Question about Hotpoint Freezers
What's the amperage on my Hotpoint Freezer? I want to calculate how much this unit is costing me in energy. Model number FV15CRB, serial number(?) AV 336553. Thanks!
    President:
  • 1,515 Answers
Hi, to find out the total amperage of your unit, you should have a data plate most of the time, located inside with the compressor amperage, and both fan motor amps. If not inside, it will be outside of the unit. It will tell you the RLA and the FLA of each. It will also show the freon type and amount you use. Also, on top of your compressor is a plate that has the RLAmps on it also. This is what you need to find on this unit to help you on your calculations.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Jul 20, 2010
Was offered a new energy efficient freezer 16.7 cu foot standing frost free by Fridgidaire ( energy efficiency rating 65). My 13 yr old Kenmore: Model : 253.9287215 Freezer works fine. Is it rated the...
I was not able to find any info quickly on your older Kenmore in my literature but its a sure bet that it was not as efficient as the new one. You can do a calculation or look at the plate (usually on the back) that states the amperage draw on each model- the higher one is the less efficient. As for cuft you need to do the math and measure the inside storage area in inches wide, inches deep and inches tall. Multiply the width X depth X height then divide by 144 (the cu inches in a cubic ft) this will give you the actual size of the Kenmore for comparison. Hope this helps... also you may want to check with your local electric utility company as many are offering a rebate to replace 10 yr old fridge. freezers and usually pick up for free.
May 15, 2014 | Freezers
True freezer
check the condenser and freon
Aug 18, 2008 | True Freezers
Can't get freezer to reset model number LFFH17HWC serial numberWB93766371
Hello richardso903 - Once again try resetting the freezer by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart the unit. Set the unit to ON, by pressing and holding the Power button for approximately ten seconds. If issue persists and freezer does not turn on, then the unit may be experiencing a wiring failure, faulty plug or control board. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
Mar 30, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Power off for electrical repair. Plugged floor freezer back in and a loud buzzing noise is ongoing. Not sure if this is a temperature alert or if there is another problem. Thanks for your help.
This sounds as if its a start relay problem. They are attached to the compressor
You will need the model and serial number to get a new one at the appliance
parts store. They are usually under a plastic cover on the side of the compressor
and the cover is retained by a metal spring clip. Remember to unplug unit before
replacing this part. The model and serial number should be located near the compressor.
May 04, 2011 | GE Freezer  14.8 Cu. Ft. Manual...
I left the Freezer door open and now it seems like the freezer is not cold enough to freeze things. It has been 5-6 hours since it has been closed. Is it just taking a long time to completely cold or...
Place a glass of lukewarm water on one of the freezer shelves. Leave the freezer door closed overnight. Check the water in the morning to see if the freezer has brought the temperature down. It takes quite awhile for refrigeration units to recover from heat loads such as door open for extended periods of time.
Jan 06, 2010 | Freezers
Old hotpoint upright freezer only has 1 temp artic blast....
I would replace the thermostat because is the only thing that controls the temp. , also there's a timer and a terminator but them are only for defrosting the unit.
Aug 13, 2009 | GE 16.7 cu. ft. / 473 liter Upright...
Which setting on an Energy Miser saves energy?
OFF is the Energy Saver mode.
To reduce moisture, there is a heater around the door seal that stays turned on, using energy. If you switch to ON, you use more energy.
It is confusing though.
Jan 17, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Need defrost element for 1996 Kelvinator Freezer
Fixya is unable to suggest sources for a Kelvinator defrost element.
Mar 04, 2018 | Kelvinator 12 cu. ft. / 340 liter Chest...
Hotpoint Mistral fridge freezer frost free Model 8596P
Hi Avaline,
You need a new friend!
If the unit is 10 years old or more it does not pay to fixit! the new ones will save you big time energy!
OR,
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Aug 21, 2008 | Freezers
Freezers Logo
81 people viewed this question
Top Hotpoint Freezers Experts
AJMAL KHAN
Victor Nwachukwu
Victor Nwachukwu
Justin Duby
Justin Duby
Are you a Hotpoint Freezer Expert? Answer questions, earn points and help others
