with your PS3 itself.
If it's still under warranty, take it back.
May 30, 2009 | Sony Playstation 3 (PS3) Console
Hello can you help with this error!
When you switch from one cable connection to another (Hdmi to AV etc) you need to reset the PS3 to its default settings. Basically what is happening is, your PS3 is set to HDMI, so when you plug in AV cables it doesn't know it. So you have to reset it. Hook your PS3 up to whatever cables (make sure system is fully off) then hold the front power button down for a few seconds.
Doing this will reset the display settings. You can then go into the XMB (main menu) and choose your connection. Although the PS3 should do this during the start up on its own.
Hope this helps.
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
PS3 HDMI & AV outputs not working?!?!?!?
change the sound output to HDMI? does the sound work on just like a normal tv channel?
Sep 03, 2008 | Sony Playstation 3 (PS3) Console
My yamaha htr 6050
Make sure you speakers are turned on on the receiver,
Jan 23, 2008 | Yamaha HTR-6030 Receiver
Audio but no video using hdmi on ps3
the cables might be faulty so borrow some one elses cables and try them if you have that option or just go back to the cables that came with it for now.
Jan 08, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
22 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
