Question about MagLite Mag Lite Led 2 Cell Aa Flashlight Select Color
Mag light won't turn off
I replace the bulb in my mini mag light flashlight. The bulb has two wires sticking under that you put in two little holes. When I put the batteries in, it turned on. It is supposed to twist on and off, and get brighter and dimmer, but it just stays on unless I take out the battery. Help
5 Suggested Answers
  • 121 Answers
SOURCE: how do you change the bulb in a mini maglite?
Carefully.....
Check in the base of the torch and you will see the spare bulb. you need to pull the spring out to get at it.
Next unscrew the top off the torch to expose the bulb.
The bulb is easily removed by gently pulling straight out. Replace the new bulb in the same way, lining the two pins up with the holes (doesn't matter which way round) and wipe the bulb clean of any finger grease etc.
Screw the top back on and replace the spring in the base before screwing the base back on..
Replacement bulbs, and all other parts for that matter, are easily sourced at any good outdoor store that stocks MAG.
Hope this helps..
Posted on Oct 07, 2009
  • 29 Answers
SOURCE: mini mag will not turn on
Somewhere in the flashlight their is a short, check everything from bottom to top.
GGBMDB
Posted on Dec 02, 2008
SOURCE: Change bulb on the 3 amp mini mag
pull the bulb strait out it should have two pins,the spring in the bottom also pulls out ,there you will find your extra bulb.
Posted on Jul 24, 2009
azanov_v
  • 3 Answers
SOURCE: How to disassemble mag charger rechargeable
http://www.google.ru/search?ie=UTF-8&hl=ru&q=how%20to%20disassemble%20magcharger&redir_esc=y&ei=Pj5hS7nAHYHFsgachrnPCw
Posted on Jan 28, 2010
Testimonial: "Very useful!"
How do I replace the led in a 2w d cell maglite
Unscrew the top half of the flash light and pull the bulb straight up, and it's out,
Not to mention there's usually a spare bulb in the base of the flashlight under the spring in a piece of foam. unless someone used it already,
Line up the two pins and slide it back into the to pin holes on top and with the bottom of the flashlight back on with battery's try the on off switch and make sure it lights up and not have dead battery's, if it lights up throw away the old led and screw on the top of flashlight,
If it still don't light check for new battery's.
Oct 03, 2014 | MagLite Mag Instrument Mag Lite 2 "D"...
I can't open a mini mag light to change batteries.
Twist off the opposite end of the bulb side , the hole in the cast of the cap is for your keychain ring.
Aug 08, 2011 | MagLite Mag-Lite& Flashlight
Cant open battery to change.Mini Maglite
My Mini Mag light has a knurled cap on the end opposite the light bulb. It should unscrew to reveal the AAA batteries.
Jan 16, 2011 | MagLite Mag-Lite& Flashlight
My Maglite torch that takes two AA batteries will not switch on. I think I require a replacement were the bulb fits into its connection.
The top just screws off and the bulb just pulls out....there should be a replacement bulb in the bottom cap under the spring inside that little plastic holder...just do not touch the bulb with you fingers when installing it. use a tissue paper to hold the bulb...
Line up the two little wires with the holes and gently press the new bulb in...
heatman101
Sep 21, 2010 | MagLite Mag-Lite& Flashlight
When i try to turn it on nothing happens wheter i put a new battery in or not
Try changing the bulb, also make sure there is no corrosion inside the bulb or battery housing
Aug 08, 2009 | Mag Instrument AAA Mini Maglite...
How do you change the bulb in a mini maglite?
Carefully.....
Hope this helps..
Jul 05, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
3 D mag flashlight diagram
Parts diagram is at: http://maglitesales.com/maglitestore/index.php/cPath/12_13
Gary
Jan 16, 2009 | MagLite Mag-Lite& Flashlight
Mini mag will not turn on
GGBMDB
Oct 08, 2008 | MagLite - Mag Charger System 110v (M)...
MagLite Mag Lite Led 2 Cell Aa Flashlight Select Color Logo
1,411 people viewed this question
Top MagLite Camping, Backpacking & Hiking Experts
David Black
David Black
 steve
steve
Alec Oren Orris
Level 1 Expert
Are you a MagLite Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
