Question about Sharp AL 1631 Copier
It lists L as a problem for the copier when you load paper and push drawer in an L comes up right away on the display.
  • 328 Answers
See problem (L)must show a digit like (1,2,3,4,.....)tell me what
Posted on Jul 21, 2010
Hello i have a canon ir2022 displays "load paper drawer 1" at start up.
If there is paper in drawer 1 and you still get this error, it sounds like a bad paper sensor.
May 27, 2015 | Canon imageRUNNER 2022 Grayscale Copier
My printer tray will not go back in /please help me
It would help if you listed the make and model of your printer, however, the suggestion I would make is there obviously something that is "jamming" the drawer. It is possible you have too much paper stacked in the drawer and that is causing it?
If not, try this:
1 - Turn the printer power off.
2 - Remove all sources of paper.
3 - Look into the areas were the the printer feeds in and comes out (you might need a small flash light)
4 - Be sure to check the area were the print head contacts the paper.
5- If there is nothing obvious, turn the printer upside down, inspect the bottom for obstructions.
6- While still upside down, try to install the drawer without any paper in it and see if it goes in O.K. If it does then you can put the printer right side up and you should be able to put it all back together.
If that does not work it is possible a part on the printer or the drawer has broken off preventing the drawer from sliding in.
Hope this helps.
Sep 21, 2014 | Office Equipment & Supplies
Hello, my copier machine cannot detect paper
Pull paper tray out and set aside,
in the back there is white lever above the spring
push lever in ,a black actuator should drop down
if it does not it may be broken or stuck.
The tray select button on the control panel should allow you to use the side tray.
Jul 21, 2010 | Canon IR1018J Black and White Copier
Copier keeps telling us there is paper jam, we have looked where screen shows jam and find nothing. We have taken out the paper tray, still don't find even a tiny scrap of paper anywhere.
There are several possibilities. After you inspect for the Jam and close the drawer, does the copier come to ready? Have you checked the behind the doors on the right side. If the copier comes to ready and you press the start button does the copier jam right away. If so check the dial on the paper drawer and be sure its set to the right size paper. If its not the copier will jam, right away. It is important with a Canon to check all areas and open both the paper drawer and the right side doors when checking for jam, if the right sequence is not followed in checking for jams the jam may not clear. If still Jammed you might take some canned air open the right side door and blow out the paper feed area, a sensor may be blocked or dusty. If all else fails turn the machine off and un-plug it from the wall, let it set a few minutes and plug it in and try it again.
May 20, 2010 | Canon imageRUNNER 2000 Copier
I have an old Canon 1150 color copier. The bottom drawer #2 dropped and can't feed paper properly. So I put 11x17 paper in drawer #1 which had 8x10 paper originally. Now the panel still shows drawer #1...
Is there a paper selection wheel or bar in the tray?
Some of the older Canon models have a dial (usually in the lower right hand corner of the tray) or a slider bar (usually on the left hand side of the tray) when you open it. That has to be set properly or the machine has no idea what size paper is there.
Dec 03, 2009 | Canon CLC 1150 Color Copier
It says add paper but it has paper loaded
Remove the paper drawer, and be sure there are no obstructions. Check to be sure nothing is stuck, and the paper is seated properly. Insert the drawer again, and see if the error goes away.
Jul 06, 2009 | Toshiba e-STUDIO 352 Black and White...
I am unable to print photographs on my D7260 HP Photosmart Printer bacause the blank photo papers are not being drawn into the machine
Have you loaded them face down? I have a 7360 and they are pretty fussy about what they will take and what they won't and how. The paper must be put in the upper drawer (if it is 6x4 paper), with the glossy side down and the drawer must be pushed right in.
Jun 12, 2009 | HP Photosmart D7260 Printer
Model cf3102 display misfeed detected
We get a miss feed on our when we load too much paper. Try loading a little less. To undo a miss feed from overloading it you have to open and close all the drawers and eventually it will go away.
Jan 29, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Won't print
ok, i just tried this and it works--
pull out paper drawer, in the back of the paper drawer there is a rectangular shaped blue button located just right of center. the symbol on it is a lock. this button can be pushed forward (away from you) or backwards (towards you), push it backwards towards you til it clicks in place.
return paper drawer and print.
this solved it for me-
hope this helps
Sep 28, 2008 | Brother HL 5250DN Laser Printer
Repair of xerox copier 5334
the sensor board of trays is abnormal check it
Sep 12, 2007 | Ricoh Aficio 450 Copier
Sharp AL 1631 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
