Question about Pride Celebrity X 4-Wheel Electric Scooter
PRIDE CELEBRITY DX RUNNING SLOW
I HAVE A CELEBRITY DX SCOOTER, IT IS 4 YEARS OLD. I HAVE HAD NEW BATTERIES FITTED, BUT THIS LAST 3 MONTHS THE SCOOTER RUNS FROM NORMAL SPEED TO SLOW AND SLUGGISH THEN BACK TO NORMAL EVERY FEW MINUTES.CAN YOU HELP ME PLEASE. JOHN . THE 2 BRUSHES ARE LOOKING OK
    Problem Solver:
  • 16 Answers
Hi
Please Check your Potientiometer also known as a Pot, This is your Speed Control and it may be on the way out after 4 Years ,
My Own Pot Packed up after 11 Months, Try to get a Second hand one as they are Expensive to buy,
Good Luck, Gerry.
Posted on Aug 01, 2010
Mother's scooter keeps dying
How old is the battery they don't last forever and they are not cheap
Sep 28, 2015 | Pride Go-Go Elite Traveller 4-Wheel Travel...
More on Celebrity X motor overheating. Brushes look good. Brake does not seem to be dragging, Batteries are about 5 years old but hold a good charge when not in use for months,
If the motor is overheating, it is drawing far more current out of
the batteries than it is supposed to. Assuming it is 2 x 13v x 33ah
batteries, these are good for about 2 to 3 years on my scooter and 'wheelchair. AGM (absorbent glass mat) lead acid batteries do deteriorate over time due to battery chemistry.
Although the batteries may appear to take a charge
and the voltage 12.6volt x 2 = 25.2 volts nominal, with no load
on them, the motor controller takes a whack of current to get you going.
I have an digital voltmeter/ammeter installed on my Pride XL scooter and I was amazed how much current the motor/motor controller takes from the batteries. 50 to 80amps on startup.
If the battery voltage drops due to the age of the batteries, as the
energy is being used up from them, the current required by the
motor for rotation has to go up, and that will cause overheating of the controller and the motor. It is Ohms law plain and simple
the less voltage available-the more current required to do the
work and current creates the heating effect.
I replace my batteries every two years. Can't take a chance on
being stuck with discharged batteries.
Feb 20, 2015 | Pride Celebrity X 3-Wheel Electric Scooter...
Why wont my celebrity x take a charge brand new batteries brand new charger
Is the charging circuit fuse blown? There are two hidden under the floor mat and hatch. Pride say that they don't exist, but there they are and one of mine mine was blown by a faulty XLR lead
Apr 25, 2014 | Pride Celebrity Xl 4 Wheel Scooter
My dad's pride celebrity scooter has new batteries. the status led flashes once, pauses, and then flashes twice and then repeats. it was not used for several months, but was operating fine the last...
Hi. The batteries for these things seem to go bad rather quickly when they are not used, but here is something to try..... So called "smart chargers" are what everything is going to. They analyze the condition of the battery and if everything is good, charge it. If everything is not good, according to the parameters of that charger, they don't. My suggestion is to take the battery out of the unit and try an old-fashioned analog battery charger for a little while, set to the proper voltage for the battery, of course, and monitored closely to measure the effects. If the batteries seem to take a charge, put them back in and run it a bit, then try the on-board charger again, just don't wait until the batteries are completely drained this time.
Sep 09, 2011 | Pride Celebrity Xl 4 Wheel Scooter
I HAVE A CELEBRITY DX SCOOTER, IT IS 4 YEARS OLD. I HAVE HAD NEW BATTERIES FITTED, BUT THIS LAST 3 MONTHS THE SCOOTER RUNS FROM NORMAL SPEED TO SLOW AND SLUGGISH THEN BACK TO NORMAL EVERY FEW MINUTES.CAN...
Hi John.
The problem could be a worn throttle pot ( wig wag ). Next time you are driving the scooter, try moving the ends of the speed lever slowly up and down, instead of in or out as you normally use it. If the throttle pot is worn, moving the lever this way will make the machine speed up or slow down.
Another cause might be a faulty battery lead connector or a faulty motor connector.
Good luck. Neil.
Jul 05, 2010 | Pride Celebrity X 4-Wheel Electric Scooter...
Brake not holding on incline
remove wheel then using screw driver
remove brake then replace and re screw
replace wheel
ted mobility centre penge 0208 676 0944
Mar 30, 2010 | Pride New Mobility Celebrity 3 wheel...
New 55ah batteries but charge won't last.
Battery life is affected by many things. But inside a tiled space like Walmart is probably the best possible running conditions. Make sure your tires are fully inflated, and you may need to have the motors check for worn brushes or maybe the wheel bearings are dry. Does the scooter push hard when in free-wheel mode? You may also need to have your charger checked, to be sure your batteries are really being fully charged.
Nov 22, 2008 | Pride Maxima 4-Wheel 4-Wheel Scooter
Pride Celebrity X 4-Wheel Electric Scooter  Logo
628 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
