Question about Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model
Craftsman 54 in lawn tractor W/ 26 hp Kohler engine
I turn the key and nothing happens, starter does not activate ... nothing. Battery test shows 12.4 volts. Sound like a bad ignition switch?
  • john andrew manchook Jul 19, 2010
    You can test the starter solenoid and switch for voltage as well. Check the starter too. Just ground the one side of the meter to the battery and touch the red side to all the contacts in question. You also have a seat switch or other interlocks that may be bad. Your battery might also be going bad. The volts might be good...but without the necessary amps that motor wont turn! You can use a wire to jump the solenoid. This would get around all the switches and interlocks. You can also use another battery and jumper cables to see if the starter will spin that way. Just be sure the parking brake is set and you are in neutral! Good luck and be careful!
  • 760 Answers
Could be, but test each item with your tester. Test key switch (12V in and 12 V out when turned to start., operator present switch 12V in 12V out (seat) Clutch switch, etc. till finally you test for 12V on the small terminal on the starter solonoid. Happy testing!
Posted on Jul 19, 2010
42 craftsman rider electricity at solenide non at starter.
Check power at solnoid on cable coming from battery. 12-13V. With key turn to start should have 12-13v
May 22, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riding mower starter will spin but not engage
The keys are not dropping in the clutch fan. Lightly tap with hammer before attempting to start. Will need to replace eventually.
Dec 16, 2014 | Craftsman YT 4500 54" Kohler 26 hp Gas...
What should I do; I have a craftsman 26 hp 54" deck yard tractor that will click but will not start?
Test starter by using jumper cables from negative pay on battery to a good ground (bare metal on the frame somewhere) and positive post to starter post ( should be a thick red wire attached to starter post. Be careful because the starter will turn bypassing all safeties. You should have the key off, parking brake on, blades disconnected. If starter turns, starter is good.
Jul 05, 2014 | Craftsman 26 Hp 54" Deck Yard Tractor
What makes a mower lose fire?
need fuel, spark and air. Make sure air filter is clear. Best way to test this is leave it off while you try to start (or restart??). For spark, easiest way is to spray starter fluid in the carb. If it starts, you have a fuel problem. If you havent lately (or ever?), change the fuel filter.
Jun 19, 2014 | Craftsman YT 4500 54" Kohler 26 hp Gas...
How do I acquire a belt diagram for a craftsman 54'' mower deck?
Search for your model number on sears site. If 0 results, search google with your model number. Owners manual usually has diagram.
Jun 07, 2014 | Craftsman YT 4500 54" Kohler 26 hp Gas...
Replaced starter and sylenoid - but engine won't always turn
sounds like the bendix spring is bad on the starter (it's the spring that returns the gear to it not moving state)...good luck
Mar 18, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
Will any other engine fit a craftsmen 26 hp lawn tractor other than the kohler
Yes there are 2 other options.
Briggs and Stratton, and Onan.
Here is the information. You will need to have your output shaft size.
http://www.smallenginewarehouse.com/
Feb 06, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
Have a craftsman 17.5 hp bought 7 or 8 years ago. Has "LT 1000" on its engine cover. Went to start it. Turned the key in the ignition, "nothing happened, checked battery, appear,o.k. The battery guage...
Yes, you may hear a small click when the key is placed in the run position. It is the fuel solenoid (on the carburetor) activating.
If it is a large click, then that is the pto clutch activating (as in the blades are ON) and that will not allow the engine to start.
Sometimes when a battery is low or connections at the battery are dirty, you will hear a click, that is the solenoid activating, but the battery voltage is low enough that the starter will not turn. Sometimes this condition has a chatter.
Easiest test for this situation is jump start from you automobile, or charge the battery for an hour, and see what happens from there.
Nov 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model Logo
559 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
