Question about Yard Machines 11A08MB006 22Inch 139cc MTD OHV Gas Powered Side Discharge
SOURCE: 4.5 hp Briggs& Stratton push mower will not run
You need to rebuild your carb. The diaphram in the carb has gotten hard and is no longer acting as a fuel pump to pump the fuel to the carb. Get a rebuild kit and a compressor (for compressed air) to blow out the jet passages. It is an medium to easy job, just watch the small parts. ----------------------------------------------------------------------------- Hint: Before you remove your fuel/air jets, bottom them out first and count the number of turns it takes to bottom them out and mark it down for each fuel/air jet. When you go to reinstall the fuel/air jets bottom them out and then back them back out to the number of turns before removal. That way the fuel/air jets are set to the right number of turns when it was running right. Good Luck, I hope this helped Please rate me...Thanks
Posted on Jan 04, 2010
SOURCE: New mower 158cc Briggs & Stratton engine April 2010
Um if its new take it back before you damage the govenor then its not warrenty!!
the springs are fine. the metal the the spring conects to on the throtle control sets the high speed. dont play with unless you know what your doing for every ones safety
Posted on Jul 02, 2010
SOURCE: I recently got a green Craftsman with yellow
You need to take the mower into a SEARS authorized store and have them show you the code meanings. Craftsman has changed a lot of their codes so for the first time this is the only way.
Posted on Sep 11, 2010
SOURCE: I have a old yard
I have found OEM part number 746-0552 on Ebay. This is for older units, say 1997 on. The cable is 49" in length. Here is a link to ALL the MTD brake cables on Ebay.
http://shop.ebay.com/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=MTD+brake+cable&_sacat=See-All-Categories
Yours is the MTD-White Outdoor Push Mower Brake Cable. # 746-0552.
We call this the deadman/brake cable. It allows a small brake pad to rub against the flywheel on the top of the engine while at the same time actuating a switch which shorts out the ignition current to the spark plug. An interesting and much needed device, right! Good luck. Hope this helps.
Posted on Jun 12, 2011
SOURCE: model 42a707 engine spitting gas out of carberator
Fuel needle leaking in the carb, remove the float bowl, check the float is moving freely, clean away any dirt, if no better replace the inlet needle.
Posted on May 06, 2012
Apr 14, 2013 | Snapper Garden
Jun 12, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
May 20, 2011 | Craftsman Garden
Nov 30, 2010 | Garden
Nov 11, 2010 | Garden
Sep 11, 2010 | Craftsman Garden
Aug 15, 2010 | Garden
Jun 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Dec 25, 2009 | Briggs & Stratton Heavy Machinery
Jul 12, 2009 | Briggs & Stratton Briggs Stratton Intek V...
172 people viewed this question
