Question about Harsper HP-4200B 42 in. Plasma Television
MY HARSPER KLAUM HP4200VPM TV DOES NOT HAVE A COAX FOR CABLE CORD. WHAT SHOULD I USE IN PLACE OF IT? SHOULD IT BE THERE?
    New Friend:
I have a whole klaum TV for sale parts only shows half picture. 229-374-4192 Solomon.
Posted on Jul 16, 2015
3 Suggested Answers
skistockli
  • 73 Answers
SOURCE: I am looking for a mother board for a Klaum
We all are looking for the HP board. HP sold these TV's with defective board. As consumers we are taking action: contact us: dorje@forexcafe.org
Posted on Jul 11, 2009
Testimonial: "Hopefully Klaum will supply the mother board for the consumers."
rdcomprepair
  • 122 Answers
SOURCE: Maxent no place to connect to cable.
Simplest way I can think of, if you will have to get an HDMI cable box from your local cable service provider and just hook it up threw HDMI. There's your cable and in HD when available HD programing is on. :)
Posted on Aug 21, 2010
What is the remote code for klaum harsper tv #hp4200vpm?
029,022. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Aug 01, 2015 | Televison & Video
I am trying to connect my NES to my 40" Dynex HD TV through the AV cables and the tv says no signal but i unhooked the HDMI cable and tried the AV cables for my xbox and the xbox worked fine. How can...
  • Well the XBox has it's own AV cable pack it uses. The AV cords you are using for the NES are a separate set that are apparently bad. So to play using the AV cords you just need to pick up a new $2usd pair or see if you have a pair laying around the house.
  • You do have a coak input on the back of your TV so if you have an old coax cord laying around the house you can use the RF bonx that cam with the NES. Hook the coax from the TV to the "OUTPUT" side of the RF box and then run the little RF cord to the NES. Then turn the TV to channel 3 or 4 and you can play it that way.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jun 21, 2011 | Video Game Consoles & Games
Rainbown lines on screen no clear picture
Hi
I would check your aerial and the coax lead from aerial to your TV to ensure that is ok.
Have you tried plugging in another video source, ie dvd player / vcr / etc.
Please dont forget to vote this answer was helpful and accept my answer.
Many thanks
Feb 22, 2011 | Harsper HP-4250VPM Television
HELLO I NEED A REMOTE CONTROL FOR THIS TV MODEL
There are 2 remotes that work right out of the box for these, the Samsung and the LG if you can find one. Best option of course is the 2 yr old and newer samsung LCD TV remotes.
There are also some Harsper remotes available on Ebay at the time of this writing.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m570.l1313&_nkw=Harsper+remote&_sacat=See-All-Categories
Sep 14, 2010 | Harsper HP-5000W 50 in. Plasma Television
Repairing Harsper tv
I CAN NOT CONNECT MY TV TO CABLE (COAX). THE ADAPTER IS MISSING, WHAT SHOULD I DO?
Apr 23, 2010 | Harsper HP-4200B 42 in. Plasma Television
Tv sparks bad when i apply the cable cord to it
EXTREME DANGER!!!!!
PLEASE LISTEN CLOSELY:
all appliances made in the last forty years have a polarized power cord.
One pin on power plug is small and other larger--the larger goes to the neutral side of the electrical outlet.
If you get sparks when you hook up the coax to the cable fitting--only one of two possible reasons.
Either the polarized cord has been defeated (plug modified) or the outlet you are plugged into is not wired right.
Understand--it does not have to be at the set you are using---if somewhere else in you home a cord is defeated or an outlet is bad--it will feed the problem via the coax to every other set in the home connected to the same line.
What you are seeing if you get sparks is the coax fitting has 120 volts AC getting to it either by the coax or from the power outlet--
The easy way to find this is disconnect all coax connectors in the home and with a voltmeter hooked to a earth ground (like a ground rod or pipe made of metal) measure for AC voltage to the coax.
THIS IS A VERY DANGEROUS SITUATION-BE VERY CAREFUL--
If even one set or outlet is bad it will feed this via the coax to all sets in the home---I have seen this before-yes it can destroy a TV! but it can also hurt or kill someone--this is the reason all power cords are now polarized.
IF YOU HAVE ANY QUESTIONS ASK ME--IF IN DOUBT HAVE AN ELECTRICAL EXPERT CHECK THE WIRING AND MEASURE FOR AC VOLTAGE TO THE CABLE--ac voltage can kill--it is the same as connecting a wall outlet to the exposed areas of the set.
THIS IS SERIOUS STUFF--DO NOT TREAT IT LIGHTLY!
SD TECH
Dec 19, 2009 | Samsung PN50B450 50 in. Plasma TV
I have 2 ps2 how do i link them to to tvs
SONY Instutions that came with it.....
SIMPLE: CONNECT THE FOLLOWING TO THE TV FROM THE PS2 VIDEO CORD.
YELLOW TO YELLOW
RED TO RED
WHITE TO WHITE.
Coax is much simplier.. Screw the Coax cord to the back of the PS2 to the TV.
Jun 29, 2009 | Sony PlayStation 2 (PS2) Console
I am looking for a mother board for a Klaum (Harsper) 42" flat screen Plasma TV (HP-4200VPM) Part number is MA6C01-2498.
May 11, 2009 | HP PL4260N 42 in. Plasma HDTV
Harsper HP-4200B 42 in. Plasma Television Logo
178 people viewed this question
Top Harsper Televison & Video Experts
Are you a Harsper Televison and Video Expert? Answer questions, earn points and help others
