Question about KitchenAid Architect Series KEBC107KSS Electric Single Oven
Springs make a horrendous noise when you open the door. what is the best lube to use on them. grease or wd40?
    President:
  • 949 Answers
The best repair is to replace the hinges and springs. If you do want to lubricate them do NOT use grease or wd40, these are flammable and do not mix well with heat.
Look up an appliance parts store in your city and pick up some high temperature copper or graphite based lubricant those are safe for use on oven hinges.
Posted on Jul 20, 2010
Unable to remove oven door (to fix misalignment). Old Smeg oven
burnt grease make things sttick really well . try some wd40 on it for a day or so then open part way and pull up on the door .
Nov 09, 2016 | Ovens
I replaced my door springs but it seams the hinges pop out of the track when opening the door and it causes the door to drop down to far
Tom, I am pretty sure you have not reinstalled door quite right, try again till you get it seated into proper position.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 03, 2016 | Ovens
How do you adjust doors on imperial ICV-1 convection oven
The turnbucke system behind the lower panel is relatively straightforward but one buckle is LH thread the other is RH thread. Slacken both locknuts and adjust the buckles until the LH door lags by the thickness of the RH door when they are just coming together (a rough approximation). Don't have too much tension on the chains and lube the chains, gears etc with a copper based grease. It has been known for the little grub screws in the bottom cogs to come loose. You'll need an allen key to tighten them up.
After all adjustments check the chain 'slack' by quickly opening/closing the doors when at about 1/2 open. There shouldn't be so much that the LH door doesn't react reasonably quickly to the change of direction, but not so tight as they are like bow strings.
Mar 08, 2013 | Imperial ICV-1 Turbo-Flow Single Oven
I have an AEG competence 5020 B fan oven (single) which has a very noisey fan, does this need a new motor and can I fix this myself?
ISOLATE THE MAINS POWER BEFORE OPENING THE REAR OF THE OVEN.
Remove the oven, open the back, remove the fan, and clean with WD40, afer the fan is dry, fit the fan back into the housing, replace back and put into cabinet, switch on low, if the fan makes a whirring noise, or unusual squeeking replace the fan, if however the fan sounds normal and good pressure when door is open, it should be okay. If you require a part go to whitegoods.co.uk
Hope this is helpful
johnf1
May 17, 2011 | Ovens
I have a GE Profile Wall Oven. JT910SASS. The cooling fan makes a loud noise. How do I replace it? Where is it?
Firstly, you don't need to replace your fan simply because it's noisy. It may be sufficient just to grease the spindle/bearings.
The fan is located at the back of the oven and CANNOT be accessed from inside the oven. If you open the oven door, you will see a grille at the back of the oven compartment - basically just some slots and holes cut into the back panel. Behind this grille is the heating coil/element, then another panel, behind which is the fan/fan motor. Basically, the fan is right at the back, dead-centre of the unit.
To access the fan, you will need to remove the oven from the wall cabinet and remove the back panel. To do this, you first need to unplug the oven or, if it's hardwired, detach the cable from the outlet - power off please! Next, remove the retaining screws at the on both sides of the oven at the front - these are only revealed when the door is open. You should now be able to remove the oven from the wall cabinet by pulling it forwards gradually and feeding the power cable through as you do it. I suggest getting someone to help you lift it out as they are fairly heavy and awkward to hold/carry. Also wear some old clothes as the bottom of the unit can be quite greasy!
Put the oven somewhere safe where you can access the back of the oven easily. The fan is covered by a removable back panel. Undo the screws (about 10) around the edges of the panel and partially pull the panel away - taking care not to snag any of the wiring behind the panel. You will also need to remove the connectors to the main power cable to remove the panel fully. Make a note of the connections (or take a photo) to ensure you reconnect it correctly!
You should now have clear access to the fan. Inpsect it visually to see if the blades are broken and try spinning it by hand to identify where the noise is coming from. If the blades are sound apply some HMP grease around the spindle which rotates the fan. This can be quite tricky, so it might be easier to liberally apply some spray lube around the area. Spin the fan by hand a little to work the lube in.
Next, test the oven before putting it back into the wall cabinet. This can be done by replacing the back panel and plugging the oven into a socket or extension cable. If the oven was hardwired, attach a plug to the end of the cable. Turn the oven on at the minimum temperature and let it run for 5-10 minutes to allow the lubricant to work through. If the noise has diminished or gone, reinstall the oven in reverse order of the above. After refitting, I suggest running the oven empty on a low-mid temperature until the smell of lubricant has gone.
If the fan is damaged - or you can't get rid of the noise by lubricating it - then you will need to buy a new motor and fan blade. Fitting these is easy with the back panel removed as they simply bolt/screw onto the back panel of the oven and the wires just slide on and off. If possible, take some photos before removing the old fan/motor to ensure correct fitting of the new parts.
Please post back if you need further assistance.
Hope this helps.
BElectric
Nov 02, 2010 | GE Profile JT910SASS Electric Single Oven
Door will not stay closed
Hello,Sounds like the door hinge springs are weak, it will probably be necessary to replace them both.
Thanks
Jun 02, 2010 | Whirlpool GBS277PDS Electric Single Oven
Oven door won't close completely
You will probably have to replace the springs I doubt if they can ve fixed. you can open the door all the way and you will see a hole in the spring just inside the door. you can stick a nail in that hole, both springs that will hold the door open and you can lift the door out and check the springs I will tell you to have patience its not easy.
Apr 21, 2010 | Kenmore 47702 / 47704 / 47709 Electric...
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 | Ovens
Removing the door from a thermador oven CT130
Usually you will find a hole in each hinge to hold the hinge open when removing the door.
It is impossible to fight the door hinge springs and remove or install the door.
One opens the door and puts a nail through the hole to keep the hinge open for each hinge.
Feb 20, 2010 | Thermador Ovens
Oven door does not close
One of the springs fell off or the door hinge assembly sprin out.
May 04, 2007 | GE JT912SKSS Electric Single Oven
KitchenAid Architect Series KEBC107KSS Electric Single Oven Logo
201 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
