My 2 year old was messing with the remote control. He has some how changed the display on tv to wide screen display which is displayed vertically intsead of horizontialy. The display is stuck like this no mater which display option i choose
    Novelist:
    Scholar:
  • 100 Answers
Hi flagan,
Most recent televisions do have a feature to restore or reset original settings. This should correct the problem, but you may need to make basic adjustments over again.
Cordially
Jon
Go Ahead. Use Us.
Posted on Apr 21, 2008
Sony kv-32hs420 screen mode doesnt work
Display ratio usually is a setup choice but bear in mind that old movies and old TV programs will display in 4:3 ratio. Remotes usually have no control over screen size.
Dec 28, 2013 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Emerson TV cutting off top and bottom of display
Its picture settings should be adjusted. Now it is set to 'wide' format I assumes. If you want to get full screen, the display format should be chaged. Without a remote control, it is not possible.
May 24, 2013 | Televison & Video
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
I HAVE THREE BLACK LINES AND A YELLOW VERTICAL LINE DOWN THE CENTRE OF MY SAMSUNG 50" PLASMA TV. ONLY 10 MONTHS OLD! WHAT CAN I DO?
The TV should be still under warranty. Most of the flat panel TVs come with a one year warranty from the manufacture. I wouldn't mess with the to void the warranty.
The problem most likely is the buffer/scan boards on the bottom connected to the screen. It controls the vertical image on the screen. The other possibility is the plasma display panel is bad.
Go the warranty route first. This may get expensive to fix.
Apr 01, 2010 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Monitor is vertical display instead of horizontal display
the keys ctrl+alt+right arrow should do the trick for you. if not then right click on the keyboard and select properties for options and you will find your graphics software has its own rotational software. good luck with two year old, sounds like you'll need it.
Feb 25, 2009 | Dell Computers & Internet
Sanyo 32" Tv about 4 yers old problem
Problems with screen size
Look out for 2 x 2.2uF electrolytics (sometimes red in color)
Vertical height oversize
The eprom was found to be faulty (nvm)
Pressing the screen format button displays wide, smart, zoom and 4:3 modes but settings have no effect on picure
Enter TT35 in the service mode to select a 4:3 CRT
Nov 23, 2007 | Sanyo DS32920 32" TV
Televison & Video Logo
Top Televison & Video Experts
