Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Enigine smokes after 15 minutes use, blue smoke
Blue smoke after 15 minutes use
    Sergeant:
  • 200 Answers
The piston rings are probably worn in the motor.
Posted on Jul 20, 2010
1993 Johnson 120, after running well for a few hours. Would not restart after about a 15 minute break. Lots of smoke.
Color of smoke is hint re issue. Black is excess carbon, blue is oil being burned, white is water
(steam). Which is it, then take it from there.
Jul 23, 2017 | Boating
What's the firing order on 1988 GMC S-15 4x4 and can jumped timing cause blue smoke out of the exhaust?
Blue smoke is almost always oil in the cylinders. It's caused by bad valve seats or bad rings. Timing won't cause blue smoke.
Nov 24, 2015 | 1988 GMC S-15
My fiat scudo has loss of power when I start it in the morning it gives white n blue smoke after 15 minutes it's back to normal can any1 help
Sounds like a bad seal of some sort, heavy white smoke indicates coolant entering the cylinder heads while bluish smoke is oil burning. It could be that itgoes away when it heats up because the metal expands and closes the gap. Check your oil as well as when a head gasket is bown there is normally a milkyness to it.
Oct 07, 2012 | Cars & Trucks
516 Cdi sprinter sudden blue smoking for few minutes and after OK
somthing in the ignition is causing a weak spark--or fuel inject circuit is running to rich----------all causes improper burning---------get a computer diagnostic done
Apr 07, 2012 | Cars & Trucks
My smoke comes through my pipe
Well, it's the type of smoke that really matters. Does it smoke black? Blue? White? White for the first ~2 miles/5 minutes of warm up is not a bad thing, just blowing out condensation. White smoke that never stops is a sign your head is warped/head gasket is busted. Blue smoke is a sign that you're burning oil bad. Black smoke indicates an overly rich fuel condition.
Dec 18, 2010 | 1993 Acura Legend
My car run find for about 15 minutes that smoke
if the smoke smells sweet your heater core is leaking is the water level going down if it is replace heater core
Aug 15, 2009 | 2002 Chrysler Concorde
6.6 liter diesel blows blue smoke
check turbo tubes for oil. If wet turbo is leaking. otherwise you may have rings leaking, how is compression?
Also there is a crankcase pressure soleniod in left side of enigine block, it should NOT rattle.
Jun 29, 2009 | 2001 Chevrolet Silverado 2500HD
2001 Jetta 1.8T, 100K miles. Smokes when hot.
Ouch! you've got engine coolant in the exhaust from a leak somewhere...DO NOT run this engine until you get someone (dealer is best in this instance) to diagnose ($50-125)
Jun 14, 2009 | 2002 Volkswagen Jetta TDI
Very heavy smoke from exhaust of Yamaha Virago 250ccobviously smells of burnt oil.doesnt seem to have any rattle or loss of power just belches out blue smoke.
give the air filter a blow out m8,, and change the plugs to a hotter grade,, ie if u have ngk b8es or summat try b9,,that type of thing,
Apr 10, 2009 | 2000 Yamaha Xv 250 Virago S
Smoke problem
hey
there are couple of smoke type.blue smoke is oil, black smoke is fuel, and white smoke is water, if it clears after starting and running a few minutes it's probably your valve guide seals leaking oil down on top of your pistons, causing it to smoke until burned off and foul your plugs.
Jun 28, 2008 | Peugeot Liberte Cars & Trucks
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
221 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
